crazy bots series 1 (the remake)
  • #61
    Re: crazy bots series 1 (the remake)
    Originally posted by corsair_lightning
    Um... I also have twin hardox scoops at the front and back, that give me 0 ground clearance at the front and back. Therefore, I should probably get under your sides...
    If you have 0 ground clearance at the front and back, then you won't be able to move.
    • #62
      Weapon: 2 solid Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at the front and back.
      *Cough*FAIL!!!*Cough*
      • #63
        ...and what exactly are they powered by? :P If they are not powered by anything, they will most definitely be static and will most definitely have a permanent ground clearance of 0, and you will most definitely not be able to move. :P
        • #64
          Far be it from me to defend Mark, but he is right on this rare occasion...it's perfectly feasible to just have the scoop supports moving freely on bearings, which would give you 0 ground clearance at front and back (although any major damage to the arena floor would jam the scoop against it and prevent movement in that direction, possibly restricting the robot somewhat)
          • #65
            Well he still didn't put them in the stats. How are we supposed to know that? For all we know, he just may be throwing stats together like he usually does. :P
            (this is why you are suppose to be clear in your stats, Mark)
            • #66
              I was thinking of that idea, but I really couldn't get it laid out enough to put it into the stats...
              EDIT: The stats have been fixed to more precisely detail how the scoops do what they do.
              • #67
                lian walsh: welcome back to crazy bots
                let the 4th battle BEGIN
                pod 1: kody/anarchy
                pod 2: mark/minesweeper
                3!!!!!! 2!!!!!! 1!!!!!!!
                ACTIVATE
                here we go
                minsweeper charges across the arena at anarchy and pushes anarchy from the side into the wall, now anarchy comes back for
                an attack, but minesweeper rams them again against the wall and comes in again, ooh that was close anarchy scuttling away
                just in time and minsweeper in now stuck on the arena wall and anarchy comes in with the axe again and again and again how
                is minesweeper gonna get out of this, down comes the axe again, now in comes shunt and lifts then off the wall, but not
                before shunt gives them an axe blow, now minesweeper is away and now pushes anarchy into the pit realease button and now
                minesweeper pushes anarchy into the pit, but four of anarchys legs are touching the floor and scuttles out to carry on
                minesweeper now pushing them into the wall again, anarchy gets away and hits the top of minesweeper, OUCH theres a
                massive hole in the top of minesweeper but its unshaken from the blow and comes back again and anarchy puts another hole in minesweeper
                but this time the axe is stuck in the body work of minesweeper now anarchy has got them where he wants them and nows pushes towards the
                pit and is almost in but minesweeper burns rubber and pushes back and shoves anarchy into dead metal, oh dear here comes the saw BZZZZZZT! cutting into the side but anarchy turns round AND FLIPS DEAD METAL and escapes the cpz but minesweeper is waiting and charges
                but anarchy flips them up and over now minesweeper lacks pushing power and is pushed into the cpz with shunt and down comes the axe again
                now minesweeper is moving very slowly and so is anarchy but there saved
                as CEASE is called
                now we go to the judges now for the scores
                minesweeper
                damage style control aggression
                7 9 7 10
                total 33
                anarchy
                10 7 8 9
                total 34
                anarchy wins by 1 point coming next the heat final
                • #68
                  Well well well, because I was such a goddamned arse yesterday I didn't think I'd win. But I did anyway. Meh. Apologies to Joey and Mark and whoever I offended. I seriously had a bad day yesterday. Soz.
                  Apocalypse II vs. Anarchy
                  Well I'm boned now. :P Meh, flip it and axe it, all I can do. :P
                  • #69
                    Aside from the fact that his axe ripped a hole clean through 7mm hardox, and Anarchy unlikely crawled out of the pit, it was a half-decent fight...
                    And I accept your apology, Kody.
                    • #70
                      Isn't that a little hypocritical of you, seeing as you run VRW? :P
                      • #71
                        *Joking*Says the man who won VRW4...*Joking*
                        And I've never typed out a robot escaping from the pit...
                        • #72
                          Let's take this to PM's...
                          Richard did it in VFT5 I think.
                          • #73
                            Well, I guess it can happen, however I believe the robots had special mechanisms to allow them to do that.
                            • #74
                              Also, remember Wild Thing. In S5 it got pushed into the pit, but got out. Even though it lost, it lost on a JD, not because of the pit.
                              • #75
                                ok you 2 stop you can settle this with a grudge match in heat b
