Mechanical Noise - Series 1
Yes, yes, YES!!!
The semi-finals start NOW. Fasten your seatbelts and enjoy.
Semi-finals
Fight 1
Achilles vs Wedge Devolution
3€¦ 2€¦ 1€¦ Activate!
Today€™s contestants need little introduction I guess. It€™s the boxy and strong pneumatic flipper with skirts at the sides up against the wedgy and sleek pneumatic flipper with skirts all around. Both contestants will have a though match. Then again, both contestants know that they€™ll get another shot at reaching the finals as both Alex and Steve have two vapours in these semies. Anyway, a little less conversation a little more action please
. Achilles is off already and doesn€™t try anything fancy, it aims straight for the wedgebot. A split-second later, Wedge Devo pretty much tries the same tactic. Near the arena centre, Alex does try the more subtle approach and makes a quick turn to the left. A good tactic, but not surprising enough for Steve who steers his manoeuvrable machine to the right to fend off Achilles€™ attack. Then, both machines meet in a rough collision! We can immediately see one of the many similarities these robots happen to have, Achilles€™ Bigger Brother style lifting plate halts Wedge€™s bent flipper blade, but has troubles getting underneath. Wedge has the same problem but Steve bloody well knows he can€™t beat Achilles in a pushing match and quickly turns around backwards as if he was parking his car
. Not only does this get Devo away from Achilles€™ flipper, it also sends it in a circle to Achilles€™ back! It€™s quite an inefficient way to get there though, and Achilles turns around already to face Wedge. As a matter of fact, Achilles is in a manoeuvring mood now and in a quick burst of acceleration gets to the side of Wedge! The Greek hero cannot penetrate the geometric shape€™s (Wedge
) skirts upon contact. Alex can finally put his superior traction to good use though and takes Wedge along for a few metres until Achilles€™ power does get the upperhand and Achilles gets underneath Wedge€™s side skirt. Alex fires his flipper with everything he€™s got and Wedge is send flying. Onto its back, Steve quickly activates its srimech before Achilles comes steaming in. Wedge hops into the air and ends up on top of Achilles€™ bulky body! The PTT-champ fires its flipper again to shrug off its nemesis, which ends up behind Achilles, again flipped. Achilles keeps on steaming forward and makes a U-turn, but Wedge is back on its feet again and goes in a reverse-turn to avoid another collision with the semi-rambot. Achilles brakes down but Wedge is already behind it and rams its skirtless back. FLIP! Wedge easily got past Achilles€™ defences and now it€™s Achilles who bites the dust. Achilles lands on its t-bar , but still needs help from its flipper to get back on its wheels before Wedge comes charging in. And so Achilles does. Wedge however, seems to have found Achilles€™ heel in its back. Again on the offensive, Wedge skids towards Achilles€™ back, who turns and dodges, and aims up. We€™re back where we started people, two flippers manoeuvring around each other to get that flip in. Wedge proves to be a bit quicker on its feet and turns into Achilles€™ back before Alex can answer. FLIP! Wedge does it again, and he rages into Achilles again. However, this time he aims to the side where Achilles will be after he self-rights, having learnt from the past. When Achilles is about to hit the floor Wedge comes in for yet another flip! Achilles makes a 360 and€¦ to Steve€™s displeasure€¦ comes down onto its wheels. This doesn€™t stop Steve from ramming Achilles€™ side, it does, however, stops Steve from getting underneath as he hits Achilles€™ skirts. Steve charges forward and slams Achilles against the wall. Wedge reverses a bit to gain momentum to penetrate those skirts, but Achilles moves forward€¦
10€¦ 9€¦ 8€¦ 7€¦
Good lord, time is running out. Wedge moves forwards again, nudging a fleeing Achilles€™ back.
6€¦ 5€¦ 4€¦
Wedge fires its flipper from this inefficient position, Achilles ends up on its side.
3€¦ 2€¦ 1€¦
Achilles fires its flipper. The flipper hits the arena wall nearby and Achilles is back on its feet.
CEASE
O lord, neither of the machines could finish the other in this flipper frenzy, the judges have to decide.
Damage: Achilles ((1 out of 10)*2=10)
Wedge Devolution ((1 out of 10)*2=10)
Aggression: Achilles ((6 out of 10)*1.5=9)
Wedge Devolution ((8 out of 10)*1.5=12)
Control: Achilles ((7 out of 10)*1=7)
Wedge Devolution ((6 out of 10)*1=6)
Style: Achilles ((7 out of 10)*0.5=3.5)
Wedge Devolution ((6 out of 10)*0.5=3)
Achilles: 10+9+7+3.5= 29.5
Wedge Devolution: 10+12+6+3= 31
Achilles couldn€™t impress the judges
Wedge Devolution goes through to the finals!
Coming next(next Sunday, actually, when I can access my other computer
Flank Attack vs Psyclonised
Yes, yes, YES!!!
Semi-finals
Fight 1
) skirts upon contact. Alex can finally put his superior traction to good use though and takes Wedge along for a few metres until Achilles€™ power does get the upperhand and Achilles gets underneath Wedge€™s side skirt. Alex fires his flipper with everything he€™s got and Wedge is send flying. Onto its back, Steve quickly activates its srimech before Achilles comes steaming in. Wedge hops into the air and ends up on top of Achilles€™ bulky body! The PTT-champ fires its flipper again to shrug off its nemesis, which ends up behind Achilles, again flipped. Achilles keeps on steaming forward and makes a U-turn, but Wedge is back on its feet again and goes in a reverse-turn to avoid another collision with the semi-rambot. Achilles brakes down but Wedge is already behind it and rams its skirtless back. FLIP! Wedge easily got past Achilles€™ defences and now it€™s Achilles who bites the dust. Achilles lands on its t-bar , but still needs help from its flipper to get back on its wheels before Wedge comes charging in. And so Achilles does. Wedge however, seems to have found Achilles€™ heel in its back. Again on the offensive, Wedge skids towards Achilles€™ back, who turns and dodges, and aims up. We€™re back where we started people, two flippers manoeuvring around each other to get that flip in. Wedge proves to be a bit quicker on its feet and turns into Achilles€™ back before Alex can answer. FLIP! Wedge does it again, and he rages into Achilles again. However, this time he aims to the side where Achilles will be after he self-rights, having learnt from the past. When Achilles is about to hit the floor Wedge comes in for yet another flip! Achilles makes a 360 and€¦ to Steve€™s displeasure€¦ comes down onto its wheels. This doesn€™t stop Steve from ramming Achilles€™ side, it does, however, stops Steve from getting underneath as he hits Achilles€™ skirts. Steve charges forward and slams Achilles against the wall. Wedge reverses a bit to gain momentum to penetrate those skirts, but Achilles moves forward€¦ 10€¦ 9€¦ 8€¦ 7€¦
6€¦ 5€¦ 4€¦
3€¦ 2€¦ 1€¦
CEASE
) Flank Attack vs Psyclonised
