NSBFLX-2
  • #46
    NSBFLX-2
    Ill get Chalkie with scaramanga
    • #47
      NSBFLX-2
      I will get son of ripper with disco boogie
      • #48
        NSBFLX-2
        New Blood - Will come up with something soon
        TYOM - http://teamcode14.proboards24.com/in...051920GigaByte
        • #49
          NSBFLX-2
          Cheers Anthony. Now I just need to know which 5 weapons he intends to use.
          By the way, disregard the awaiting confirmation for Psycho Cyan in Get Him, I jus forgot to delete it in a copy and paste...
          • #50
            NSBFLX-2
            Orka MK4 will get SOR.
            Stas for all robots soon.
            • #51
              NSBFLX-2
              Mr. Slave to get SOR.
              • #52
                NSBFLX-2
                Ooh, Id love to fight CDM in a grude match, show Steve how to make a good crusher for once. :P
                • #53
                  NSBFLX-2
                  Get Chalkie
                  Scaramanga - Alex
                  Get Baldur
                  Get Psycho Cyan
                  Get Son of Ripper
                  Disco Boogie - Martyn
                  Orka MK. 4 - Chris M(big surprise there )
                  Mr. Slave - Anthony
                  Entries for Son of Ripper closed.
                  • #54
                    NSBFLX-2
                    I thought a lot might want to go after SOR, and I thought I might see Chris there too.
                    Just to give yall a chance, Im gonna enter http://teamcode14.proboards24.com/in...=1103744395SOR
                    • #55
                      NSBFLX-2
                      I have decided that Manic Monsoon shall go after Baldur!
                      Weight: 100kg
                      Armour: 5mm Hardox all over.
                      Speed: Roughly 28mph
                      Shape: Box wedge with side skirts and rounded back.
                      Weapon 1: A linear actuator powered lifter running by a 4 bar system at 24v. This can lift 200kg easily.
                      Weapon 2: A small strip of Grade 5 Titanium on the front wedge, which gives 0mm ground clearance.
                      Strengths: Powerful drive and good strong weapon
                      Weaknesses: A bit too fast and hard to control when at full speed.
                      Ground Clearance: 0mm on front and sides, 1cm at back.
                      Srimech: Invertible, but can self right using the lifter if wanted to.
                      Notes: The robot is powered by 2 B42-500 MagMotors running at 60v. This gives Monsoon approx 60HP! The robot has a total of 6 wheels, 3 on each side. Each side is linked together by a set of heavy duty belts, giving 0m turning circle and the manoeuvrability of a 2 wheeled bot, and each wheel is coated in Vulcalon. The front wedge is angled at 42.5 degrees, meaning that it is not too steep or too shallow. The lifting arm is powered by a S28-150 MagMotor, and is made from 7075 Aluminium. The lifter itself can lift a total of 200kg, and can self right the robot if needs be. The side skirts are made from 4mm Titanium and are hinged.
                      Stats for my New Blood and TYOM entry shall be up Friday Night.
                      • #56
                        NSBFLX-2
                        ^ Just a tad overweight...
                        (eg. 25kg)
                        • #57
                          NSBFLX-2
                          Funny how no-one else believes so, isnt it, Tom?
                          My New Blood and TYOM entry is below:
                          Name: Pure Evil: Revenge of the Disc
                          Weight: 100kg
                          Armour: 7mm Hardox ring spinner and 4mm Titanium flipper/wedge.
                          Speed: 8mph
                          Shape: It is a ring spinner with a front wedge.
                          Weapon 1: The main body is a ring spinner made from 7mm Hardox, with Titanium teeth all over it. It is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. The disc weighs a total of 38kg.
                          Weapon 2: A spinning kinetic powered flipper, based on Team Whyachi€™s €œWarrior SKF€. It uses the kinetic energy from the disc to power the flipper, meaning it can flip with a total of 298KJ of energy.
                          Strengths: Unique and powerful weaponry. Good control.
                          Weaknesses: Takes a long time to self right due to the disc needing to spin up successfully.
                          Ground Clearance: 0mm at front and sides of flipper, 5mm at back due to ring spinner.
                          Srimech: The flipper can successfully self right the robot.
                          Notes: The robot is powered by 2 800w 36v DC motors giving 8mph top speeds. The wheels are made from Vulcalon, and have screws embedded in them to help gan traction on the arena floor. The ring spinner is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. There are 15 1€ cubed Titanium teeth all over the horizontal spinner, giving it 298KJ of energy on impact. The flipper works because there is an eccentric land on top of the spinning ring. The top link connected to the flipper plate has a groove in it, when fired the top link engages with the spinner land and pulls backward flipping the plate up. At the front of the flipper there is a 4mm Titanium €œnose€ with a sharpened edge designed to get under all skirts and ground clearances. All the electrics are kept within the 1m diameter of the ring spinner.
                          • #58
                            NSBFLX-2
                            Daniel: Hardox armour and B42 drive at 60 volts, plus titanium skirts and a magmotor lifter. One of these does not belong. Unless, of course, your robot is abnormally small and efficiently compact. No dimensions, so no reason to assume it is.
                            • #59
                              NSBFLX-2
                              Reserve a spot under New Blood would you?
                              I havent a mind for any of the other stuff.
                              • #60
                                NSBFLX-2
                                Due to people not getting into the first annihilator, there will be a 2nd one. The finale of NSBFL X-2 will be a 1-1 between the two annihilator winners.
