Well have HOH and Veg 2 in the mayhems, In-teror-fied and a football setup that will be put on WKJGW in the footy, and like Dave, reserve me a place if we can choose on fight, if not, stick in PRP.
Leprosy Infection (competes with Mega Masher 2 in football)
Orka MK3
Wreck-Tangle(Annihilator contest)
Mega Masher 2 (competes with Leprosy Infection in football)
Juggerbee 3.0 (Challenge Belt)
Die-Ceratops Invertus (Annihilator Contest)
Cholera (Not the same as Dans machine)
Tsunami 2 is Tsunami 1 as we know it, its just they previously entered the dutch games with a different version of it which was Tsunami 1. Tsunami was Tsunami 2, but known as Tsunami because they didnt want the Uk to think theyd entered before.
1) Wedge Devolution
2) Killotine: EVO
3) SD IV
4) Whirligig 4.0
5) Revenge of the Revenge of the Bludgeonator
6) Chameleon
7) The Raven Chaos 2 (RW6)
Most stats can all be found on this page (http://mattyhakaman.proboards15.com/index.cgi?board=Bravehearthttp://mattyhakaman.proboards15.com/...ard=Braveheart), but since The Raven is a newbie, those stats will posted momentarily (with thanks to Dan )
Also, please forget the scoops on SD, since they do bugger-all
ALL-STARS: Spin Dash has done the best in this contest, methinks
ANNIHILATOR: Killotine: EVO and Whirligig 4.0
FOOTY: Chameleon (with Robot The Bruce-style flaps )
CHALLENGE BELT: Wedge Devo
NAME- The Raven (HW)
SHAPE- rather low box with a front wedge and several Mute-style spikes on the sloped front & top. Think Ally Gator from RW3, but with sloped sides and back
COLOUR- black
WEIGHT- about 100kg. Hoping for a proper weight calc later
DIMENSIONS- 105cm X 75cm X 30cm (minus weapon)
SPEED- 12mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front (thanks to a small spatula ala Bigger Brother), around 7mm at either side and 3mm at the rear
ARMOUR- 5mm titanium/vanadium for the main shell, 3mm for the spikes and 1mm for the spatula
WHEELS- inside robot, 4-wheel drive
POWER- 2 X S28-400 Magmotors, running on 24v
WEAPONS- The key weapon on the Raven is a pair of vertical snipping jaws, similar to those used on Bash or Sir Killalot. However, the pincers are imbedded into the machine, so that the top part of the mouth sticks out the top of the bot ala Razer while the bottom part remains hidden inside the front wedge. The idea is that a robot is dragged onto the front wedge, they get stuck in place thanks to the spikes, and while the top jaw crunches through the top, the bottom jaw begins piercing tyres and underbellies at the same time. The jaws run on 5000psi hydraulics and are made of 4mm thick Hardox.
SRIMECH- To fly back onto its wheels, the Raven uses a top-mounted rear-hinged flap to right itself. Powered by two 2.2kg CO2 bottles and a 1.1kg buffer tank at 145psi, it can right the machine in a snap and can even double as an offensive flipper if anyone gets on top or attacks from the rear.
NOTES- flies the Scotland flag, has Nevermore written on the underbelly in deep red
STRENGTHS- sneaky weaponry, offensive srimech, good pushing power, good armouring, great control, excellent at getting under and keeping hold of other bots, quite good manoueverability
WEAKNESSES- vulnerable to flipping from the sides
Sadly, Im no good with dimensions. So I will post the robot mine are like, with exception of DCI
LEPROSY INFECTION
Weight-100 kilos
Shape-Invertable box
Robot most like-Tetanus Booster
Speed-15mph
Locomotion-4 inner wheels. Almost all wheels are solid tyres
GC-2mm
Armour-5mm bright green titanium
Weapons-Spinning drum, covered in teeth, spinning at 1000rpm
Strengths-Destructive drum
Weaknessess-Control
ORKA MK3
Weight-95kilos
Shape-Box
RML-Panzer MK3
Speed-12mph
Locomotion-6 inner-solid tyres
GC-2mm, with 0 at scoop
Armour-6mm titanium
Weapons-Electric lifting shovel at front, could lift a bus,
Srimech-A top mounted dorsal fin rights the robot either way up.
Strengths-Cant run out of CO2
Weaknessess-Hard to turn
WRECKTANGLE
Weight-100 kilos
Shape-Wide Box with rear plough and skirts
RML-Ultra Violence (from Robotica)
Speed-30mph
Locomotion-6 inner (protected by skirts), solid wheels, no tyres
GC-0 all round due to skirts
Armour-6mm titanium
Weapons-Spinning blade, like Kritical Mass, Manta or Ultra Violence. The only difference is that the blade is RECTANGULAR. The design is so it can flip bots as well as damage them. Also has a top mounted bar. The rear acts as a plough.
Srimech-The bar acts as the srimech. Its design means it CANNOT be side or back stranded
Strengths-Unique Weapon
Weaknessess-Untested
MEGA MASHER 2
Weight-100 kilos
Shape-Box Wedge
RML-Minion (only lighter)
Speed-20mph
Locomotion-4 inner, solid tyred again
GC-2mm, except at front, which is 0
Armour-5mm titanium
Weapons-The front is a wedge, and the rear has a vertical spinning disc. Also has a Minion type bar running sideways across the body.
Srimech-The robot can self-right (using the bar) and run inverted. Take your pick.
Strengths-Not scared of flippers
Weaknessess-Relativly new.
JUGGERBEE 3.0
Weight-95 kilos
Shape-Inertbale box with wedge
RML-Juggerbot 3.0
Speed-30mph
Locomotion-4 outer, protected by rims, solid tyres
GC-2mm, front is 0
Armour-7mm titanium
Weapons-The front is passive, can push twice its own weight. The rear has an electric flipper, can flip 200 kilos
Srimech-The robot runs inverted. Flipper works upside down.
Strengths-Power
Weaknessess-Will have control problems
Notes-For power, it uses the same thing Storm 2 uses.
DIE CERATOPS INVERTUS
Weight-100 kilos
Shape-Box with moveable nose cone
Dimentions-1.3m x 0.78m x 0.28m
Speed-18mph
GC-2mm, 0mm at flipper
Armour-6mm titanium
Weapons-Invertable flipper, like St Agro, or Rick. It can flip 300 kilos. The nose cone is moveable so the flipper can still work upside down.
Srimech-Robot runs inverted. See above for flipper working upside down. Bars prevent side stranding.
Strengths-Ability to work upside down and STILL be able to use its weapon
Weaknessess-Control
CHOLERA
Weight-100 kilos
RML-Big Nipper
Speed-15mph
Locomotion-Same as Big Nipper, 4 solid wheels on top, 4 more on bottom (I think)
GC-2mm
Armour-6mm blue titanium
Weapons-Big Nipper style jaw on a raising arm, like Big Nipper. It can travel through a range of 180 degrees (thats up or down), like BN.
Srimech-Robot can self-right (using arm) and run inverted. If stuck on side, it raises its arm until it topples over, then works it out from there.
Strengths-Cant be side stranded for long
Weaknessess-Hard to control
Other notes
For football, Mega Masher 2 will fit a bucket scoop with blockers on the wedge and Leprosy Infection will have a C shape running lengthways to catch the ball where the drum is normally. The disc of MM2 and the drum of LI will be turned off, but they will still push.
1. Typhoon 2
2. Happy birthday party pooper
3. Star 69
4. Disco 5
5. TIRTASM
6. SRIMECH NOT INCLUDED
7. SB IV
8. Panic 3 GTI 2
NAME- Happy birthday party pooper (previously Birthday party pooper) (ta to frank for the help he gave me with finalising this robot)
SHAPE- invertible disc (like gyrobot)
COLOUR- Blue
WEIGHT- 150kg
DIMENSIONS- 100cm diameter X 20cm height
SPEED- 10mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- its about 10mm but 3mm under the blades
ARMOUR- 6mm titanium body
MOVEMENT- it runs on 8 inner anarchy style legs.
POWER- 2 x S28-400€™s Magmotors on 24v.
WEAPONS- it has a powerful spinning shell spinning at around 1500rpm weighting around 65kg powered by 2 X LEM-130s running at 48v, it has 12 typhoon2 style teeth around the out side 4 around the bottom 4 around the middle and 4 at the top
NOTES- all components have been shock proofed with rubber around them.
STRENGTHS- very destructive weapon
WEAKNESSES- easy to push if weapon not spinning
Shape: Low Wedge
Motivation: it now uses four storm 2 style Vulcalon wheels
Speed: 12.5 Mph
Weight: 100kg
Height: 300mm to top of body, 600mm to the top of the disc
Length: 1300mm
Width: 600mm
Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction connected to two Kart Tyres.
Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
Color- the robot and skirts and flipper are blue and the disc is yellow
Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a rear 0mm skirt and has 6mm with out it. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
Shape: A low to the ground invertible box shape with a low centre of gravity
Motivation: It uses four Vulcalon wheels like those used in Storm II
Weight: Somewhere around 80kg without any set-ups
Ground Clearance: 10mm all the way around unless stated
SRIMECH: The robot can work invertible
Drive: It is driven by two LEM130 Lynch Motors on 36v powered by NiCAD battery packs giving around 18hp and a top speed of 20mph
Turning Circle: It turns on the spot using a Tornado like 4WD skid steering system
Armour: 5mm thick Grade 5 Titanium
Notes: Interchangeable body panels, all can be changed within the time limit of 20 minutes (Ta to Steve for some help )
Strength: Interchangeable weaponry speed and power
Weakness: High clearance
Set-ups:
1.0) A 15kg scoop made of 10mm thick Hardox - For use against bad pushers or any powerful spinners, also has a spinning flail like on tornado
2.0) A small vertical drum weighing around 5kg powered by a C40-500 Magmotor on 36v giving it around 6hp - For use against weak armoured robots
3.0) A pair of front forks similar to those on Panic Attack with carbon tips for scratching Titanium robots, they are powered by two Linear Actuators and can work either way up - For use against robots with high ground clearance and that have wheel slots I can slide them into
4.0) Eight carbon tipped spikes, four at the front, four at the back each places in the corner of the robot - For use against robots with thin Titanium, 2 spikes on the front and the back move in and out powered co2
5.0) A front concave curving horizontal scoop thing made of 10mm Hardox and 10mm rubber behind it for impacts, the outer armour is replaced with drilled 3mm thick Ti - For use against round robots of Full Body spinners, also to fit the active weapons rule it has a chain flail like used on tornado
6.0) Some 5mm thick Ti/V skirts hinged in the centre of the robot so they flop over if flipped - For use against flippers, it also has a front 8kg vertical drum
7.0) Some 5mm thick Ti/V skirts hinged very low to the bottom of the robot and each mounted with springs - For use against rammers
A low rear hinged arm going across the top of the robot made of drilled Grade 5 Titanium powered by a linear actuator. On the end is a small crusher also powered by a linear actuator so that it can clamp and then lift. There are also some hinged skirts around the edge of the robot making it hard to flippers to get under - For use against flippers, the idea is to stop them with the skirts and try and crush the flipper when its fired so I can mash up the electronics with the crusher and then dump them where I feel (Thanks to Steve for designing this mechanism )
NAME- SRIMECH NOT INCLUDED (previously 80kg bot tartan terror)
SHAPE- like beta
COLOR- Clear
WEIGHT- 110kg
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm under all 4 wedges/ skirts 6mm under the robot so it can still move. The skirt, bottoms of wedges are made from 3.5mm hardox, the skirts are like that of biohazard
ARMOUR- 25mm GE LexGard (same as beta)
MOVEMENT- it has 2 inner tracks
POWER- 2x LEM130 Lynch Motors on 24v
WEAPONS- none it jus uses the 4 wedges and pure ramming force
SRIMECH- is not included
NOTES- Semi finalist as tartan terror in SEKT
STRENGTHS- very low to the ground, powerful drive
WEAKNESSES- SRIMECH NOT INCLUDED
NAME- SB IV
SHAPE- Invertible wedge with a curved back
COLOR- blue
WEIGHT- 100kg
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front 0mm at the sides due to hinged skirts and 6mm at the rear to flip it self over
ARMOUR- 4mm titanium/vanadium armor
WHEELS- It has 6 inner Vulcalon
POWER- 2 S28-400 Magmotors running at 24v
WEAPONS- it has 2 flippers one on either side of the wedge both are powered by 80mm Bore ram on 1000psi, they can work separately or together normally separately
SRIMECH- invertible
STRENGTHS- Powerful flippers, low ground clearance
WEAKNESSES- easy to flip from the rear (not that it will effect it)
NAME- Star 69
SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
COLOR- yellow
WEIGHT- 100kg
SPEED- 19mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
ARMOUR- it has 4mm grade 5 titanium
MOVEMENT- it uses 6 inner storm 2 wheels
DRIVE- it uses 2 x lem 130€™s
BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots and also used for bottom teeth when flipped
SRIMECH- Invertible, points and blades stop it from sticking on side
NOTES- according to frank the name is rude, first star shaped robot
STRENGTHS- Powerful weapon and drive
WEAKNESSES- it€™s a bit random
Name- Panic 3 GTI 2 (aka panic 5) (previously panic 3 GTI)
SHAPE- Low invertible box
COLOUR- Clear
WEIGHT- 100 kg
DIMENSIONS- 65cm x 60cm x 18cm (Length x Width x Height)
SPEED- 20mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 5 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- 10 mm lexan which is over 2mm aluminium to help with impacts
MOVEMENT- panic now uses 6 vulcalon wheels to give extra pushing power
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are like those on panic attack, the forks are powered by 2 linear actuators
SRIMECH- its invertible
STRENGTHS- Low ground clearance, reliable weapon
WEAKNESSES- Innards can be seen
