Oh No!!! It's VRW 5!!!
    Re: Oh No!!! It's VRW 5!!!
          What's with all the s?
            I believe they all think that this will end badly with a possibility of an intercontinental shouting match.
            If you need someone to make up numbers I'll enter pending on whether I can get some stats up in time.
            Time to start work.
              It's a belief well grounded in historical precedent I'm afraid :P
              There are far better tournaments to enter for your first time Jordan, seriously...
                I think that this is the one that requires the least robots so It's less for me to have to design.
                • #23
                  With RoboBash 2 you can enter one vapourbot and the rest can be realies.
                  • #24
                    However, with this one, you can enter realies as long as you do not have 5 vapourbots.
                    So if you had 1 vapour, then you could enter 5 realies, 2 vapours with 4 realies, etc. But t only works if I'm positive you have less then 5 vapours.
                    • #25
                      Due to advice from a helpful assistant, I now only need 3 more people to make this a 24-bot minor.
                      • #26
                        err il enter CrOoKeD EvO, I.A.N, O.I.D....er must i enter the others? ah well if i have to il enter pick axe of doom and BOXX but id rather enter envy and orrion *orrion being my very own heavy) in their place
                        jack
                        • #27
                          Well, you would need 5 vapours and 1 realie...
                          If you can give me a general description of Orrion, I'll let you enter it as your realie.
                          Samuel Park
                          1: Theseus
                          2: Paralyzation 3 (11)
                          3: Mecha's Revenge (3)
                          4: Return of Black Death
                          5: Whiplash (7)
                          6: Gravity (14)
                          Jack Orr
                          1: CrOoKeD eVo (9)
                          2: I.A.N
                          3: O.I.D
                          4: Pickaxe of Doom
                          5: Boxx
                          6: Envy/Orrion
                          • #28
                            orrion is iron awe 4, we bought it resently, it has a axe and a flipper, both full pressure, its armored in hardox and steel, and if you need a description on how powerfull the weapons are we flipped puck out the arena in or fast fight, but befor that we punctured his tire with our axe, and bent the hub :P
                            • #29
                              Okay, then. Orrion will be your realie.
                              • #30
                                ill enter with my new vapours (thanks mark )
                                Merry Hampton
                                Weight: 100kg
                                Shape: A box on wheels ala Tornado.
                                Colour: the colour of unpainted titanium
                                Dimensions: 75cm x 85cm x 25cm
                                Drive: 4x 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
                                Locomotion: 4 foam-filled GoodYear Go-Kart wheels.
                                Armour: 6.5mm titanium
                                Speed: 20mph
                                Ground Clearance: 0mm at front, 5mm elsewhere.
                                Turning Circle: 0m
                                Weapon: A 7mm thick hardox scoop, mounted at the front.
                                Srimech: Invertible.
                                Strengths: Tornado on steroids.
                                Weaknesses: Untested.
                                Bio: im a train enthusiast,(does that make me sad?) so i came up with this design...
                                Win/Loss Ratio: N/A
                                The Servant
                                Weight: 100kg
                                Shape: Mute (S7)
                                Colour: Blood Red
                                Dimensions: 67cm x 96cm x 26cm
                                Drive: 4x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks
                                Locomotion: 4 Mute-style wheels.
                                Armour: 5mm titanium
                                Speed: 35mph
                                Turning Circle: 0m
                                Weapon: A full-pressure CO2 flipper(looks a lot like Chaos 2's) powered by a fire extinguisher.
                                Srimech: Flipper
                                Strengths: Very fast.
                                Weaknesses: Untested in battle
                                Bio: Essentially an updated Mute, Team Blood Mages' Servant is prepared to do some damage.
                                Win/Loss Ratio: N/A
                                Dr. Thwack
                                Weight: 100kg
                                Shape: Biohazard.
                                Colour: Malachite green
                                Dimensions: 80cm x 75cm x 10cm
                                Locomotion: El Diablo Grande-style rubber tank tracks.
                                Armour: 3.5mm of hardox and 1.5mm of titanium on top.
                                Speed: 20mph
                                Ground Clearance: 0mm all around thanks to 3mm titanium skirts. 5mm without skirts.
                                Turning Circle: 0m
                                Weapon: A 10kg pneumatic hammer, powered by a fire extinguisher. It hits an opponent at 70mph.
                                Srimech: The hammer.
                                Strengths: Powerful weapon, nearly unflippable.
                                Bio: my 2nd ever robot design.
                                Win/Loss Ratio: N/A
                                Druid
                                Weight: 100kg
                                Shape: Mortis (S4)
                                Colour: Black at the front, and gold at the back.
                                Dimensions: 100cm x 80cm x 30cm
                                Locomotion: Mortis-style titanium tank tracks.
                                Armour: 6mm hardox
                                Speed: 18mph
                                Turning Circle: 0m
                                Weapon: The weapon is a full-pressure Co2 flipper running off of a fire extinguisher. the flipper is not only the front wedge, but also the top of the robot.
                                Srimech: Flipper
                                Strengths: Half-Decent flipper
                                Bio: my 3rd robot design takes the full-body flipper to a new level.
                                Win/Loss Ratio: N/A
                                my realies will be
                                259 and storm 2
                                yay my 100th fanfic post
                                virtual beers for everyone
