Velociraptors Fanfic Tournament - Series 6!
i will enter the anhiolater with panic 3 gti 2 and forklifts revenge who i would lift to replace sb iv with as it is rushed and not good thanks in advanced
Name-Forklift€™s revenge
SHAPE- Low box with rear anti self flipping wedge
COLOUR- Yellowy orange
WEIGHT- 100kg
SPEED- 18mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- 0mm at front due to flipper, 0mm at sides due to skirts 7mm with out, 0mm at rear due to wedge. The skirts are held down by torsion springs
ARMOUR- 3mm hardox
WHEELS- has 6 inner storm 2 style wheels
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it now uses a flipping arm that works much like the matadors or Toro€™s the flipper is powered by co2 on a 120mm pneumatic ram, working at 145psi, the flipper front is pretty unique as its front is like that of a fork lift (it has 2 flat bits of metal) this is welded onto the flipper, the arm can toss robots very high and if possible out of the arena. The prongs of the forklift weapon are used to get under the corners or gaps of skirts
SRIMECH- the flipper self rights the robot but because of the rear wedge thing it self rights like firestorm does i.e. the front wheels will go down first
NOTES- this is a modified version of my robot from the panic attack forum.
STRENGTHS- Power full weapon
WEAKNESSES- limited co2
i will also enter happy birthday party pooper for the chalange belt
WEIGHT- 100kg
SPEED- 18mph
TURNING CIRCLE- 0m
ARMOUR- 3mm hardox
