Not-So Insane Robotic Elimination Challenge!
    It is Frank...
    ...Blackadder
      ill enter
        Forget it, Tim. I dont even wanna SEE what unrealistic thing thats overpowered and overweight that you have next...
          gee, Im still wondering who that one person might be
            Is that sarcasm, or not. I suddenly have an idea of who that person is.
              shape: box shaped
              colour: green purple and black
              weight:98.04kgwheels,130kg,walker
              speed: 3-14mph
              turning circle:0mm
              Ground clearence: 0-100mm
              armour: 3mmbulletproof plastic like small torque
              movement:interchangeable between 6wheels and 6legs
              power: 3x12v batteries
              weapons a flywheel in the front and a flipper in the back.
              srimech: flipper the flywheel stops it from getting stranded on its front and theres x-terminator style srimech arms
              to stop it getting stranded on its sides
              strengths: shape, flywheel
              Weaknesses: reliability
              notes: if its overweight on wheels then I will take off the flipper and use it only on the legs system.
                1) Tim, Tony said you couldnt enter
                2) Please excuse me while I n00b flame...
                [weight:98.04kgwheels,130kg,walker]
                This means what exactly? Your wheels weight all but about 2kgs of your weight and you also have legs that put you overweight?
                [speed: 3-14mph]
                Why 3mph? And would that suggest your robot has two speed gearing? I highly doubt it...
                [Ground clearence: 0-100mm]
                10cm ground clearence? I think you mean 10mm
                [armour: 3mmbulletproof plastic like small torque]
                A little on the weak side for a Heavyweight robot... well in fact, my Featherweight uses thicker stuff than that :P
                [movement:interchangeable between 6wheels and 6legs]
                Is this even permitted in the rules? I dont think it is possible, sorry, nice idea but it would involve too much work changing all the mechanisms around.
                [power: 3x12v batteries]
                What type of batteries? SLA, NiCad, NiMH, AA? :P
                [weapons a flywheel in the front and a flipper in the back.]
                What are the powered by, what size is the disc, what hinge is the flipper?
                [strengths: shape, flywheel]
                Box shapes are actually weak in environments like with with super spinners.
                [Weaknesses: reliability]
                One of the classic weaknesses, how the hell does a fictional robot have reliability problems especially when it is (AFAIK) new? Theres plenty of other weaknesses above to take into account...
                Sorry to interupt you Tony, but I thought it was needed. And soz if I seem to picky or have said anything wrong, too. Nice to see youre trying Tim, but theres still lots of stuff to learn.
                • #23
                  No problem andy.
                  Tim, can you read? I DONT want to see what kind of unrealistic, unworking designs you have up your sleeves. Do us all a favor and just give up and LEAVE.
                  • #24
                    I know Im supposed to be retired, but meh.
                    Team Name - Team Whatever I Decide to Call It
                    Team - Me!
                    Robots:
                    Seggy 4.25; Chalkie 3G; Mortgage; HHISTWT; Calm Down Dear; Son of Wedgie; The Circle Revisited; The Tim Tribute Robot
                    Robots name - The Tim Tribute Robot
                    Mass - 100 kg
                    Weapons - Sod All
                    Can it self-right - No
                    Velocity - 1 mph
                    Turning Circle - 2 metres
                    Ground clearance - 30mm all over
                    Skirts - Nope
                    Wheel Type - 10 wheels
                    Motors - Each Powered by a drill motor
                    Body Shape - Box
                    Armour - Paper
                    Colour - Pink
                    Summary - It Owns
                    Strengths - Everything
                    Weaknesses - Nothing
                    • #25
                      First off, hahaha....second off, that better not be your REAL 8th robot dave :P
                      • #26
                        Team Name: Canadian Beef
                        Wolf
                        Mass-100kg
                        Weapons-front hinged flipper running at 200psi
                        Dimensions-95cm length/80cm width/40cm high
                        Shape-low wedge shape/sloped rear with skirts on the side
                        Wheels-Four inner wheels
                        Top Speed-22mph
                        Armour-7mm titanium all round
                        Motors-2x LEM130s at 36v
                        Power-4 x 48v NiCD 3600Mah Packs
                        Ground Clearance-0mm around the whole body.
                        Strenghs-Nippy around the arena, dependable armour, good weapon, can get under anything.
                        Weakness-Flipper cant get robots OOTA all the time (it can some times)
                        Firefly
                        Dimensions-95cm length, 80cm width, 40cm height.
                        Weight-100kg
                        Shape-a low box shape with Biohazard like side and rear skirts
                        Wheels-4 inner wheels
                        Speed: 22 mph
                        Weapon: A lifting arm (like Biohazard-like) that can comfortably lift 200kg. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 10cm. It could be used against dangerous spinners
                        Motors-2 LEM-COs running at 36v
                        Power-4 x 36v 3600mAh NiCD packs
                        Armour-7mm titanium all around
                        Ground Clearance-0mm front, 0mm around the sides/back with skirts.
                        Turning Circle-0m
                        Strenghts-Powerful weapon, nippy around the arena, low to the ground.
                        Weakness-May take some time to self right.
                        • #27
                          Kevin: Read the rules please. You need EIGHT vapours, not just two.
                          • #28
                            anthony read the rules you suck stupid swiss people mmm swiss cheese drools
                            • #29
                              Timothy! For Gods SAKE! Just LEAVE PLEASE! You seriously are not liked here and are being a right stuck up idiot.
                              • #30
                                Tim, this is actually Tonys tournament, he doesnt need to read the rules...
                                And why does he suck Swiss people? The Swiss are quite clever, not stupid.
                                You are doing the impossible and making battling fantasy robots weirder! :P Shape up or ship out, you seem to ignore whatever advice we give you to make better vapourbots so we can only presume you are here to annoy us - dont.
