err il enter CrOoKeD EvO, I.A.N, O.I.D....er must i enter the others? ah well if i have to il enter pick axe of doom and BOXX but id rather enter envy and orrion *orrion being my very own heavy) in their place
orrion is iron awe 4, we bought it resently, it has a axe and a flipper, both full pressure, its armored in hardox and steel, and if you need a description on how powerfull the weapons are we flipped puck out the arena in or fast fight, but befor that we punctured his tire with our axe, and bent the hub :P
Merry Hampton
Weight: 100kg
Shape: A box on wheels ala Tornado.
Colour: the colour of unpainted titanium
Dimensions: 75cm x 85cm x 25cm
Drive: 4x 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 4 foam-filled GoodYear Go-Kart wheels.
Armour: 6.5mm titanium
Speed: 20mph
Ground Clearance: 0mm at front, 5mm elsewhere.
Turning Circle: 0m
Weapon: A 7mm thick hardox scoop, mounted at the front.
Srimech: Invertible.
Strengths: Tornado on steroids.
Weaknesses: Untested.
Bio: im a train enthusiast,(does that make me sad?) so i came up with this design...
Win/Loss Ratio: N/A
The Servant
Weight: 100kg
Shape: Mute (S7)
Colour: Blood Red
Dimensions: 67cm x 96cm x 26cm
Drive: 4x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks
Locomotion: 4 Mute-style wheels.
Armour: 5mm titanium
Speed: 35mph
Turning Circle: 0m
Weapon: A full-pressure CO2 flipper(looks a lot like Chaos 2's) powered by a fire extinguisher.
Srimech: Flipper
Strengths: Very fast.
Weaknesses: Untested in battle
Bio: Essentially an updated Mute, Team Blood Mages' Servant is prepared to do some damage.
Win/Loss Ratio: N/A
Dr. Thwack
Weight: 100kg
Shape: Biohazard.
Colour: Malachite green
Dimensions: 80cm x 75cm x 10cm
Locomotion: El Diablo Grande-style rubber tank tracks.
Armour: 3.5mm of hardox and 1.5mm of titanium on top.
Speed: 20mph
Ground Clearance: 0mm all around thanks to 3mm titanium skirts. 5mm without skirts.
Turning Circle: 0m
Weapon: A 10kg pneumatic hammer, powered by a fire extinguisher. It hits an opponent at 70mph.
Srimech: The hammer.
Strengths: Powerful weapon, nearly unflippable.
Bio: my 2nd ever robot design.
Win/Loss Ratio: N/A
Druid
Weight: 100kg
Shape: Mortis (S4)
Colour: Black at the front, and gold at the back.
Dimensions: 100cm x 80cm x 30cm
Locomotion: Mortis-style titanium tank tracks.
Armour: 6mm hardox
Speed: 18mph
Turning Circle: 0m
Weapon: The weapon is a full-pressure Co2 flipper running off of a fire extinguisher. the flipper is not only the front wedge, but also the top of the robot.
Srimech: Flipper
Strengths: Half-Decent flipper
Bio: my 3rd robot design takes the full-body flipper to a new level.
Win/Loss Ratio: N/A
my realies will be
259 and storm 2
yay my 100th fanfic post
virtual beers for everyone
