Pussycat Tribute Tournament 5
  • Pussycat Tribute Tournament 5
    Look at the thread for stats Dave.
    Might I suggest flipping the 3rd seed OOTA, cos it has a high ground clearance.
      Oh bugger...all THREE bots are after me!
      Sheesh, you people know how to drive out an american, dont you?
      Haha, jk, cant wait to see how I get owned...
        Dont worry about being attacked by the house robots, because I will be having a good go at then after pushing Warhead from the rear into Typhoon 2 once it is upto speed, then go after the house robots to push then into the pit or into Typhoon 2.
        I need to show then that Dave is back, and this time he wants the complete set of House robot deaths
          Dave Sez: A Cup of Coffee Vicar?
          STEVE SEZ:
          Heat B for everyone. At farking last.
          HEAT B
          ROUND 1
          MELEE 1
          FLIPPING HELL Vs M.O.A.B.I.E. (3) Vs THE AXE ATTAXE Vs WELL BUY YOU A NEW ONE TOMORROW, MRS BROWN!
          FROM CARTERTON, IN OXFORDSHIRE, FLIPPING HELL!
          (represented by David Weston)
          Rude though the name may be, Flipping Hells battle record is respectable indeed, with the Lord of the Ring silver medal and a place in FAR8s Semi-Finals to show for it. Now, its sights are on the PTT and therell be hell to pay for anyone in its path! A steep wedge in appearance with an elongated sloping tail, the weapon is obviously a flipper. But this rear-hinged arm operates on 1000psi pneumatics and, on a good day, can toss a fellow Heavyweight up to 25ft in the air. Hellish indeed. And even if you do survive a single launch from this beast, youll have a hard time exacting revenge. Speeds of up to 18mph and top manouverability from its four Razer-esque wheels will make sure of that. Along with this, the 6 mil aluminium/steel alloy should allow some decent protection and the low 4mm ground clearance will come in handy against fellow flippers. But despite this, control could end up an issue with such high speeds and if that arm runs out of gas, Flipping Hell! wont be the only expletive Dave will be yelling.
          IN PTT1: did not compete
          IN PTT2: did not compete
          IN PTT3: did not compete
          IN PTT4: did not compete
          FROM KILKIVAN, IN AUSTRALIA, AND SEEDED NO.3, M.O.A.B.I.E.!
          (represented by Aaron Knight)
          Mother of All Bricks returns...Inevitably Evolved! One of the biggest surprises of last year after reaching the Top 3, Aarons rammer has undergone several major changes since last it fought here. Though still an invertible box, the shuffling pads have been replaced by four titanium wheels with urethane rubber and NIB magnets. Beats just using sellotape, I suppose. As if that werent enough, the 2 x LEM-200D motors can produce 15mph top speeds and approximately 52hp each at maximum capacity! And you thought Storm was a powerful pusher! Also a change from last year is the front lifting wedge replacing the drill, to raise opponents off the ground before bludgeoning their brains out. All this and a 6 mil Hardox 450 shell to boot! But as ever, there are catches. The invertible frame leaves the wheels open to attack and with the sides seemingly skirtless, a well-driven flipper could give Mother of All Bricks the mother of all headaches!
          IN PTT4 (as Mother of All Bricks 2): took the bronze from Son of Ripper 3.5, having ploughed through the likes of Beta, The Disc 5 and Tengu VI to get there
          FROM OTTOWA, IN CANADA, THE AXE ATTAXE!
          (represented by Matty McDonald)
          With former champions Beta and The Business Ends no longer in action, the title of PTT Axe King is now wide open - enter our first challenger! The Axe Attaxe is one of Matty McDs newest creations and shows us just how far hes come since his days on the Panic Attack Community. Wedge-shaped and tipping the scales at 100kg, the hammer mounted on this newcomer is powered by a 60v Etek motor - giving nearly 3kJ of force per shot and equal strength to that of good ol Beta! The point of the axe has also been sharpened to a menacing thin point to ease in penetration, so avoiding the front is a wise move to all our contenders. Along with such a vicious weapon, the newbie also sports excellent manoueverability on its two wheels and the Lexan armouring is a real pain to puncture at up to 13mm thick. However, the 15mph top speeds do hinder the robots control and traction isnt too much of a strong point. And with pushers appearing everywhere these days, The Axe Attaxe could end up facing the chop!
          FROM LARGS, IN AYRSHIRE, WELL BUY YOU A NEW ONE TOMORROW, MRS BROWN!
          (represented by Scott Anderson and clone :wink
          Having drowned their sorrows in their local boozer since their performance last year, the descendents of You. Outside. Now! have sobered up enough to come back for another crack at the title. Both halves of this clusterbot remain much the same as the previous War - two invertible box-wedges with a linear-actuated lifting arm apiece. However, these Middleweights are a lot tougher than their size suggests. Their sellotaped four wheels provide them with a good deal of grip on the arena floor and their 10mm 2014A aluminium shell should be able to take a good pounding. Combined with speeds of 15mph, the twins are both well-protected and well hard to catch. But if one gets overturned, its wedge instantly becomes useless and with each being half the weight of nearly all our other competitors, sheer size could be a problem. Will the next thing the Mrs Brown twins end up buying be their own coffins?
          IN PTT4: went out in Round 1 after Soz, Disc-onnected...Again threw one half clean out the ring!
          House Robots - Michael Pliers and Scream
          Roboteers stand by...
          3...2...1...
          ACTIVATE!!!!!!!!!!
          Quickest off the mark today is Flipping Hell. Just as the first clusterbot of the evening splits up, Dave Ws machine dashes straight for them, managing a glancing blow on Mrs Brown 1! As the Middleweight responds to this with a little shunt on the flippers side, Mrs B2 engages in a little tango with the Axe Attaxe! And where is Mother of All Bricks in all this? Where else - dashing up to hit the Void Activator! Just as both parts of the Caledonian cluster give their rivals some hard nudges, that very familiar siren starts up and signals for M.O.A.B.I.E. to come careering back down the ring! With a mighty din, our No.3 seed crashes into the side of Flipping Hell and knocks it away from Mrs B1! However, Dave doesnt feel too happy about that and swings his creations sloped front around and underneath the rammers side! Immediately, Aaron starts to drive off, but doesnt prove quite fast enough as the PTT4 bronze medallist rockets nearly 9ft skyward! Meanwhile, the Mrs Brown twins are having a much better time! Mrs B1 has managed a few more glancing blows on Flipping Hell, while Mrs B2 has slipped straight under the Axe Attaxe and slammed it into the nearest wall! However, just as the second Middleweight begins lifting the newbie off the ground, M.O.A.B.I.E. thunders back over and smashes into both competitors! Acting fast, Mattys machine twirls around and brings the great hammer down on Mrs B2s lid! With a dint now left in the aluminium, Scotty the 2nd tries to run away, but the newcomer has slid right underneath and clamped onto it with a second blow! Desperately, the little Stormish bot attempts escape, but thats some hold the Axe Attaxe has on it! While M.O.A.B.I.E. backs off for a little ramming space, Matty jams his thumb forward on his main control stick and shoves Part 2 of the clusterbot over towards the opened Void! However, Scotty Zwei isnt making it easy for him - violent jerks from the smaller machine are causing great disruption on the journey! Enter Aaron and his bronze medallist to sort things out by smashing both of them aside with the front wedge! As the Axe Attaxe is sent into a spin, the No.3 seed darts underneath Mrs B2 and has it shoved across the arena and into the Void much to everyones confusion! On seeing this, the original Scotty groans and ends the rather boring dance with Flipping Hell abruptly by sending Part 1 away and driving it down the hole after its companion! Well, with the 50% rule present as ever, a potential OOTA would just be more needless pain, no?
          Mrs Broon falls tae her doom! Proof that two heeds isnae always better than wan, know what ahm sayin, Sonny Jim?
          Poor Scots aside, back to the fight! Infuriated by the demise of its dance partner, Flipping Hell charges straight for M.O.A.B.I.E. and clashes head-on in the middle of the ring! On this occasion, the veterans lifty wedge proves just the lower and instantly shoves Daves destroyer across the arena into the right-hand wall! As though in frustration, the hellish flipper snaps open in a cloud of gas, just as the No.3 seed backs off for another slam! Quick as can be, Mr Weston takes advantage of this moment of freedom to zip back over to the arena centre...right into the Axe Attaxe! Instantly, Matty slides under Flipping Hell and clamps onto the aluminium and steel shell with its pointy weapon! However, just as the hammerbot makes another attempt for the Void, Dave notices that the axe shaft is stretching right over the flipping arm. Mr Weston fires...and throws the fellow newbie over onto its back after an eye-popping 7ft flip! Unfortunately, a further attack is prevented as M.O.A.B.I.E. returns to the scene and gets back under Flipping Hells side! Dave tries to counteract this...but its hard to see how he can do this! Before a plan can spring up in his head, the No.3 seed has dashed across the Warzone and promptly deposited the Lord of the Rings Finalist on top of Mrs Brown and friend!
          CEASE!!!!!
          Flipping Hell is in flippin big trouble! Back to the land of fire, brimstone and carbon dioxide for you!
          M.O.A.B.I.E (3) AND THE AXE ATTAXE GO THROUGH TO ROUND 2!!!
          HEAT B
          ROUND 1
          MELEE 2
          PUSH-ISH FUNDAMENTAL Vs THE ROBOTNIK TWINS Vs TYPHOON 2 Vs WARHEAD (30)
          FROM TIDWORTH, IN HAMPSHIRE, PUSH-ISH FUNDAMENTAL!
          (represented by David Sheppard)
          This robot has undergone many different forms in its lifetime - David Sheppard, Hurricane, Push-ish and now Push-ish Fundamental - and has a relatively mixed battle record. But Davey Boy may finally have gotten this series just right with this latest incarnation. Wedge-shaped with a scooped rear, the main weapon is sheer brute force. Powered by an LEM-130 at 48v, this machine is capable of speeds of 20mph in high gear and the torque it produces is quite splendorous. Theres not too much in the way of weaponry, but a lifting plate on both top and bottom will happily raise a fellow Heavyweights wheels off the ground before ramming commences and removable skirts are also available for facing flippers. Along with this, the shell is strong enough with 4mm Hardox n 8mm RSP-707 TG and the invertible frame will be a bother for the tossbots...but the four wheels mounted on the same axis provide average manouverability and the wheels are also vulnerable to axes and the like. Will Push-ish end up being shoved aside?
          IN PTT4 (as Hurricane 2): was ejected from the ring by SpinVerter 3 in Round 1
          FROM OSWEGO, IN NEW YORK, THE ROBOTNIK TWINS!
          (represented by Anthony Politzi and guest driver Dr Ivo Robotnik :wink
          Trying and failing to catch a hedgehog for 14 years could get anyone depressed. So what better way to perk up than by creating mindless battle droids and destroying them for kicks? Works for us. Yes, bursting from your old Mega Drives come the Robotnik Twins, bent on forum domination and the aquisition of eggs. Unlike most clusterbots, both parts are very different - the Emerald Hill Driller Car and the classic Egg-o-Matic. Part 1 sees the Doc in a four-wheeled box with a rollcage and an enormous front 900rpm drill, while Part 2 is a domed full-body spinner, equipped with srimech arm and can reach speeds of 1000rpm. What less did you expect from Mobius No.1 mad scientist? As well as their varied arsenal of weaponry, the Twins also have 18mph top speeds each and with a blend of titanium and Hardox armour, these two Middleweights could give even Metal Sonic a run for its money. However, the Driller Cars large tyres are completely exposed to all forms of attack and being so fast, control will be a major problem. Whatever happens, though, we can be sure that the Robotnik Twins will definately cause a little chaos.
          FROM EDINBURGH, TYPHOON 2!
          (represented by Corporal Gary Cairns and Andy Jackson)
          AttennnnnSHUN! Despite a disappointing performance last year, reigning Robot Wars champion Typhoon is back on parade to try its hand at the crown for a second time. Just like before, its still the lethal lampshade weve all come to know and fear. Coated in red, white and blue, the main weapon is...erm...itself. The shell spins at speeds of up to 1200rpm and when it reaches that velocity, we all know what the four teeth attached are capable of. Ask Hammerhead, Iron Awe and Atomic for more information. Also, superb speed and manouverability allow the RW king to flee from trouble in an instant and once those blades get going, its very hard to knock off-balance thanks to the laws of gyroscopics n such. Unfortunately, though, the machine is pretty useless if the shell grinds to a halt and with no proper self-righter, Typhoon and the Air Cadets could end up being stripped of their stripes once again.
          IN PTT4: was overturned by Gravity in Round 1
          FROM BOURNEMOUTH, AND SEEDED NO.30, WARHEAD!
          (represented by Simon Scott and Rich Southworth)
          Its da bomb, bee-yatch! Back for a fourth War with a decent enough record behind it, Warhead returns to do what all good WMD do and have a blast! Still unchanged since it first competed, this rounded box-type thing is armed with a horrible spinning dome mounted on its front wedge. Fixed onto a forward-hinged plate, this flywheel can slice at more angles than the mind can comfortably cope with. And thats not the only nifty feature the brother of Razer has - the bull horn arms on either side act as self-righters and a means to keep the machine balanced. As for the articulating tail? ...well, it just rules, OK? As ever, the shell on this bizarre-looking bot will take plenty of good hits and steady speeds mean that the team will rarely lose control. However, it does result in the seed being pretty sluggish and with the ground clearance as high as it ever was, a good flip could blow Warheads chances to pieces.
          IN PTT2: lost to Pure Evil on a 31-23 judges decision in its Heat Final
          IN PTT3: dumped into the Pit in Round 2 by Electro
          IN PTT4: was flicked into the Pit by Son of Ripper 3.5 in Round 2
          House Robots - Dulcy and Uncle Sam
          3...2...1...
          ACTIVATE!!!!!!!!!!
          According to backstage gossip, it seems that the Robotnik Twins are the prime targets in this match-up. Well, youll have to catch em first, boys! Immediately breaking up, the clusterbot parts go their separate ways - the Egg-o-Matic heading down the ring to rev up with Typhoon, the Driller Car dashing up to the Void Activator! However, the little box doesnt get too far before Push-ish catches up to it with ease and slides underneath the rear end...before smashing the little chap drill-first into the Button for it! With the siren deafening us all as usual, the spinners near the bottom of the Warzone are showing less signs of action. Typhoon, the Egg-o-Matic and Warhead are all looking very apprehensive. None seem too sure what to do...at least until the reigning RW champion smashes into Tonys little Middleweight and sends it into an even bigger spin than usual! Feeling he might as well go with the flow, Simon sends Warhead too after the mini spinner, sending both machines into a twirl on impact! Desperately, Tony tries to get the shell back to maximum speed, but Typhoon simply swoops on over again and smacks off it in a brief spark shower! Deeply worried now, Mr Politzi swerves away for some space, taking another scar as Warheads dome manages to clip it! But he thinks hes got problems, thats nothing to what the Doctor is feeling right now! No matter what he does, Ivo just cant seem to get away from Push-ish, who has now just slammed the Driller Car into the rings topmost flywheel! Front cone twirling menacingly, the Middleweight hurridly adjusts its position and charges at the veteran head-on! Robotniks combatant reaches its opponent...and ends up shooting right over its wedged body and onto its back! Thankfully, the rollcage kicks in and the Driller Car tumbles back upright, but Push-ish just glides underneath the high sides just as it starts moving again! As Ivos entrant is shoved effortlessly down the ring, it passes by its brother, whos having equally little luck! Having only just spun up again a few seconds ago, Typhoon has caught up and clobbered it fiercely with its own claws! And matters arent helped when Warhead catches up and manages to nibble part of Tonys little machines spinning shell before being flung away! However, it seems that the duos suffering wont last much longer...as Push-ishs journey is completed and the Driller Car is dumped unceremoniously into the Void! Ton and the Doc seem to be putting their situation across accurately as the Egg-o-Matics controls are put down...I HATE THAT WEDGEBOT!
          The Robotnik Twins go the way of Segas consoles! Is there a doctor in the house?
          And so, were down from five to three...but for how much longer? Barely seconds after the Robotniks demise, Typhoon immediately smashes into Warheads side! Richie cranks the dome up to full speed as Simon twirls it around, but the No.30 seed proves too slow and ends up taking another bash from the reigning RW champ! Indeed, theres barely time to recover before Push-ish makes the scene and slides under the Battlebots rear tail! It seems as though the vapourbot and the Scotsmen have a little alliance going on here! Angered at this deception, Simon and Southworth try to escape, but Dave simply activates his lifters and slowly raises Warheads wheels off the ground! Anxiously, Richie notices that Typhoon is backing off. Both quickly find out why. As though on a caffine rush, Push-ish rockets towards the Void corner and sends our No.30 seed cascading down into the pitch-black hole therein!
          CEASE!!!!!
          Both our survivors twirl in victory having lived through todays four pittings, but now, they seem to have their sights on new targets! Heroically, Push-ish dashes to Uncle Sams CPZ opposite the Void...but before it even makes it halfway there, the hefty new House Robot flashes out and ploughs its scoop right under our wedged veteran! Dave attempts to shove back, but nobodys pushier than an angry American! In a blur of red, white n blue, Sam streaks across the ring and gives Push-ish a taste of its own medicine by slamming it down the Void as well! Gary and Andy consider rushing to its aid, to continue the rebellion in Dave Sheppards honour...but think better of it and decide to just let Typhoon twirl around a little instead.
          CEASE...AGAIN!!!!!
          Warhead proves to be a real dud, as our 30th seeds quest for glory blows up in its face!
          PUSH-ISH FUNDAMENTAL AND TYPHOON 2 GO THROUGH TO ROUND 2!!!
            LATER ON:
            HEAT B
            ROUND 2
            M.O.A.B.I.E. (3) VS Push-ish Fundamental
            The Axe Attaxe VS Typhoon 2
            Thoughts? Tactics? Somehow enjoy the delayed and slightly iffy IMO Round 1?
            Thank you
              Damn you wee house robot, you win this time, but I will be back...
              ...In round 2...
              ...woot...
              ...*looks at draw*...
              ...Bugger...
              ..Plan in the morning
                Gimme a O! Gimme a W! GImme a N! Gimme a E! Gimme a D!
                Whats that spell?
                OWNED!
                That word describes my first match of PTT.
                Cant say I dont disagree wit the result though, great job Steve. Heres hoping I have better luck later...
                  TACTICS:
                  Hmm, Typhoon 2 will be an interesting machine to battle, I do believe I can attack it with the axe, hopefully damaging the FBS, and hopefully stopping the spin. If I can do so, I can easily push it around, and no matter what I do, try and get it down the pit as quickly as possible.
                    I predict Push-Ish to pull off a shock and pit MOABIE, and Typhoon 2 to beat The Axe Attaxe on a judges decision.
                      My first proper Knockout Tactics of the war
                      (MOABIE - MO
                      Push-ish - PF)
                      Speed - 8/20 mph for PF, 15 for MO.
                      Drive - ~13 horsepower for PF, 63!! horsepower for MO (400 * 59.2 * 2 / 750)
                      Wheels - 2 large rollers on shared axle for PF, 4 standard pushy wheels on MO.
                      Right, I have been practising driving a 2 wheel drive shared axle off-road thingie, and it is takes some time to learn how to turn with low effect.
                      I believe I have the lower front end, but if we meet head on, it will be funny to see, because if I go up, I still have both wheels planted on the ground due to the rear wedge thingie, but if I get under MO, I will lift its front wheels off the ground, and reduce traction. In a torque vs. torque match, I have a feeling that due to my wheels and low gearing I could outpush it, but lets not try to get into a position like that.
                      My main aim for the match will be, using my extra speed, get around the sides of MO, with no skirts said in the stats, I should get under. Once under, push on, getting under some more, lift the front wedge up, and take directly towards pit release to dump it into the pit.
                      Good Luck Aaron
                        Okay, lets crunch some numbers.....
                        PF has roughly 465mm diameter wheel, megaly big.... It needs this size of wheel to do 8MPH with 48:1 gearing with a LEM130 @48v. Also, to achieve 20mph, it will be geared 19.5:1. Going by the EDT Simulator, PF has the following specs:
                        Low Gear: 8MPH
                        1380Nm Torque @ Axle
                        5960N Stall Torque
                        Max. Tractive Force 392N @ 28.5 Amps
                        High Gear: 20MPH
                        563Nm Torque @ Axle
                        2420N Stall Torque
                        Max. Tractive Force 392N @ 70 Amps
                        MOABIE on the other hand, has a specs going a lot higher in its favour:
                        Low Gear: 15MPH
                        1450Nm @ Axle
                        13500N Stall Torque
                        Max. Tractive Force 785N @ 86.7Amps
                        To summarise it up in simple, MOABIEs got enough torque and traction to push PF around with only two wheels on the floor.
                        Now, enough maths. My tactics are basic. My acceleration and control will be my greatest weapon. PFs acceleration is poor, Ill just dart around his sides and push my way under. Ill use the actuated fron end to apply more weight onto the arena floor by lifting the front wheels up just a fraction when Im ready to push.
                        Once under, ram straight into the wall, stack him against the wall and pin him there for the legal amount of time, knocking him off the wall and pushing him into another wall, stacking him and then pinning him again. The pinning tactic will hopefully gain me points with the judges in tactics, agression and control. If the pit comes into play, Ill put him down it first and take no chances!
                        Good Luck Dave
                          Spin up and splatter. If the axe tries to hit the shell, Ill rip the thing straight off!
                            ^^^And people moan when I go into RP mode^^^
                            Its only a game aaron, no need to bring out all the techinal bits.
                            Im faster and have better acceleration. Aaron claims to have a front wedge, but he doesnt state a ground clearance, so the wedge doesnt touch the ground. Neither do the wheels because it has 6mm Hardox Armour All round ...
                            ...Ok Im being picky, so I will stop.
                            Tactics
                            Wear the skirts which should prevent Moab getting underneath cos it doesnt state in the stats that the wedge is zero ground clearance, so if its not in the stats, then its not on the robot.
                            At the start, using my better speed and acceleration, dart around sides, get under, lift, open pit, dump in pit, (drive in pit)
                            ...nothing fancy, just basic tactics for a simple bot.
                            *Goes off to do full Roleplays for ARCA*
                              ...Whats wrong with you guys just saying I can out-push him?
                              *head hurts*
                                *Hands Frank a cup of coffee*
                                It will help with your head hurting
