How could I Improve pt 2
This is a sticky topic.
    Hardox or any other steel on a feather is certainly possible, but how thick depends on the rest of the robot of course.
    My new feather, Hardox armour.
    Yep, it's certainly doable, my old wedge had 3.2mm Hardox 450 and 5-6mm Farm Steel (Plough Disc!)
    It's all about the thickness and amount used
      Ok, New Vapour.
      Nucleus:
      Shape: T-Minus with side skirts
      Colour: Grey with a yellow flipper
      Weight: 100kg
      Drive: 2 S28 Magmotors @ 24V
      Power: 6 Intercooled NiCad Battlepacks @ 24V
      Motivation: Thick Titanium treads with a Urethane coating
      Speed: 12mph
      Armour: 4mm Hardox
      Ground Clearance: 0mm at front, 0mm at sides, 10mm at rear and under skirts
      Turning Circle: 0
      Dimensions: 100x70x35
      Weapons:
      Weapon 1: A high-pressure rear-hinged nitrogen flipper running at 1000psi powered by 2 125x75 rams running off of a 3kg Nitrogen tank
      Weapon 2: The scoop on the front is covered in titanium barbs
      Srimech: Flipper
        Hi, CPA23, welcome back! Good vapour there, but there's a few problems with it...
        1) The B42 MagMotors...they are more properly called BFA42 MagMotors. Also, they come in specific series, such as 500, 600, and a few others. Which one are you referring to?
        2) A123 cells come in multiples of 3.3v, so they don't equal 48v exactly. Also, how many cells are in those 8 packs? The number of cells dictates the voltage you will have.
        3) The ground clearance is a bit sketchy. If you mean that the ground clearance at both the front and rear is 0, then it won't move. Also, 3mm is a bit small itself, you might want to bump that up to 10mm so you don't have trouble driving.
        4) With the armour you have on, the 100/80/50cm dimensions you have are quite optimistic, and lessening the armour will solve the weight problem but make your robot more vulnerable. You should lower one or two of the dimensions a bit.
        5) You can't run Nitrogen pneumatics from a CO2 tank.
        6) Shouldn't the titanium barbs be visible from the side view?
        7) You should have a front and/or top view to compliment the side view, it helps us visualize it better that way.
        Yeah, try and fix those things and we should be all set.
          Ok, thanks for the help.
          1: Which would you reccomend?
          2: I'll change the batteries to Intercooled NiCad Battlepacks http://www.robotcombat.com/products/...tercooled.html, but how many should I use and at what voltage?
          3: I'll up the ground clearance to 10mm and lose the back skirt
          4: The new dimensions will be 100x70x35
          5: Ok, my bad. I meant a nitrogen tank, I apologise for this, it was like 2 AM.
          6&7: I will fix the picture & add a new picture tommorow.
            1/2) If you're going with NiCad Battlepacks instead, then I would recommend either S28-400 MagMotors (more power but less thermal energy) or C40-300 MagMotors (bit less power but more thermal energy so they'll last longer), and I'd recommend running the S28s on 24v/C40s on 36v, and using at least 5 or 6 Battlepacks for either.
            3) Okay.
            4) Seems doable to me, although other people might question it.
            5) It's okay, I have made stats late before and have had to change them for it. :P
            6/7) Yep, it's all good. For a paint pic that was actually a pretty good attempt, although if you feel up to it, you may want to try your hand at 3d-modelling programs such as Rhino or SolidWorks (Rhino is a bit easier to use) to give an even better visualization.
              Ok, I will try Rhino but in the meantime I will post a new picture using paint.
              Edit: Just looking through your vapours and my robot lookes suprisingly like Fulcrum.
                No problem at all, mate, your pic was pretty good after all. I started out using Paint, although I deleted all my old paint pics before 2005.
                  Just noticed a mistake in my stats, Nucleus is 10kg too light, so I will upgrade the Nitrogen tank from 3kg to 5kg and and have 7 battlepacks instead of 6
                    Iv'e made a new robot which will replace a bot Mark gave me
                    4-Bar Discount
                    Weight: 100kg
                    Shape: A box wedge that has a wedge on all sides, like Storm 2, but with a rounded rear
                    Colour: Grey with blue and red stripes
                    Dimensions: 0.67m x 0.78m x 0.68m
                    Drive: 4x 24v S28-400 Magmotors, powered by 7x 3000mAh NiCad Battlepacks.
                    Locomotion: 4 Storm 2 style wheels
                    Armour: 2mm Polycarbonate baseplate. Everything else is 40mm HDPE to combat axes
                    Speed: 14mph
                    Ground Clearance. 0mm's at front. 7mm elsewhere
                    Turning circle: That of a pizza machine. 0
                    Weapon: A 4-Bar flipper which is powered by a 4kg nitrogen tank and a 100mm ram at 1000psi . The bot also has static spikes at the rear for extra protection.
                    Srimech: Flipper of course
                    Strenghs: Good flipper. Good armour and plenty of potential
                    Weakness: Um..... Not sure.
                    Bio: A bot that seeks to beat you to a bloody pulp
                    Win/Loss Ratio: N/A
                    What do you think
                      I think...
                      1) 2mm polycarbonate is too thin, even for a baseplate
                      2) It's incredibly tall for a box wedge.
                      3) It's okay, minus above points 1 and 2.
                        OK thanks for the advice Kody
                        Revised stats
                        4-Bar Discount
                        Weight: 100kg
                        Shape: A box that has a wedge on all sides, like Storm 2, but with a rounded rear
                        Armour: 6mm Polycarbonate baseplate. Everything else is 40mm HDPE to combat axes
                        Speed: 14mph
                        Win/Loss Ratio: N/A
                          Kody, I made the picture you asked for, but could only fit 3 sets of barbs on the picture, there should be two more sets of barbs (See original post).
                            Can someone check this please.
                            Bruxism
                            Shape: Wedge with sloped sides and rear + side and rear torsion sprung skirts
                            Colour: Like teeth and gums
                            Weight: ~98.2kg
                            Drive: 2 S28 400 Magmotors @ 24V Geared at 1.5:1
                            Power: 9 NiCad Battlepacks @ 24V
                            Motivation: Two small rubber wheels with Hardox hubs, the are a similar size to Iron Awe 5€™s wheels
                            Speed: 23mph
                            Armour: 5mm Hardox
                            Ground Clearance: 0 all round, 5mm under skirts
                            Turning Circle: 0
                            Dimensions: 150x60x40
                            Weapons:
                            Weapon 1: A 10kg axe powered by a 150x120 ram, the axe head is like Dominator 2€™s axe but the spike is longer
                            Weapon 2: In front of the axe shaft there is a Hardox panel, when the axe is fired it acts as a forward hinged flipper
                            Srimech: Flipper or axe, take your pick
                              PSYCHO
                              BODY SHAPE: Short, fat cone. Short for a cone anyway
                              WEIGHT: 100kg
                              DIMENSIONS (L X W X H): 75cm [without spike] x 75cm x 30cm
                              COLOUR: Crazy mix of primary colours and some green with the name written in silver with blood red outline around the outside
                              LOCOMOTION: 4 x internal custom-built HDPE wheels 85mm in diameter with vulcanised tyres.
                              GROUND CLEARANCE: 10mm
                              DRIVE MOTORS: 2 x S28-400 magmotors run @ 24v
                              DRIVE BATTERIES: 2 x NiCad battlepacks running at 24v in parallel
                              SPEED: 15mph
                              TURNING CIRCLE: 0 metres
                              BODY ARMOUR: 7mm hardox monocoque, the removable panel is the base, which is 5mm aluminium
                              CHASSIS: 7mm hardox monocoque
                              WEAPON 1: The shell has two huge curved blades on either side that are actually part of the shell so that they cannot be ripped off. They are tungsten tipped and the shell spins up to 3000rpm in 3 seconds via 2 x S28-400 magmotors @ 24v to make one deadly weapon.
                              SRIMECH: There is a pole that sticks out of the top of the robot and is bent to a 90 degree angle like . It works like Megabyte's, pushing the robot back onto its wheels when flipped.
                              ARMAGEDDON
                              BODY SHAPE: Basic box with front hinged wedges and rear battering ram
                              WEIGHT: 100kg
                              DIMENSIONS (L X W X H): 90cm x 80cm x 25cm
                              COLOUR: See CAD
                              LOCOMOTION: 4 x internal but invertible custom-built HDPE wheels 270mm in diameter with vulcanised tyres.
                              GROUND CLEARANCE: 10mm, this is protected on the front by the hinged wedges and on the sides by the skirts
                              DRIVE MOTORS: 4 x S28-400 magmotors run @ 24v
                              DRIVE BATTERIES: 8 x NiCad battlepacks running at 24v in parallel
                              SPEED: 20mph
                              BODY ARMOUR: 4mm hardox monocoque
                              CHASSIS: 4mm hardox monocoque
                              SKIRTS: 5mm grade 2 titanium, hinged wedges are 7mm of the same stuff
                              WEAPON 1: The set of 5 hinged wedges at the front of the robot are very effective at getting under other robots to help in pushing them around.
                              WEAPON 2: The battering ram at the rear of the robot is shock mounted and is made of 1cm think grade 2 titanium, so it will flex under pressure from spinners rather than being ripped off, like Behemoth's scoop
                              SRIMECH: Invertible, works just as well as upside down.
                              STRENGTHS: Strong and powerful
                              Could somebody check these stats for War of the Weapons please? I'm more or less sure about Armageddon, but Psycho I'm not so happy about, I've never attempted an FBS before.
                                Hey guys, I haven't been around for... not sure how long, but considering I have an unread PM from January 2009 in my inbox at ZED, quite a while. I'm thinking about entering tournaments again when some open, but I'm quite out of the loop when it comes to the quality expected of vapourbots these, days, so if someone has the time spare to look over my robots hosted here, (Thanks to Kody for keeping them on his site, by the way) I'd really appreciate it.
