Velociraptor's Fanfic Tournament - Series 6!
  • #61
    Velociraptors Fanfic Tournament - Series 6!
    Update:
    Thank you VERY ****ing much to a train that never turned up, causing me to miss the coach I needed, I wont be going to the funeral. Im expecting the new processor some time around the start of next week so Ill get my stats in then.
    ...Arriva trains is a contradiction in terms
    • #62
      Ive just noticed a mistake I made when entering Ankle Biter the Second. In the dimensions section, its actually in cm, not mm as I mistakenly put. Can you keep this in mind please Rich?
      • #63
        Update the 2nd:
        Thanks to a last minute idea from mum, and about a £35 taxi ride and some very nice people in the coach company, I will be going. Stats in next Saturday hopefully.
        ...Arriva still suck.
        • #64
          Fargo suck even more frank
          • #65
            Who says WKJGW stands for anything?:wink:
            2000VP if you can guess. In fact, if I like it more than what it *doesnt* stand for, I might even change it.
            • #66
              VGER
              mass:
              Stainless Steel Frame - 20.43866 (1 cm thick predominantly, 2cm on the underbelly and parts of the lifting fork.)
              Titanium Armor - 26.14416 (top - .764 cm, bottom - .508 cm)
              Wheels - included in the Ti Armor estimate, .635 cm thick, solid, rubber treads
              S28-400 magmotors x 2 - 6.182
              S28-300 magmotor - 2.500
              Flywheel - ~10.000 kg, mostly in the teeth.
              Maxtor controller - ~1.000 kg
              EV Warrior - 1.472 kg
              Husqvarna 3120XP - 10.409
              NiMh 24v Battlepacks x 3 - 3.6
              TOTAL - 81.746 KG
              Weapon - Circular flywheel, 8.4 hp (6.2 kW), spins at 1:2 reduction for 5000 rpm. If Aarons desperate for a kJ estimate, I can give him one. Its pretty modest though. I was aiming for a weapon that wouldnt break after one hit, like many others in the tournament probably should.
              Frame - Stainless 400 Steel
              Armor - Titanium (thickness on the mass chart)
              Srimech - Lifting plate can self-right the robot in any position in 1-2 flips. NOT INVERTIBLE. Expect a motion diagram of the robot self-righting on my avatar soon.
              Wheels - 15 mph, like 90% of the other robots youll ever see. 2 S24 mags power it at 24 volts. 60-amp continuous cell discharge, which is pretty good for single packs weighing only 1.2 kg each.
              Clearance - HUGE. 6.985 cm mostly, although the wheels and the rear wedge make full contact with the ground obviously.
              Strengths -
              --Internal Combustion Engine has an EV Warrior starter motor, in case it stalls during a fight.
              --Powerful flywheel with adjustible height. Rides at 5.04 cm when level, minimum height - 3.81 cm, maximum height - 6.34, doesnt matter too much though.
              --Lifter can LIFT any ~100 kg robot, and can flip some opponents, depending on the angle I get, and the distribution of their weight.
              --Theres enough extra weight (15 kg worth) for (1) a robot trap that lengthens the rear lifter significantly (2) ablative 2024 ali armor (which either covers the wheels or the robots top), or (3), replacing the flywheel, a stainless steel scoop for the front, which Ill likely never need *glares at Aaron*
              Weaknesses -
              --Not a good pushybot.
              --Certain spinner designs will probably be able to stop it no matter what (Im thinking cage spinners on this one).
              --Top Heavy to a large extent, though its wide enough and distributed enough to not affect turning or driving, itll usually land upside-down if flipped.
              I will add ABR when Im done with it. I had to rebuild both from scratch obviously, but I think the new versions are far supurior to what Id been using.
              • #67
                Ill have a go Matty-
                W.K.J.G.W.-
                Windiest. Killer. Just. Got. Windier.
                • #68
                  What Kind of Jackass Got Walloped?
                  • #69
                    Worse Train Company ...
                    ... South West Trains, not for the delays, but the cost of travel.
                    To get from where I live (just outside Andover, Hants) to London Waterloo, it costs £24, no wonder why so many people take the car.
                    • #70
                      Is that VGer on your profile, Nick? And I still need six other robots from you.
                      1 more space left if Alex and Tom B enter! Still awaiting stats from Scott, Frank (hes explained why he hasnt given them, so no worries, Frank) and Aaron.
                      I hardly ever use trains, so I cant give much of an opinion on which company is worst.
                      • #71
                        Dave Weston? I just remembered, Mr. Brisbourne has gone on holiday in Somerset for 2 weeks, and I think, without looking at the thread, that hell be back on Thursday.
                        • #72
                          He has posted in the F1 thread.
                          • #73
                            W.K.J.G.W. =
                            Worst Kind of Joke Going Walkies
                            It took me a while to come up with this one
                            • #74
                              It took you that long to come up with THAT?!:wink:
                              Unfortunately, I have to pay up seeing as Mr. R got it bang on first time. Am I that predictable?:sad:
                              • #75
                                yes
