MacFan Fic - Season 1
MDU3 VS Tengu
Well weve been here before, just previous incarnations. Main tactic is to keep total translation RPM down @ 1500rpm(Max of 2500) and bend his spinning shell in till it stops working. Once that is done, Tengu is not much of a challenge. I should take far less energy from the impacts compared to Tengu due to the fact my whole robot is rotating and there is no fixed axial point like in a shell/ring spinner. I want to stay agressive as possible in this match!
Knightrous Wedge VS Back 2 Rock 2
Simple tactics, rush B2R2 as soon as I can, attacking from the sides or back, getting under those skirts and pushing him to the wall, pin him against for wall for 20seconds. Then flip him over and push him to the next wall back off and give him a few seconds to selfright, but as he is about to finish self righting, rush under the airborne skirts, push him to the next wall and pin him again for 20 seconds. The idea is that, Knightrous Wedge is not very destructive, but is very fast, controllable and has a controlling weapon, so if I can keep controlling the opponent all the way through the match with out letting him have a chance, then I will rack up a lot more point in control and agression, making up for the lack of damage.
If I fail to go under the skirts, Ill just push him sideways since my front wedge will only lift to the top of those skirts and find a good pushing hold against the box sides on B2R2.
*Is that RP or tactics Alex *
Axeius VS Infusion
Simple tactic. Spin up, tear hole out of the armour from the sides. Advanced tactic. Spin up the shell up to full speed, dodging any of his movements in the process. Wedge him with my wedge, get under and then just sit there spinning, his drive will be off the ground and he will not be able to move, what Ill do then is slowly pivot on the spot and try to shift the wedge around to let the spinning rim come undernieth Axeius, a further more rotation on the spot will allow the wedge to slide out from under Axeius and let him drop his under belly into the teeth of my spinning rim. The idea being that if I can attack him from underneith with the rim, I can take out his drive wheels and cause immobilisation....
Easy to follow those Role-Tactics Alex
					MDU3 VS Tengu
* Axeius VS Infusion
						 ), slip under, let the Mute-style barbs hook into the wheel housings and essentially bash it into anything that comes handy - hazards, the wall, the audience...
