Crash & Burn: Mini-Tournament of Death 3
    Re: Crash & Burn: Mini-Tournament of Death 3
    I will enter Envy please. I think you know the stats
      I do indeed. Thanks very much, Swanny.
      Entrants
      Gabriel V (Joey)
      Minesweeper 1.1 (Mark)
      Qwertyuiop (Navaha)
      CrOokEd (Jack)
      [reserved] (Andy)
      Envy (Shane)
      10 more spots.
        I'll enter Next Stop Jupiter.
        Weight: 100kg
        Shape: Warrior SKF, with a wedge extension on the front.
        Colour: Colours of the planet Jupiter, duh.
        Dimensions: 100 X 81 X 21 cm
        Power: 2 X LEM-130's @ 36v, powered by several NiCad Batteries, shock-proofed.
        Wheels: 2 X Aluminium Wheels with Urethane Rubber for superb grip
        Armour: 3.5mm Hardox for the wedge, 7mm Ti/V for top and bottom, 5mm hardox for the rim
        Speed: Roughly 13 mph
        Ground Clearence: Obviously 0mm for the front, and 6mm for anywhere else
        Turning Circle: Zero... how many times do I have to tell you guys?!
        Weapon: A nasty 27kg spinning rim powered by an LEM-130 Lynch, and spinning at 2000RPM. It also has 8 X hardox teeth on board. (Four on top, Four on Bottom) The rim can deliver some VERY nasty damage to another opponent. It can slice through titanium, and dent hardox without any problems. The motor is shock-mounted, to avoid killing itself from its own hits. The rim can also transfer its energy to the front kinetic flipper, thanks to a clutch. This flipper has a wedge extension which is nearly impossible to get under. The flipper can also throw robots with HUGE force. Can you say, OOTA?!
        Srimech: Yes, it can run inverted... BUT the flipper can right the robot if needed.
        Strengths: Can cause some EXTREME damage, Powerful Flipper, Shock-Proofed, A good all-rounder.
        Weaknesses: A bit slow
          Sorry, I screwed up on the stats again.
          Minesweeper 1.1
          Weight: 100kg
          Shape: Tornado (S7)
          Colour: Gold on top and bottom, Silver on the sides, with MINESWEEPER written on the sides in red. The scoops are bronze.
          Dimensions: 90cm x 85cm x 25cm
          Drive: 2x 36v LEM-130 motors, powered by 8x A123 Battlepacks. The motors power all 4 wheels via a belt system.
          Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
          Armour: 6mm Hardox monocoque
          Speed: 22mph
          Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
          Turning Circle: 0m
          Weapon: 2 solid Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at front and back. The robot also has a bunch of shockproofing around the belts, electronics, and motors, due to the fact that it was originally designed as a spinner killer/rambot.
          Srimech: Invertible
          Strengths: Super-reliable and fast. Good pushing ability.
          Weaknesses: Not too much of an offensive weapon.
            I'll enter Apocalypse II, stats in C&B4
              Monsoon Season, SVP. Stats here: http://strickenone.proboards.com/index. ... thread=305
              YAY!
                I'll go about entering Die-Reverta-Tops...I trust you know where the stats are. :wink:
                • #23
                  I will enter Under Pressure! http://strickenone.proboards.com/index. ... =thvapours
                  • #24
                    Mornington Crescent for me, please!
                    NAME- Mornington Crescent (HW)
                    SHAPE- flat cylinder
                    COLOUR- white, with the London Underground sign for Mornington Crescent on the top and bottom
                    WEIGHT- approx 100kg
                    DIMENSIONS- 100cm X 20cm
                    SPEED- 12mph
                    TURNING CIRCLE- 0mm
                    GROUND CLEARANCE- 8mm
                    ARMOUR- 3.5mm Hardox
                    MOVEMENT- 4 x inner wheels
                    POWER- 2 x S28-400 Magmotors, running at 24v
                    WEAPONS- Mornington Crescent is armed with not one, but TWO outer spinning rings, one on top of the other. The top ring spins anticlockwise, while the bottom ring spins clockwise. Each ring has four teeth and weighs about 10kg. The rings are powered by an LEM-130 running at 36v each and can reach speeds of 1500rpm. The two rings spinning in alternate directions should also help the robot be easier to drive - theoretically, anyway.
                    SRIMECH- invertible
                    NOTES- flies Scotland flag, thanks to Joey and Andy for helping with stats
                    STRENGTHS- two spinners for the price of one, nippy, manoueverable, tough, more controlled than regular ring spinners
                    WEAKNESSES- wheels open to axes and crushers, unpredictable bouncing?
                    PIC- http://img25.imageshack.us/img25/5661/m ... escent.bmp
                    • #25
                      I've decided to go for The Final Cut.
                      Also, Paul wishes to enter Nitro-Gene 5.0.
                      • #26
                        Entrants
                        Gabriel V (Joey)
                        Qwertyuiop (Navaha)
                        CrOokEd (Jack)
                        The Final Cut (Andy)
                        Envy (Shane)
                        Next Stop Jupiter (Samuel)
                        Apocalypse II (Liam)
                        Monsoon Season (Daniel)
                        Die-Reverta-Tops (Chris)
                        Under Pressure (Martijn)
                        Mornington Crescent (Steven)
                        Nitro-Gene 5.0 (Paul)
                        3 more.
                        • #27
                          Lethal Weapon for me.
                          Kody, I trust you still have the stats?
                          • #28
                            Not on either computer, but they're on ZED, aren't they? I seen 'em there. So I'll use those.
                            2 more people needed! Then this can get underway.
                            • #29
                              I'll enter Symmetry:
                              http://www.insaneclown.nl/vapourbots/showrobot.php?id=3
                              • #30
                                I probably don't need to say this, but...
                                Leo, do you remember Liam's Mini-Tournament? You entered Symmetry, and I entered Minesweeper!
