The Spanish Inquisition QT
    Look before you leap Kevin, the tournys full...
      Going home today so i dont know if ill get any more tactics in until Thursday, but for Hit Me, i have much lower ground clearence, ram it all over the shop. Finish it as soon as possible though, dont want to take any chances.
        NOTES- according to frank the name is rude, first star shaped robot
        Ahh, Martyn, how naive you are.....
        Anyways, as for tactics: spin up and make precise hits at the oppertune moment, my weapon should be up to speed before his as it is smaller givign me the advantage, keep the disc pointed at him at all times.
          Walk Away vs. Back to Rock II
          I guess a machine will be counted out when it doesnt move for a certain period of time?
          if so, just drive in, watch how his legs are pulled in, and start driving circles around him like vultures do to their preys, either he will be counted out for not moving, or hell start moving at a certain moment, which is when I (carefully) come in to slam and pin him at the arena wall, keep coming in with the saw from that point.
          Even IF (and I say IF) I accidentally drive up his plow, I should be able to drive off, and I think Id win it on a JD because I was way more active
            Damn and wahoo Damn being that hes better than me and wahoo being that he hasnt got a hammer or an axe
            Tactics: Get underneath the ground clearence and hopefully ram into the pit switch and then simply lower down the trident-flippy thingie and drive forward shake and down goes love machine.
            Predictions:
            Im going to say the walkers gonna walk away and out of the contest
            Very tricky but Im going to be saying that Martyns having roast salamander tonight
            as much as I want battle raptor 4 to win I have to say that theyre gonna be extinct.
              If a robot doesnt move for 20 seconds, than Ref starts to count it out, where the machine must move before 10 is reached.
                I have the higher speed in my fight, so Ill use it to try and go for his sides. When I get there, I will (obviously) clamp. His description says it is drilled for holes, so maybe I can try to clamp into one of those holes. Really get a grip from that and cause more damage that I would with no hole. From there, just go for the pit.
                Should he get under my claws, just use my superior speed to back off before he can get the flip in. After I have backed off, then go straight back in while the flipper is up. Then clamp underneath his flipper and pit him from there. This scenario is only if he gets under my claw though.
                I just really have to clamp him, and then use my superior drive to pit.
                Now for my obviously incorrect predictions! =P
                Love Bite V 2.0 vs. Hit Me = Love Bite will hit him.
                Walk Away vs. Back to Rock II = Hes Back To Rock and hell rock through to the next round.
                Star 69 vs. Salamander = Im not sure. If Salamander can actually take off one of those star hammer things, then hell go for it. However Salamander does look like he can be smacked around. Ill have to go for Star 69 on this.
                Flank Attack vs. Battle Raptor 4 = Hopefully me.
                Gluck!
                • #23
                  Can you READ tim? It has a CRUSHER!
                  • #24
                    predicting is cool...
                    Love Bite V 2.0 to totally abuse the high ground clearance of his opponent, and pierce the weak top with his claw
                    Could go either way, the fact that Star 69s weapon works 360 degrees arround might be decisive
                    Can also go either way, but I very much like Flank Attacks design...
                    • #25
                      alex i put that in ages ago and i know what it means i really should look at what i am posting :P
                      spin up and attack salamanders wheeles and i think it will hopfuly stop it on one side i will then do the other side or i will stop spinning and push it from behind and dump it down the pit
                      • #26
                        I like the name actually...
                        ... WHAT?
                        • #27
                          Youre not the only one Martijn...
                          What?
                          • #28
                            WEAPONS Weapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. thats a quote so cant you read Anthony Politzi or whatever the hell it is.
                            • #29
                              Dont say I CANT read. YOU CANT READ IT YOURSELF. HIS PINCHERS CAN DAMAGE LIGHT/MEDIUM ARMOR AND YOUR ARMOR IS VERY LIGHT. Read it before you try to win the fight, moron.
                              • #30
                                Ill tell you when your older - Anthony shouldnt know about that kind of thing at his age.
                                If you want to know Martjin Ill tell you on msn as your older than me and probably would know if you came from the UK, though really its probably not worth your time.
