The Norman Sheppard Tribute Tournament
  • #91
    MY four Ziggos? Youve got the wrong roboteer, Martyn!
    And besides, Ill only activate the hammer when I KNOW Ill hit you. Also if you try to avoid my charge youll lose judge points for aggression. :wink:. For another fact, Darth Dread has excellent pushing power, but (reading from your stats) The Deer is just a bit more powerful than Darth Dread, so youll have a plus side there. Meh...never mind.
    All right, no more arguments. Ive said enough, let the robots do the talking. :wink:
    Team Gore
    http://www.geocities.com/kodybluz/kodybluz2http://www.geocities.com/kodybluz/kodybluz2
    • #92
      Frank, how the HELL does a heavyweight beat four Ziggos?!
      Without too much dificulty. Ziggo is designed to slice and dice 25 Kg robots. If youre not doing much damage it doesnt matter if you have four or fourty Ziggos.
      • #93
        Robin: Attack Wedginator first . Lift it OOTA. Then the same for GigaByte.
        Starfire: Try and lift Lunch Box up, and shred its tires, maybe lift it OOTA. Watch for Bio.
        Raven: Beware of Son of Ripper, and rip Glasgow Kiss tires and axe off. That axe wont be able to do much damage to my tires.
        Beast Boy: Scottishly Fictional wont be able to push me properly thanks to my rounded bludgeons! All the same Ill attack Tsunami, because I wont able to attack Scott properly.
        Cyborg: If Axe-O-Lotl even THINKS if axing me, Ill just drag him around the arena since I have the better power. Watch out for Wedge D.
        Tazbot: Get the arm under Haka and lift him onto his back. Then push him against the wall and hold him there.
        Cant wait, Dave.
        • #94
          I like the way some people assume things like their robot is unbeatable, Power is nothing without good tyres, overwise you will spin the wheels on the smooth-ish steel floor.
          • #95
            Um, Dave, ANYTHING on steel floor isnt going to give you much traction. Its pretty hard to grip a non-grip surface.
            Good point though.
            • #96
              *Throws a spanner into the mix*
              For this series, Im not doing the heats in the normal order, so the running order of the heats will be:
              2
              15
              1
              14
              16
              5
              7
              10
              3
              13
              6
              4
              9
              8
              12
              11
              Heat 2 round 1, should be coming up 26/1/05
              • #97
                Use the Ming 2 style front to slip underneath the back of DTK, slamming him into the fence and hopefully breaking summat in the process.
                • #98
                  Oh yes, that was something I was supposed to change that Matt is using Tanto 3 not Tanto 2.
                  • #99
                    HEAT 1 / 2
                    ROUND 1
                    1) Bulldog Breed (3) VS She Loves You VS WHIRLIGIG 4.0
                    Rev up. Kill whoevers nearest. Moving on...
                    2) Dantomkia (30) VS Tanto 3 VS Twist of Fate
                    Ill take Twist of Fate to be sent tunnelling out of the contest
                    • The Norman Sheppard Tribute Tournament
                      Bulldog Breeds Tactics:
                      Go for She Loves You, the low wedge of Bulldog Breed should easily be able to get underneath She Loves You. Team up with Whirligig 4.0, so Steves machine can do some serious damage to She Loves You before I flip it out of the arena or down the pit. I shouldnt have much problem with these plans.
                        Whats Tanto 3 like then?
                        Hey... If I made the rear non spinny and fitted a device like Dantomkias tail, TOF probably would make a nice mole machine
                          http://www.tantorobot.com/tanto.htmlhttp://www.tantorobot.com/tanto.html - At the bottom.
                            OK. Now does anyone have any details about its weapons?
                              No, weve guessed
                                quote:
                                and for my realie, Ill have Hells Teeth
                                Dave, is this the Hells Teeth which was in extreme new blood?
                                If so, do you have any pictures of stats.
                                Clovers tactics
                                Gamma Trident: Attack GeForce.
                                Splitz: Take out PRPs wheels.
                                Kick in the Teeth: Get under The Deers side and chew up its tires.
                                Balderdash: Flip Firestorm over and over again.
                                She Loves You: Take out Bulldog Breed, the axe should penetrate the armor.
                                13 Black: Go for Crashing Bore, coz if I go after ArchAngel then Ill be
                                ripped to pieces.
