Re: The Crash & Burn Tournament 4
Joey sez: I'm pretty sure I am right, I haven't heard anything about them using actuators on it before. If wrong, I stand corrected.
As for batteries...2 3600mah packs is 7.2ah, which is just about enough to keep a basic, 2wd heavyweight robot with no electric weapon going for about five minutes. Anything on top of that that is electrically powered will add to the drain, as will more wheels and other strange things.
A guide (accuracy not guaranteed, knocked up in five minutes from basic knowledge)
6-7ah (2 NiCad/NiMh packs) - will power a heavyweight with two standard (i.e. not starter or other strange devices) electric motors on two wheels and no other electrically powered components
9-12ah (3 NiCad/NiMh packs) - will power a heavyweight with two electric motors on four wheels, or a heavyweight with two electric motors on two wheels and an electrically powered weapon (except some spinners with large heavy discs)
12-16ah (4 NiCad/NiMh packs) - will power most heavyweights, up to four electric motors on four wheels or two motors on six or more wheels, and a large electrically powered weapon with one motor or hydraulic pump.
20ah (5 NiCad packs) - will power almost all heavyweights, including those with tracks, those with large amounts of wheels and motors, those with two or more motors on a spinning weapon (including Y-drives) or a combination of a hydraulic pump and another high current draw electric weapon.
24ah (6 NiCad packs) - needed if you're running some combination involving fully rubberised tracks and a large electric weapon or hydraulic pump. Very overkill but will ensure you're never short on power.
24ah+ - good starting point if you experiment with car starter motors for drive.
It's a bit general (it doesn't cover overvolting motors, although if you run things above their rated voltage you should add another pack to be sure) but it's worked for me so far (it's based on the same standards I use for working out battery power, although I eschew electrically powered spinners so I don't have that problem)
Andy sez: Thanks for the reserved place, Kody, and good to see you back. I'm working on some new otherweights and then I'll post my stats.
