Pussycat Tribute Tournament 5
  • Pussycat Tribute Tournament 5
    woohoo, Steves back behind his writers desk
    Hell Machine VS T.I.R.T.A.S.M. (13)
    Go Hell Machine! (for its build by my teammate Dave Weston ), but really, I think this axe/flipper combo has what it takes to take out T.I.R.T.A.S.M.
    Another Twist of Fate VS Kali
    Given Kalis hard front and AToFs lack of a decent srimech, Alex should be able to pull this off
    (Message edited by MajinB on December 04, 2005)
      I will use set up 5 the hardox and rubber scoop. I will ram Hell Machine around and try and pit it
        Good to see you back, Steven! I pick TIRTASM and Kali to go through.
          Avoid the front and try to hit it in the sides. Would give more info, but Im still in shock at getting to the second round in the first place.
            Ok, Tornado type robot, Nice
            Hell Machine is great with box bots. Scoop it up via the sides and back and axe it until it dies, failing that, stack it against the nearest wall with bthe rear arm.
              Two Rounds within a week? Who in da zone?
              HEAT G
              ROUND 2
              SEMI-FINAL 1
              HELL MACHINE Vs T.I.R.T.A.S.M. (13)
              Today, Marty will use the concave-curving horizontal scoop with added flail. This is made of 10mm Hardox and rubber, designed to tackle the most horrible full-body spinners...so why hes using it here is anybodys guess.
              House Robots - Scarlek and Mr Hyde
              Roboteers stand by...
              3...2...1...
              ACTIVATE!!!!!!!!!!
              Wanting this battle over with as quickly as possible, T.I.R.T.A.S.M. shoots out of its spotlight and careers up the arena into the Void Activator! The siren once again starts pounding into the ears of our poor audience as Hell Machine catches up to the reversing No.13 seed and scrapes underneath the rear! Before Marty gets a chance to blink let along drive off, the NSBFL 3 champions axe snaps down onto the titanium top! Now, the duo are locked together in a pushing match, the two competitors surging back and forth as one attempts to dominate the other! Finally, a particularly hard thrust from T.I.R.T.A.S.M. allows it to break free of the axes grip and dart around to Hell Machines side! As Dave tries to turn around and block this attack, Marty slams his thumb down on the accelerator and shoves the FAR New Blood silver medallist right across the arena into Mr Hydes corner! Spotting the competing machines approach, the Victorian House Robot waits with claws wide open and allows Hell Machine to be slammed into his greasy clutches! However, his crushing arms prove to be too slow on this occasion, as Dave suddenly darts out the Patrol Area, around to T.I.R.T.A.S.M.s side and pins it side-on into the wall just behind them! Not wasting a moment, Mr Weston starts bashing his finger down on his Fire! button and starts hammering down on our No.13 seeds shell! Marty, meanwhile, is desperately trying to wriggle his robot free and as if to make things worse, Mr Hyde trundles to the very edge of his corner and gets a few blows in on the veteran itself! As Daves destroyer backs off for another charge on its rival, the PTT4 Semi-Finalist seizes his chance and shoots away from the wall after Hell Machine! For a moment, the two simply circle one another, until T.I.R.T.A.S.M. proves just the quicker and gets back around to the NSBFL 3 winners side! Just squeezing its hardox n rubber scoop under the 2mm ground clearance, Mr Forsyth goes full throttle and shoves the PTT newbie right across the warzone and into the opposite wall! Davey tries to get back to the main arena for some space, but our No.13 seed simply tries to stop this by dishing out a few more simple rams! Getting his timing right, the Oxfordshire lad waits for the veteran to back off again and dashes away from the fence to freedom! Our two competitors start off their little dance with each other again, which is halted barely a few seconds in after T.I.R.T.A.S.M. knocks into its partner! Word of advice, Marty - dont develop two left feet when literally dancing with the Devil. To exact revenge, Hell Machine manouevres itself back under the No.13 seeds side and clamps down on the lid again with the hammer! That top panel has quite a lot of good dents in it by now, but thats the least of Martyns worries - Dave has just started shoving him in the direction of the Void! Desperately, Mr Forsyth tries to jerk himself free of the axes grip and although he does have the superior pushing power (but not by too much), Hell Machines scoop is far enough underneath it to cut that down to size! After much struggling and jolting, T.I.R.T.A.S.M. is finally dragged to the arena precipice and unceremoniously dumped as Davey Boy retracts his hammer!
              CEASE!!!!!
              T.I.R.T.A.S.M. goes A.W.O.L., as our 13th seeds plans for conquest end up D.O.A.!
              HELL MACHINE GOES THROUGH TO ROUND 3!!!
              HEAT G
              ROUND 2
              SEMI-FINAL 2
              ANOTHER TWIST OF FATE Vs KALI
              House Robots - Scream and Uncle Sam
              3...2...1...
              ACTIVATE!!!!!!!!!!
              With the sound of the buzzer, Another Twist of Fate begins revving up that corkscrew shell and nips into the arena centre! Frank carefully tries aiming his creation for Kalis side, but Alexs latest monster proves far too quick to be caught and charges straight into the unusual spinner with a horrible clatter! In a shower of sparks, the duo bounce away from each other! The Stormish newcomer has suffered some slight scarring to its polycarb and ABC armour, but is otherwise sound as a pound! In comparison, Another Twist of Fate has fared worse, with the impact causing the shell to snap to a halt! Immediately, Frank gets the spinner slowly going again and tries to get some space to rev up properly, but Alex isnt having any of it! A burst of speed sees Kali crash back into the Corkscrew/Typhoon hybrid and not only stops the shell again, but gets right under its 10mm ground clearance! Not daring to stop, Alex starts pushing Another Twist of Fate across the ring and just when it looks like theyre going to crash into the nearest barrier, Mr Holt activates his flipping arm and successfully rolls the revolving robot onto its side! In a panic, Frank starts the shell up again, hoping to pull a Ziggo and spin himself upright again...however, the corkscrewed body shape doesnt so much self-right it as let it slowly trundle around in a circle like a wounded Blizzard! Wanting to put the freakish spinner out of its misery, the Grim Beeper swoops across the arena and kicks off the countdown...
              1...2...3...4...5...6...7...8...9...10!!!!!!!!!!
              CEASE!!!!!
              Another Twist of Fate really should have seen that result coming!
              KALI GOES THROUGH TO ROUND 3!!!
                HEAT G - THE STORY SO FAR:
                ROUND 1
                KALI & T.I.R.T.A.S.M. (13) won their battle after the rammers pitted two members of 4 Swords and Alexs machine pitted Hypno Disc
                ANOTHER TWIST OF FATE & HELL MACHINE won their battle after Frank knocked out No Close Shave 3 and Dave pitted No.20 seed Supreme Glory Gamma
                ROUND 2
                HELL MACHINE survived a ramming match with T.I.R.T.A.S.M. (13) after grappling and pitting it
                KALI flipped over Another Twist of Fate
                LATER ON:
                HEAT G
                ROUND 3
                HELL MACHINE Vs KALI
                Thoughts? Tactics? Enjoy Round 2?
                Thank you
                  I thoroughly enjoyed R2 !
                  Ok, Kali, another Storm clone but with pneumatics. I dunno if it has skirts, so if not, Ill try and out-maneuver it and scoop it up so I can attack the wheels with the axe. Oh, and avoid the flipper if I can, but I can self right relatively easy, but still, Ill avoid it if I can help it.
                    Im going to guess kali to win.
                      I honoustly think Hell Machine can do enough hammering to take Kali out, or do some nice flips or so...
                      of course Im not completely unbiased since Dave and I are teammates in PTT...
                      and I do agree with Dave, Hell Machine vs T.I.R.T.A.S.M. was awesome
                        Three fights in a week? Praise da Lord, Im on fy-aaah!
                        HEAT G
                        ROUND 3
                        HEAT FINAL
                        House Robots - Shellraiser and The Kaiser Chief
                        3...2...1...
                        ACTIVATE!!!!!!!!!!
                        Kali gets the slightly quicker start today and crashes head-on with Hell Machine in the middle of the ring! The duo almost seem to rebound off each other upon impact, but its Daves creation that recovers first and powers into its rivals side before it can get away! Scraping under the barely existant ground clearance with its scoop, the NSBFL 3 champion activates its axe and puts a small dint into the fellow newcomers top! However, as the hammer is withdrawn for a second shot, Kali manages to wriggle free and begins encircling Hell Machine like a buzzard over fresh meat! The Stormish competitor proves too fast for Dave to keep facing it and charges into the highly experienced vapourbots side! Now, its Alexs turn to get under its flaming foes side as Kali effortlessly shoves the NSBFL 3 king right the way up the arena and smacks it into the Void Activator! Mr Holts machine backs off for another ram, but in doing so allows Hell Machine to make a break back into the centre of the warzone! The brutal box-wedge follows and the duo engage in a few fancy manouevres before Kali bashes into its opponents side once again and slams it into the closest wall! With his flipper now well underneath his pinned nemesis, Alex activates the arm...but the wall prevents Daves creation from being completely inverted and bounces back onto its wheels! Kali backs off to retract the flipper, but allows Hell Machine to escape as a result! The two competitors briefly start dancing around with each other once again near the arena centre until Mr Weston swerves round into the Stormish newcomers side and scrapes back underneath it! In an instant, the axe comes crashing down and pops another little dint into the lid of the MRW5 Semi-Finalist! A short shoving match takes place between the duo and a few moments later, Kali has managed to wriggle free of its opponents grasp! With a burst of speed, Alexs creation tries dashing around to Hell Machines side again, but it seems Dave was prepared for this wee manouevre! Almost as quickly, the NSBFL 3 champion twirls back underneath the fellow newcomer and brings the mighty axe down on the polycarb n ABC shell a second time! However, as the duo heave and ho in the middle of the ring, Hell Machines axe starts losing its grip on Kalis top...and slips down into one of the wheel houses instead! With a powerful tug, Mr Westons more experienced robot begins dragging its struggling foe down towards the Void! Alex doesnt want to end up there...or does he? Statistically with the stronger pushing power, the Stormish entrant gets a burst of speed and starts dragging the NSBFL 3 king down to the Void instead! The tables have turned, but not for very long! As the purple-and-yellow hole gets nearer, Hell Machines axe is finally shaken out of Kalis wheel housing and Dave is able to jerk out of harms way with feet to spare! Enraged, Alex twirls his successful newbie around to finish what it started, but Mr Weston proves just the more manouevrable this time and scrapes back under his rivals side! The hammer gets a hold on Kali once more and a quick thrust forward sends the MRW5 Semi-Finalist tumbling down and out of its first (and maybe last) PTT!
                        CEASE!!!!!
                        Kalis performance was nothing short of blasphemous! Godawful, even!
                        HELL MACHINE GOES THROUGH TO THE SERIES SEMI-FINALS!!!
                        Congratulations to David Weston!
                          LATER ON:
                          HEAT H
                          ROUND 1
                          Beavis and Bothead VS Crash Bandibot 2 VS F.P. 4.0 (15) VS Razer
                          Atomic VS Automatic Schmuck VS Back to Rock VS King Black Panther (1
                          Thoughts? Tactics? Enjoy Round 3?
                          Thank you
                            Beavis and Bot-Head will, uh...TRY to pit Crash Bandi-Bot and not get COMPLETLY destroyed by Forcepower and Razer.
                            After the fight which ill proboblay lose, drive them around various places with recordings of their infamous laughs taped to them somewhere. If you cant beat em, at least annoy em quite a bit. :P I dont ever add silly tactics that wont matter like that, but I just have to for their first fight.
                              Ah, good ol PTT5, good to see that Ive been able to at least win a fight here.
                              Anyways, what are the stats for King Black Panther?
                                and dont forget to mention Heat B
                                anyway, in Heat D, current Spanish Inquisition Champion () Back to Rock will play it savely and go for a quick pitting of Atomic, ramming its sides
