Re: How could I Improve pt 2
Hammer & Nails looks good to me Lian, but if you want to revamp it I'd remove one of the axes, personally I don't see the need for 2
And I'd keep Curse of the Deep just for that nice CAD, it'll probably do better over here than it did on ARC
And if anyone wouldn't mind looking at Vertigo here, been a while since I wrote out FRA-style stats and I think the pneumatics in particular may be off....
VERTIGO
BODY SHAPE: Box with 60* wedge at front and angled rear ala Tornado. The sides are sloped at 45*
WEIGHT: 100kg
DIMENSIONS (L X W X H): 80cm x 75cm x 20cm
COLOUR: See CAD
LOCOMOTION: 4 x internal wheels, made of aluminium with unrethane tyres. Each is exposed from the top and bottom and is 22cm in diameter
GROUND CLEARANCE: 0 at the wedge, 8mm at sides and 10mm at rear
DRIVE MOTORS: 2 x LEMCO-130 lynch motors running @ 48v
DRIVE BATTERIES: 4 x NiCad battlepacks at 12v in series
SPEED: 18mph
TURNING CIRCLE: 0 metres
BODY ARMOUR: 4mm hardox monoque, flipper/top panel is
6mm.
CHASSIS: 4mm hardox monocoque. The removable panel is the top one.
WEAPON 1: The whole top panel is a full pressure flipper, powered by a 100mm ram @ 725psi from a 3kg co2 bottle, providing plenty of flips and a lot of power, similar power in fact to the modern Kronic the Wedgehog.
SRIMECH: The robot is invertible, but the flipper can be used to right it if needs be.
STRENGTHS: Powerful weaponry, tough armour
THEME SONG: Bodies by Drowning Pool
VERTIGO
WEIGHT: 100kg
COLOUR: See CAD
SPEED: 18mph
6mm.
