Yep. After two failed attempts at tournies, Im trying again. I never know when to quit, do I? This time, however, less overkill on the hazards, for your much needed sanity.
ARENA: A arena with two segments, connected by a tunnel. In the first segment is where a majority of the hazards are, and the robots starting positions. The second segment is where the house robots are, so try not to get pushed over there!
Segment one: 4 hazards here. 4 discs [like the spinners from the Battlebots arena, except with spikes instead of just being bare, so instead of just disorenting, they can also do damage] in each cornor, 3 heated circular diamond-tipped killsaws that come out horizontilly in the middle of each side[ excpet the side where the tunnel is]2 arena flippers [Like the ones in RW, except for more powerful and shoot upwards, located close to each ohter in the middle of the arena] and one pit shortley behind those two flippers, which opens halfway through the match. OOTAs can also be scored with a well aimed flip over one of the sides.
Tunnel: One side is located at the bottom side of the first segment [both are shaped like squares] and the other is located at the top of the second segment.
The area seperating the top and bottom is pretty wide, so a good flipper could flip whoever was pushing it, back up, then turn the tables!
Second Segment: If the house robots are angered here, they will attack and try to chase you to the other side! Or, if they feel like it, they could send you to the FOrge hammer on the opposite end of the tunnel, which is like the pulveriser from Battlebots, but with a heated spike attached.
Possible house Robots:
Psycho Cyan Evolved: Same as version on the FAR stats, but with 20kg discs instead of 10kg, and also 9mm hardox. Also two more drive motors.
Shovearound 2: Same as before, but with 4 PERM PMG 132s powering it on 72v! Try fighting back to THAT kind of pushing power!
Hurricane Hugo 4: Same as before, but with a 40kg spinner mechanism and 8mm hardox on the top and bottom to protect it aginst hammers! Also run by THREE eteks on 48v instead of S28-400 mags, which power up the speed to 50mph!
SUNCUST: Same as before, but now powered by 4 Eteks on 48v which brings up the speed to 25mph, and the jaws have been powered up to 5000 PSI with 20 tons behind it! Also 10mm hardox.
Only two house robots will be in at a time, randomly selected.
The format will be like this: Four brackets of 16 bots each. There will be 4 heats divided with 4 robots each for each bracket. Each robot that is the last one standing [or wins a judges decision] Goes through. The winners of each of the four heats then fight each other, and the last two eliminated are out. Then its a one-on one fight between the two survivors. The winner of that match moves on to the finals. Once the four finalsts make it there, theres another heat with 4 robots. The first two out fight each other in a playoff, and the last two standing face off for first place. Unlike most tournys, there are only 4 seeds, and if theres a next season, those four will be in the first heat of the first bracket.
Also, like most tournys, Heavys only.
REGISTRATION RULES:
One person may not enter. That person knows who he is.
Please, no reserving spaces. This isnt a grudge or anything, but I want to prevent any further hold-ups beacause people wont get their stats in [glares at Martyn while getting memories from minimirec]
*Note, Martyn isnt the one restricted from entering, just for those who thought so*
No nets, chains [if used for attacking] passive-only bots, flamethrowers, or anything else that wouldnt be allowed in other tournys. Clusters are allowed, and can be linked by any means. All of the bot must be knocked out to be eliminated, though.
8 people to enter 8 vapours each. No realies allowed.
JUDGING:
17 points are given between 4 catagories: [Note this still holds true for 4 way heats, but bots knocked out will not recive any points]
Damage given: How much damage you dealt.
Damage taken: How much damage you recived.
Control: How well you controlled the other bots.
Agression: How agressive you were.
That should cover everything. Heres hoping for some entries this time!
REGISTRATION RULES:
JUDGING:
