MacFan Fic - Season 1
    quote:
    No house robots, they suck.
    You Meanie
      OK then, then Ill have the WHOLE of Team Dinowarrior.
      ORKA MK4
      Weight: 100 kilos
      Body Shape: Behemoth
      Speed: Some 15mph
      TC: 0
      GC: 2mm, 0mm at front.
      Wheels; 6 inner
      Armour; 7mm titanium
      Power; 3x 12v batteries, powered by a couple of Magmotors
      Colour; Black with white patches
      Weapons; A Behemoth like bucket scoop, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
      Srimech: It has a dorsal fin on top used for self-righting
      Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
      Strengths; Weapon
      Weaknessess: Hard to turn
      BIO
      Every big team needs some big star to bring in the crowds. My big name is Orka MK4, representing Team Dinowarrior in all its glory.
      No one is faster, smarter or more agile than Orka Mk4. When charging, other robots need to get out of his way. He can flip just about ANYTHING that doesnt take the warning, or simply grab hold of them. Hes ready for battle! Are you?
      DIE-CERATOPS RE-INVERTUS
      Weight; 100 kilos
      Body Shape: Wheely Big Cheese
      Speed; 15mph
      TC; 0
      GC; 0mm at front, 3mm at sides and back.
      Wheels; 2 inner, sticking out only slightly,
      Armour; 8mm titanium
      Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
      Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
      Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
      Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
      Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
      Weaknessess: Tengu VI
      BIO
      Orkas cute-on-one-side-pure-hell-on-tuther friend, Die-Ceratops is equally as powerful and as nippy as his buddy. In the arena, he can get to oppodents/victims in record time. Then, once his flipper is underneath them, they can kiss the ground good-bye. Of course, hes teamed with me, and I can be rather protective over him...
      CYCLONE FORCE 2.5
      Weight; 100 kilos
      Body Shape; Storm 2
      Speed; 25mph
      TC; 0
      GC; Side is 0mm due to skirts. Back is 2mm. See set-ups for front GC
      Wheels; 6 inner
      Armour; 7mm Titanium.
      Power; Similar stuff to what Storm 2 uses.
      Colour; A blue-ish grey tone all over.
      Weapons; The robot has 5 set-ups, 2 brand new...
      SET UP 1...A lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
      SET-UP 2...A pair of Kan Opener style claws, with about 4 tonnes of pressure at the tip. Front GC for this and Set-up 3 is 1mm.
      SET-UP 3...A Disc-O-Inferno style disc, reaching speeds of up to 3000rpm and with similar damage capability to this dangerous bot (I mean, look what it did to Panic Attack).
      SET-UP 4...Two 30cm long spikes, which, combined with the speed of the robot, can easily penetrate weaker armours (Id say anything 4mm thick or less, minus Steel, is in a bit of trouble).
      SET-UP 5...The most risky approach, A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
      Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible. Set-ups 2, 3 and 4 work upside down.
      Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
      Strengths;Raw power
      Weaknessess;Lack of control, Set-ups 1 and 5 do not work upside-down.
      BIO
      When Cyclone Force 2.5 is in the game, every other piece of metal is scrap! Cyclone can travel across the arena with great speed AND power. His interchangable weapon system means NO ONE is safe. Thank goodness hes harmless when turned off.
      LEPROSY INFECTION
      Weight; 100 kilos
      Body Shape; Tetanus Booster
      Speed; 18mph
      TC; 0
      GC; 2mm
      Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
      Colour; A disgusting shade of lime green.
      Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
      Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
      Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
      Strengths; Drum, control is pretty good
      Weaknessess; Wheels may be vulnerable to axes
      BIO
      When youve got sharp teeth, sickeningly bright green paint and a name of a skin disease, battle invitations are pretty remote. So, hes loving life in the Robot Wars arena where he can make others sick. Leprosy Infections drum is killer! And when hes upside down, those teeth start gouging out his prey. Grrr...
      MEGA MASHER 2
      Weight: 100 kilos
      Body Shape: Minion
      Speed: 12mph
      TC: 0
      GC; 0 at front, 1mm at sides due to skirts.
      Wheels; 4 inner.
      Armour: A nice 3mm of steel
      Power: Similar stuff to what Tornado uses.
      Colour: Red and yellow.
      Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar comes out from the side.
      Srimech: The aforementioned bar rights the robot, even though it can run inverted.
      Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
      Strengths: Power, weaponary
      Weaknessess: A little bulky, not as heavy as the body would suggest.
      BIO
      Mega Masher is still hell bent on robot destruction. Whether you think of him as the baddest, most brutal robot ever or just a power crazed crazy thing - just dont tell him when his disc is spinning at full throttle! His wedge is also dangerous; being one of the lowest out there. Dont trust this robot to lose as far as you can throw him! Even better, dont try to throw him at all; hes based around Battlebot champion Minion, and way too bulky for flipping.
      Y4
      Weight: 99 kilos
      Body Shape: T-Minus
      Speed: 16mph
      TC: 0
      GC: 2mm, but the flipper blade reaches 0.
      Wheels: 2 semi outer (that means theyre protected)
      Armour: 5mm titanium
      Power: The usual 3x 12v batteries and couple Magmotors for power.
      Colour: Grey
      Weapons: An extremely powerful flipper (Try 300 kilos+). Can perform about 30 or so flips before it starts weakening.
      Srimech: The flipper acts as srimech. It can also be used as gymnastics. A light flip will knock the robot back over, but pressing hard on the button will send the robot into a 540 degree spin before landing, or a Matador style bound in mid air. All prperly controlled, of course.
      Inspiration: A quote from a cartoon. Taz-mania, I believe.
      Strengths: Powerful flipper, very entertaining.
      Weaknessess: Semi exposed wheels.
      BIO
      Even the simplest of names create a savage effect. This flipper flapper is back under my arms, and ready to make his own mark on the world. Like Mega Masher, he is based on a Battlebot champion, this time T-Minus, and thus is a master at powerful flips.
      AXE-O-LOTL
      Weight: 100 kilos
      Body Shape: Comengetorix
      Speed: 20mph
      TC: 0
      GC: 2mm
      Wheels: 4 inner
      Armour: Mainly aluminium (5mm) with 3mm Titanium top plates.
      Power: Same stuff as Storm 2 and Cyclone Force uses.
      Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
      Weapons: A very nasty axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
      Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
      Inspiration: My favourite amphibian, the axolotl.
      Strengths: Powerful weaponary
      Weaknessess: Questionable armour.
      BIO
      Axe-O-Lotl likes a bit of Mexican chilli powder with his lubricating oil. After a break in Mexico, Axe-O-Lotl has returned to join the mightiest of the mighty on Team Dinowarrior. His powerful/persistant axe is brutal, and he has just as much power as Cyclone Force.
      OBLITERATION
      Weight: 100 kilos
      Body Shape: Revolutionist
      Speed: 5mph
      TC: 0
      GC: 5mm all the way round. It has to be.
      Wheels: 8 inner (4 on top, 4 below)
      Armour: 7mm titanium
      Power: It drives on 3x 12v batteries plus a couple of Magmotors. For the weaponary, the power matches Phrizbee.
      Colour: Dark blue with tinges of black and brown.
      Weapons: This robot is a full body spinner. The teeth are increibally sharp. It spins at about 500 rpm, and does damage similar to Phrizbee.
      Srimech: Unusual for a FBS, this robot runs inverted.
      Inspiration: It sounded cool. It also sounds like a ride at an amusment park, if you ask me.
      Strengths: Body! Need I say more?
      Weaknessess: Rather slow, First timer
      BIO
      Obliteration has the disposition of a train wreck many times over. Though he prefers to take his time around the arena, his super powerful spinning body delivers a nasty blow. Obliteration is a first stringer, and considers himself A closer - And he doesnt like having his photo taken for some reason! Watch out for this guy - hes no sweet pleasent ride let me tell you!
        EXTRA NOTE: Because of the rule thingys, CF 2.5 will be using Set-Ups 1, 2 and 3.
          Firestorm, Mute, Storm 2, Typhoon, Gravity, X-Terminator, and
          Wolf
          Mass-100kg
          Weapons-front hinged flipper running at 175psi
          Dimensions-95cm length/80cm width/40cm high
          Shape-low wedge shape/sloped rear with skirts on the side
          Wheels-Four inner wheels
          Top Speed-22mph
          Armour-6mm titanium all round
          Motors-2x LEM130s at 36v
          Power-4 x 48v NiCD 3600Mah Packs
          Ground Clearance-0mm around the whole body.
          Strenghs-Nippy around the arena, dependable armour, good weapon, can get under anything.
          Weakness-Flipper cant get robots OOTA all the time (it can some times)
          Enterprise
          Dimensions-95cm length, 80cm width, 40cm height.
          Weight-100kg
          Shape-low wedge/sloped rear with Biohazard like side and rear skirts
          Wheels-4 inner wheels
          Speed: 19 mph
          Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 1000psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. Spikes at the back to prevent the robot from flipping itself over.
          Motors-2 LEM-COs running at 36v
          Power-4 x 36v 3600mAh NiCD packs
          Armour-7mm titanium all around
          Ground Clearance-0mm front, 0mm around the sides/back with skirts.
          Turning Circle-0m
          Strenghts-Powerful flipper, nippy around the arena.
          Weakness-Flirts with Matilda.
            ONE real robot Kevin. ONE.
              Boulderdash
              Street Magician
              SUNCUST
              Shovearound 2
              Psycho Cyan Evolved
              Brian Boitano
              Judo Chop
              Walk Away [150kg setup]
              Cyberdemon
              Mr. Slave 2
              Terror Gear 3
              Shotgun Slapper
              Novastorm 2
              Bloody Tears 2
              Apply Some Pressure
              Dr. Evil
              Annihlator: SUNCUST is my current favorite, so lets go with that.
              Otherweights:
              AW: No Stairway to Heaven
              FW: Scarlet TOuch
              LW: Dales Dead Bot
              MW: Waynestock
              SHW: Walk Away [200kg setup]
              Lemme know if I need to drop some robots from the main comp, although im pretty sure I dont have to.
              http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
              (Message edited by Swiss_tony on November 16, 2005)
                My apologies, misunderstood the 16 robot rule....
                Boulderdash
                Street Magician
                Shovearound 2
                SUNCUST
                Shotgun Slapper
                Novastorm 2
                Terror Gear 3
                Cyberdemon
                • #23
                  Since I love you alllllll so much, I went and made a CAD of the arena for you! You mean you downloaded the Arena from happyrobots.com and modified it into your arena
                  Ill enter there 4 in everything possible:
                  Motivation: 4 x 125mm wheels
                  Speed: 0-12MPH [25MPH under Kinetic Boost]
                  Clearance: 7.5mm (same inverted) 0mm at the front, the wedge scraps the floor.
                  Weight: 100kg
                  Height: 125mm
                  Length: 800mm
                  Width: 600mm
                  Weapon: The weapon is a 31kg Hardox spinning ring (Ala MDU) powered by a LEM170 @ 36v. The rim rotates at 1800rpm and should spin up within 2-3 seconds max. The weapon is also a storage device for the drive. The spinning rim is connected to each side of the drive via a car air conditioner clutch, when the clutches are engaged, the 31kg kinetic storage bank(the spinning rim) transfers its energy into the drive train, giving it approximately double torque and speed for 2-3 seconds until the rim starts too loose speed and energy. This extra €˜kinetic€™ boost is used to ram into opponents with the front 10mm thick Hardox 500 wedge (similar to the one on Warrior SKF but wider and less depth to it). The front wedge is rubber shock mounted to ensure it survives the biggest of hits.
                  Drive: 2 x C40-500 Magmotors on 36v geared 7.5:1. The drive is also assisted via the spinning rim as explain above.
                  Batteries: 90 x 3600mAh NiCD Cells configured into 3 x 36v packs. This gives an output of 36v @ 10.8Amp/hours.
                  Armour: Front wedge is made entirely out of 10mm Hardox 500, the top and bottom of the robot is made out of 8mm Titanium/Vandium, The ring is made out of 10mm Hardox 400 with inner bracing to the perimeter bearing. Inner bulk heads are made from 20mm polycarbonate and 10mm aluminium.
                  Notes: Invertible, speed when needed and generally well controlled for a spinner.
                  Name:Mass Disctruction Ultimate 3
                  Motivation: 3 Wheels
                  Speed: 12MPH (480MPH Tip Speed)
                  Weight: 100kg
                  Height: 250mm
                  Diameter: 800mm
                  Weapon: The robot itself is the weapon. It uses its drive and a custom made micro processor system similar to that used in a fellow translational spinner called Cyclone Bot to translate itself around the arena creating a €œVortex of Destruction€. Using 9 Hardox €œenlightened€ teeth, it tears its opponent to pieces when the teeth collide at a sub-sonic speed of 480MPH. Causing certain death to the opponent.
                  Drive: 3 x Briggs & Stratton Eteks running on 60v. The motors are protected with a current limiting circuit and a thermal protection system which will ensure the motors don€™t over heat. The drive system uses a unique variable drive system with load sensing technology which enables the robot to start rotating with a high gear ratio preset at 5:1 giving the motors high torque low speed. As the robot gains rpm, which is constantly monitored via wheel rpm sensors, the gearing then adjust to suit the load of the motors and gain further speed allowing the gear ratio to lower from 10:1 to as low as 1:1 at top speed. The gear ratio can also over drive thrown the ratio 1:2 giving the robot nearly double the original top speed and allowing far more energy, but this is only used when the opponent is at a distance where it can easily be disposed of. Otherwise, the drive is left at 1:1 maximum.
                  MDU 3 sports an advanced drive control system to that of Cyclone Bot as it uses motor and wheel sensors to travel and translate in the most efficient possible way, minimising energy lose. The drive will adjust ratio to suit condition if it is loaded and will change if need to translate at the full 12MPH (6MPH up on the last version since the robot size has decreased for faster movement, quicker spin up times and thicker armour). Spin up time is minimal and varies between 0.5sec spin up and 1sec when the system is suffering from battery voltage drop. At a mere 1/7th of its full RPM, this robot will be dangerous. 500rpm will have enough energy to throw robots out the road and allow it to continue its quest for domination. If people start ganging up on it (Everyone will, I know), the drive system will be locked down into 500rpm mode allowing the drive to have nearly maximum potential torque yields and it will force the opponents away till it can then safely power back up to full speed and deliver the force of the €œVortex of Destruction€. To ensure endurance during combat, everything has been shock mounted for maximum protection in Urathane and Medium Density Foam.
                  Batteries: 250 x 3600mAh NiCD cells producing 60v @ 18amps. The packs are protected by a system like the drive which give both current and temperature protection. The packs are re-enforced between the cells with Polypropylene cell holders and will prevent them from breaking during the impacts.
                  Armour: 4mm Hardox 500 with stainless steel welding built in a monocoque design with triangle shape and inner supportive bulkheads. 10mm Polycarbonate on the top to save weight due to the upgrade to Etek motors and higher voltage
                  Notes: Invertible. Soon to be your worst nightmare. All within your precious 100kg weight limit. Approche Avec prudence.
                  Motivation: 6WD
                  Shape: A wedge shape like SJ (http://www.buildersdb.com/botpics/845.JPGhttp://www.buildersdb.com/botpics/845.JPG)
                  Speed: 35MPH
                  Weight: 100kg
                  Height: 320mm
                  Length: 750mm
                  Width: 650mm
                  Weapon: A speedy hydraulic front hinged lifter/flipper (0.25 second to do the full 120 degree movement) which is powered by a hydraulic motor geared 12:1 onto a crank shaft that lever on the lifting arm. (Diagram can be provided for Writer). The front wedge is made out of 10mm Hardox 500 and scraps the ground at 0mm.
                  Chassis/Armour: 5mm Hardox 600 sides, 8mm Titanium base and top. 3.25mm Hardox 450 floating skirts on the sides and back.
                  Drive: The drive is a hydra-static drive train. It has a 42HP Honda CR125 motor bike motor (2005 model) with a custom made swash plate hydra-static pump bolted to the motor output shaft. The hydra-static drive provides full motor torque at 0MPH right up to 40MPH (Electric motors and normal hydraulic drives cannot provide this feat, if you google hydra-static, you€™ll find out why). 6 x 120mm wheels that are 100mm wide provide the maximum traction when coated in 15mm of Urathane Rubber (Volcalon).
                  Notes: The robot is invertible. Gyro-stabalised and has an active traction control system build from a pair of 18X picaxe chips and some custom software and sensors. This will help maintain maximum control and handling at high speeds. Can self right with lifter and has 0mm ground clearance at the skirts and 15mm under the body.
                  Advantages: The SPEED! The Pushability! The Strength!
                  Disadvantages: Having to keep your opponent in the arena long enough to have fun
                  Realie: Team Whyachis Warrior SKF! Picture here: http://www.buildersdb.com/botpics/2396.jpg
                  Any questions?
                  (Message edited by teamvertex on November 17, 2005)
                  • #24
                    Firestorm
                    Wolf
                    Mass-100kg
                    Top Speed-22mph
                    Enterprise
                    Weight-100kg
                    Speed: 19 mph
                    Turning Circle-0m
                    Firefly
                    Mass-100kg
                    Weapons-front hinged flipper running at 1000psi, with a back attachment so you can flip robots from the back. Need any pics, just ask.
                    Dimensions-90cm length/80cm width/35cm high
                    Top Speed-20mph
                    Armour-7mm titanium all round
                    Ground Clearance-1mm around the whole body.
                    Strenghs-Nippy around the arena, dependable armour, fast weapon, can get under anything.
                    Weakness-Flipper cant get robots OOTA all the time, but it can send a robot far.
                    • #25
                      Axeius
                      Mass-100kg
                      Shape-Like Terrorhurtz with armour around the wheels.
                      Weapons-a big very nasty axe with the power of Terrorhurtz, however the robot can always self right so it wont be pinned anywhere. It can fire 60 times in a fight. It is precise too.
                      Dimensions-80cm length/80cm width/30cm high
                      Wheels-Two inner wheels
                      Top Speed-20mph
                      Strenghs-Nippy around the arena, dependable armour, great destructive weapon, can get under anything.
                      Weakness-sides are vulernable to flips.
                      • #26
                        is the arena floor magnetic?
                        if so, Ill change 1WDs vacuum cleaners in ball-shaped electro-magnets, and I can assure you itll definately work then
                        if not... well, it depends how soon this tourneyll actually start, if I dont have a valid replacement for 1WD in time, just skip FLick of the Wrist, Liar, Beta and 1WD so Ill have 4 entries, if I design a valid replacement in time, good for me
                        • #27
                          save a space for me in everything i need to locate some stats
                          • #28
                            Maybe
                            • #29
                              Well, Martyn is saved a space... the last space in the tournament. Although, Martyn, if I counted correctly you may only enter 4 robots for this.
                              Worry not, Martijn, I counted all the robots up without 1WD and it comes to an exact 60. Odd, but nonetheless, satisfying.
                              • #30
                                Ill enter and team up with someone else cause I really want to be in a new tourney.
