Not-So Insane Robotic Elimination Challenge!
HEAT THREE:
Calm Down Dear, its only a robot
Cosmic Thunder
The Circle Revisited
Yet Another Cut Above The Rest
Number one tactic: Flip flip flip! Try to flip them all and get points for it!
HEAT FOUR:
FBSDS
Son of Ripper
Son of Wedgie
Forklift
Hmm... this is going to be a bit harder. FBSDS has a self-righting arm at the top, but I dont want to have to use it that much. Try to spin up and keep to myself, if I get a clear shot of someones back, take it and hit them.
HEAT ONE:
Star 69
Dante
Meat Slicer 2
Balder
Meat Slicer 2 is Balders worst nightmare. It should easliy get under and really rip up the plow, tossing and turning him over. Dante really shouldnt be much of a problem either, since its an axle-bot, but well see.
HEAT FOUR:
Allanon
Chameleon
GeForce
Flank Attack
Stay away from GeForce, when I have to. Instead, go for Allanon. My armor should hold up to those spinners, and I should easily clamp him. From there, take him to hazards till hes dead. Then try to take GeForce from behind for teh wins!
HEAT THREE:
CDM
Windmill
Drumroll
Axeolotl
Windmilll want to go for Axeolotl since it has questionable armor. Im not faster than it but I should be able to get round the sides easy and smash him to bits. Drum Roll 2 will go for CDM, and rip up that wedge and possibly flip CDM over easy. Then Windmill should be able to rip off those vunerable wheels of Drum Roll 2.
HEAT FOUR:
Malaria
Argo
Kali
Pit Drone
Malaria should get underneath Agro, whatever Richard says. I do have that front weak lifting plate, which can press against the ground putting more weight on it, making it extremely low to the ground so thats what Ill do. Ill then get under Agro and start hammering, not letting him get away. Pit Drone, will go for the sides of Kali, getting under that high GC and really ripping up stuff with the disc. Then itll probably be Malaria who takes it.
HEAT THREE:
Cosmic Thunder
HEAT FOUR:
FBSDS
Son of Ripper
Son of Wedgie
Forklift
HEAT ONE:
Star 69
Dante
Meat Slicer 2
Balder
HEAT FOUR:
Allanon
Chameleon
GeForce
Flank Attack
HEAT THREE:
CDM
Windmill
Drumroll
Axeolotl
HEAT FOUR:
Malaria
Argo
Kali
Pit Drone
