You know Frank, you should change your stats. I doubt I is almost 3 meters long
Oh yes, and can I put Bloody tears in the goal horizontilly so more ground is covered? But not like it matters cause either way I can ajuist turn it when the match starts :P
Ok there are all chains
and heres the next 2
Position:Midfielder
Weight: 85KGS
Dimensions:1X1X1
Weapons: A big air filled hole which can either shoot the ball or pass.
Speed:12MPH
Drive:16 S28-400 Magmotors at 3 volts.
Armour:Kevlar
Transmission:chains
Additionals:Boots and Gloves
Positionefender
Weight:145Kgs
Dimensions:12X2X12
Weapons: 2 Big claws like tough as nails at the front and at the back
Speed:31Mph
Drive:2 Magmotors running at 24 Volts
Armour:Titanium
Transmission:Chains
Additionals:Boots on top.
Perhaps I should of made things a bit clearer, this comp is for 100kg HWs, no additional weights for tracks, 200kg limit on walkers, and from any side, the robot must be at least ball diameter smaller than the goal
Tim: I assume that voltage on Si is supposed to be 36v
ok and its 100kgs for anne
The last 3
Positionefence midfielder
Weight:99kgs
Dimensions:2X1X2
Weapons:A bi-rotational axe which spins upward and it has safety cameras to protect the opposition and my own team
Speed:21MPH
Drive: 4 S28-400 Magmotors at 36V.
Armour:Titanium
Transmission:Chains
Additionals:Boots on the axe
Position:Sub
Weight:100KGS
Dimensions:1X2X3
Weapons:A scoop
Speed:60MPH
Drive:4 S28-400 Magmotors at 36V.
Armour:Glass
Transmission:Chains
Additionals: has a flag that says Stoke Sucks
Position:Sub
Weight:100KGS
Dimensions:2X2X2
Weapons:A wedge with a scoop and bonbons
Speed:23MPH
Armour:Polycarbonate
Transmission:Chains
Additionals: has on the top blast off
Oh yeah my team is called Team Lucy not Team Tim and its the battle of the crap writers.
Im not certian if Anne would be 100kg with all that gear in the stats, and it cant go magically from 145kg to 100kg because you switched the numbers over.
Oh yeah.... Bonbons ? Those are sweets arent they ?
