How could I Improve pt 2
This is a sticky topic.
  • Glad to see Leo's still around.
    • Raise the dead
      shape:see pic
      dimensions: 750mm x 500mm x 210mm
      weight:100kg
      wheels: 2 x 220mm custom wheels, rubber tyre
      clearance: 0mm at front and skirts, 6mm at back (exc. skirt)
      motors: 2 x LEM 130's
      speed:15mph
      armour: 6mmvti/v alloy, 7mm front of lifter, 4mm at end of skirts
      weapon: 1000psi CO2 4-bar flipper powered by a 190mm ram and a 3kg CO2 bottle.
      srimech: invertible, may be able to self right with flipper
      • So back to vapourbot designing, i have tweaked my two original vapours:
        Shape : Plowed Box, like Punjar,but with sides and back sloped at 45° angle, with a slot cut in the plowed front for the weapon
        Dimensions : Length : 60 cm,Width : 80 cm Height : 35cm
        Color : Dark Blue
        Weight : 99kg
        Movement : 2 Go-Kart wheels
        Motors : 2 NPC-T74 at 36V
        Speed : 20 Mph
        Armor : 4mm Hardox for everythingexcept the front plow which is 1mm thinner
        Turning circle : 0mm
        Ground Clearance : 1,5cm
        Power : 6 Ni-Cad battlepacks at36V
        Weapon : A Vertical ElectricBoogaloo style bar , powered by an Perm 132 at 36V, allowing it toreach 3000RPM
        Shape : Low Box, Tornado Style,with a plow at back, and a Last Rites style cage holding the weaponat the front
        Dimensions : Length : 90 cm,Large : 80 cm Height : 35cm
        Color : Blood Red
        Weight : 100kg
        Movement : 2 Caterpillar Tracks
        Motors : 2 NPC-T74 at 24V
        Speed : 15 Mph
        Armor : 3mm Hardox
        Weapon : A Matilda Style 27kgFlywheel with 2 S7 Tool Steel Series 4 Hypno-disc like teeth, poweredby an E-tek R at 36V, allowing it to reach 3000RPM
        • New Vapour whipped up
          Weight: 100kg
          Shape : Box Shape, with roudedsides and a back slot for the secondary weapon
          Drive : 4 Go-Kart Wheels, drivenby 4 NPC-41250 at 24V
          Armor : 2.5 mm Hardox
          Colour : Golden, with the name inRed on the top and bottom
          Length : 80cm
          Width : 60cm
          Height : 30cm
          Speed : 20mph
          Srimech : Invertible
          Ground Clearance : 1cm
          Weapons : A hinged wedge at the front, which therefore means it will always scrape the floor, made of 3mm Hardox , wedge works the same either way up, and 2small teeth can be mounted at the top, near the edges for preventopponents from jumping over it, the wedge is 20 cm long and has thesame witdh and height as the chassis, with a 35° slope
          A horisontal spinning disc 45 cm wideand 5 cm tall, with 2 Hypno-Disc Series 4 teeth, spinning at 2500RPM, powered by an E-Tek at 36V
          Turing Circle : None
          • I'm still a little unsure about this sort of thing, with the weights, dimensions and such like. Does this one look like it would work?
            Robot Name: No Exit
            Shape: Rounded cylinder segment (See image)
            Weight: 27.0 kg
            Length: 29.9 cm, 24.5 cm with Ramp weapon
            Width: 30.0 cm
            Height: 5.5 cm
            Motivation: 2x solid rubber & polyurethane wheels
            Drive: 2x DeWalt 12V New Style Drill Motors
            Power: 1x 14.8V Li-Poly 4-cell pack
            Armour: 4mm Kevlar and fiberglass shell with Nomex lining, 6.5mm Titanium frame & wedges
            Weaponry: CO2 powered low-pressure Flipping arm with interchangeable Titanium wedge and Hardox Ramp attachments, hinged titanium wedges, actuated HDPE bollards
            Speed: 14.5 mph
            Turning Circle: 0 cm
            Ground Clearance: 5 mm, 0mm for wedges
            Srimech: Flipping Arm
            Colour: Near-black, details based on road markings (See image)
