PTT - Regeneration
  • #31
    PTT - Regeneration
    The Crashing Bore????? 2?????
    *faints*
    • #32
      PTT - Regeneration
      The legend returns!
      • #33
        PTT - Regeneration
        I am here. Thanks be to Kody for reserving a spot. (If that was ok. )
        Heavy Weights:
        Mobile Failure - http://strickenone.proboards99.com/index.cgi?board=teamaltvapours&action=display&thre ad=507http://strickenone.proboards99.com/i...action=display &thread=507
        Bloody Frigid - http://strickenone.proboards99.com/index.cgi?board=teamaltvapours&action=display&thre ad=569http://strickenone.proboards99.com/i...action=display &thread=569
        The Featherweight will be along shortly.
        • #34
          PTT - Regeneration
          Frank can I say that batteries should be along the lines of 6 packs of A123s each pack built to 36v. I think that should be plenty of power and room to fit them. A123s are the kiddy battery at the mo. Soon to be fitted in Thor. Just an opinion you dont have to use them.
          • #35
            PTT - Regeneration
            Heavyweight 1
            Motivation: 4 x 125mm wheels
            Speed: 0-12MPH [25MPH under Kinetic Boost]
            Clearance: 7.5mm (same inverted) 0mm at the front, the wedge scraps the floor.
            Weight: 100kg
            Height: 125mm
            Length: 800mm
            Width: 600mm
            Weapon: The weapon is a 28kg Hardox spinning ring (Ala MDU) powered by 2 x D-Pack motors @ 24v (Same motors used in Shredderator). The rim rotates at 2500rpm and should spin up within 1-2 seconds. The weapon is also a storage device for the drive. The spinning rim is connected to each side of the drive via a car air conditioner clutch, when the clutches are engaged, the 31kg kinetic storage bank(the spinning rim) transfers its energy into the drive train, giving it approximately double torque and speed for 2-3 seconds until the rim starts too loose speed and energy. This extra €˜kinetic€™ boost is used to ram into opponents with the front 6mm thick Hardox 500 wedge (similar to the one on Warrior SKF but wider and less depth to it). The front wedge is rubber shock mounted to ensure it survives the biggest of hits.
            Drive: 2 x S28-400 Magmotors on 24v geared 4.8:1. The drive is also assisted via the spinning rim as explain above.
            Batteries: 12 x 8 A123 cell packs. 26.4V @ 27.6Amp/hour
            Armour: Front wedge is made entirely out of 6mm Hardox 500, the top and bottom of the robot is made out of 4mm Hardox 500, The ring is made out of 10mm Hardox 400 with inner bracing to the perimeter bearing. Inner bulk heads are made from 20mm polycarbonate and 10mm aluminium. All internals are mounted on soft urethane mounts for shock protection.
            Notes: Invertible, speed when needed and generally well controlled for a spinner. Ram or Spin, Infusion aims to win!
            Heavyweight 2
            Pictures:http://i20.photobucket.com/albums/b2...Nerix.pngNerix
            • #36
              PTT - Regeneration
              We might be moving house back home, so I dont feel like doing any writing now.
              I will post my entries
              Heavyweights:
              The Kill Point
              Skullcrusher
              Featherweights:
              Sons of Thunder
              (Stats on Chevron Championship 2)
              • #37
                PTT - Regeneration
                Entry update!
                HEAVYWEIGHTS THUS FAR:
                1. Seung Mina V (Kody Kunz)
                2. Intriguous
                3. ??? (Alex McW)
                4. ???
                5. Gehenna (Andy J)
                6. Fissure
                7. Under Pressure (Martijn B)
                8. Back to Rock III
                9. Dervish: The 1337 Generation (Daniel S)
                10. Propane Nightmare
                11. ??? (Martyn F)
                12. ???
                13. Orka R.V. (Chris M)
                14. Leprosy Infection
                15. Eye of Ran II (Joey McC)
                16. Nidhogg Evo
                17. The Crashing Bore 2 (Frank G)
                18. Raging Tempest
                19. Tengu VII (Alex H)
                20. Achilles
                21. Infusion (Aaron K)
                22. Nerix
                23. Nitro-Gene 5.0 (Paul C)
                24. Autoism 3.0
                25. BIACS-IS of Evolution (Matt F)
                26. Hacked-Off Ha-ka
                27. The Kill Point (Elliot S)
                28. Skullcrusher
                29. Mobile Failure (Tracy F)
                30. Bloody Frigid
                31. Apocalypse (Liam E)
                32. Kill Saw
                FEATHERWEIGHTS THUS FAR:
                1. Heretic (Kody K)
                2. ??? (Alex McW)
                3. OverDrive (Andy J)
                4. ??? (Martijn B)
                5. Deadly Lampshade (Daniel S)
                6. ??? (Martyn F)
                7. Bulldozer (Chris M)
                8. Isolation (Joey McC)
                9. ??? (Frank G)
                10. Sith (Alex H)
                11. M.B.X. (Aaron K)
                12. Skink (Paul C)
                13. Tidal Wave (Matt F)
                14. Sons of Thunder (Elliot S)
                15. ??? (Tracy F)
                16. Werewolf (Liam E)
                Stats required from Alex Mc, Martyn, Chris, Kody (FW), Martijn (FW), Frank (FW) and Tracy (FW).
                Sorry you missed out, Shane and Richard. Maybe I could arrange a little grudge match if I have time.
                • #38
                  PTT - Regeneration
                  No worries dood
                  • #39
                    PTT - Regeneration
                    Heretic is done: http://strickenone.proboards99.com/index.cgi?action=display&board=feathers&thread=650 &page=1http://strickenone.proboards99.com/i...feathers&threa d=650&page=1
                    • #40
                      PTT - Regeneration
                      ORKA RV
                      Weight: 100 kilos
                      Body Shape: Basic Invertible box-wedge shape. 1m long, 0.8m wide, 0.3m at maximum height.
                      Speed: Some 15mph
                      TC: 0
                      GC: 8mm, 0mm at front.
                      Wheels; 6 inner
                      Armour; 7mm titanium
                      Power; 3x 12v batteries, powered by S28-400 Magmotors, at 24v.
                      Colour; Black with white patches
                      Weapons; A pneumatic CO2 powered flipping arm that spans most of the robots length. It can throw some 400 kilos and has about 50 flips. Although the arm itself is quite narrow (about half the robot width), the flipper plate expands the full width.
                      Srimech: Its a both-er. It can run inverted AND self-right using the arm.
                      Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
                      Strengths; Weapon
                      Weaknessess: Hard to turn
                      LEPROSY INFECTION
                      Weight; 100 kilos
                      Body Shape; Invertible box, looks a bit like Tetanus Booster, only slightly larger. About 140cm in length, 90cm in width and 30cm in height.
                      Speed; 18mph
                      TC; 0
                      GC; 6mm. The mini-skirts hang down to about 1mm.
                      Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
                      Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
                      Colour; A disgusting shade of lime green.
                      Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
                      Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
                      Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
                      Strengths; Drum, control is pretty good
                      Weaknessess; Wheels may be vulnerable to axes
                      Bulldozer will come later.
                      • #41
                        PTT - Regeneration
                        Names
                        HW
                        Disco 5
                        The Deer/ No-I-Deer
                        FW
                        DTK (rw 7)
                        stats for my hw laters
                        • #42
                          PTT - Regeneration
                          Thanks for the advice Shane. I have no trouble admitting I know very little about batteries
                          • #43
                            PTT - Regeneration
                            OK, peeps, heres the situation: I start uni again on Monday and I would really like to get started on this tournament before I go back.
                            Featherweight stats are still required from Alex Mc, Chris, Frank and Tracy. Martijn told me on MSN hes going to use real robot Afterschock.
                            Martyn, I can get your stats from another recent tournament if you dont have the time to post the updated version.
                            Alex Mc, I cant start the tournament without your Heavyweights at least. Stats in, chop-chop. :wink:
                            (Message edited by Steven_McG on January 29, 2009)
                            • #44
                              PTT - Regeneration
                              Gah, forgot I needed a feather. Sorry
                              I dont have one, so Ill enter Pillow Torque
                              • #45
                                PTT - Regeneration
                                BULLDOZER
                                Weight: 12.5 kilos
                                Shape: Basic box shape with front scooper, 30cm by 20cm by 20cm
                                Speed: 15mph
                                TC: 0mm
                                GC: 0mm at from, 6mm at back and sides.
                                Wheels: 4 inner.
                                Armour: 4mm aluminium armour all around. The sides and back are additionally protected by strips of balsawood, which is also used to create the horns. The top is additionally covered by what looks like a paper bag. All of these are purely for sacrificial purposes.
                                Power: 2 18v drill motors, and 2 12v NiCads.
                                Weapons: The front scoop provides the main weapon. It gets underneath an oppodent, then simply pushes into them, or turns them over. Also at the back is a tail, powered by its own electric motor. It is mostly there for effect.
                                Srimech: The tail might do that.
                                Strengths: Getting underneath the opposition.
                                Weaknesses: Sacrificial, to say the least.
                                And before anyone questions the paper bag...err, hello? Tricerabot?
