How could I Improve pt 2
This is a sticky topic.
    I've swapped the blade for a 259 style disc, placed horizontally on the robot. It is 60cm long and powered by a Magmotor. I'm not too sure which type of power source to use for it, though, since I planned for the weapon to be as fast as Typhoons
    Any advice?
      Typhoon's disc was petrol driven...can't remember what engine exactly but it was a Stihl chainsaw one, size and power unknown but I use a similar thing (Stihl MS880, 8 horsepower, 12000rpm ungeared speed, about 10kg) for pretty much all my spinners, that may be of use to you.
      Most people seem to prefer using electric motors to drive spinners for some reason, the S28-400 Magmotor (4.5 horsepower at 24v, 4000rpm ungeared speed, 3.1kg) is a popular choice.
      Typhoon only span at about 900rpm max, it did so much damage because it was very well made and there was a lot of weight in the spinning shell, particularly on the outer rim.
      Hope all that is of use :P
        Is there anything wrong with this?
        (TEAM COLDSTORM HOUSE ROBOTS)
        Napoleon Botaparte
        Weight: 110kg.
        Shape: Reverse Wedge ala Bad Attitude.
        Colour: Blue, Purple and Navy.
        Dimensions: 120 X 100 X 37.
        Power: 2 X LEM-130's @ 48v, powered by several NiCad Batteries, Shock-Mounted.
        Wheels: 4 X Urethane Rubber Tyres with titanium hubs.
        Armour: 25mm Polycarbonate for sides, 5mm Hardox for front and rear wedges, 4mm Titanium for top and bottom.
        GC: 0mm for the wedges, 6mm anywhere else.
        Top Speed: 35 mph.
        Weapon: None.
        Srimech: Invertible, Side spikes prevent it from getting beached.
        Strengths: CRAZY PUSHER!!!
        Weaknesses: Exposed Wheels, duh.
        Mangled Metal
        Weight: 200kg.
        Shape: Cylinder ala Puck.
        Colour: Green.
        Dimensions: 120 X 120 X 23.
        Power: 2 X S28-400's @ 24v powered by several NiCad's, shock mounted.
        Wheels: 4 X Aluminum Tyres with Urethane Rubber.
        Armour: 3.5mm Hardox for Top and Bottom, 6mm Hardox for weapon.
        GC: 6mm Everywhere.
        Top Speed: 10 mph.
        Weapon: 74kg Ring Spinner powered by a LEM-200, with 4 X 1kg Pussycat style blades and spinning at 1300RPM. Shock-Mounted to protect itself from its own blows.
        Srimech: Invertible.
        Strengths: Once it hits you, YOU will be mangled metal. Flipping it does nothing. At all.
        Weaknesses: Slow and Sluggish.
        Mind-Bender
        Weight: 250kg.
        Shape: Cone with top 20cm cut off... kinda like Megabyte :P
        Colour: Swirl of black and white ala Hypnodisc.
        Dimensions: 120 X 120 X 27.
        Power: 2 X S28-400's @ 24v, powered by several NiCad Batteries, Shock-Mounted.
        Wheels: 4 X Aluminum Wheels with Asmaprene Urethane Rubber on it.
        Armour: 4mm Grade 5 Titanium for the robot armour, 5mm Hardox for the weapon.
        GC: 5mm Everywhere.
        Top Speed: Roughly 8 mph.
        Weapon: Get this. A 78kg Whyachi style Spinning Cage powered by a LEM-200. This spins at 1500RPM, and has three hardox claws to wreak havoc. Heavily Shock-Mounted, as well. Can you say, OUCH?!
        Srimech: None! :O But I'd like to see you get past his cage spinner.
        Strengths: Destruction to the MAX!
        Weaknesses: Flip it, and it'll be gone.
        Head Smash!
        Weight: 300kg.
        Shape: Think a box, with a Dantomkia-style front wedge, and a rounded back.
        Colour: Red, with an image of Decapitated Head on Top.
        Dimensions: 125 X 96.8 X 32.
        Power: 2 X LEM-130's @ 48v, powered by several NiCad Batteries.
        Wheels: 4 X Urethane Rubber Tyres with Hardox Hubs.
        Armour: 6.5mm Hardox, with 12mm Grade 5 Titanium for the Base.
        GC: 0mm for the front, 6mm for anywhere else.
        Top Speed: 19 mph.
        Weapon: A mega-powerful hammer. The entire hammer is made of hardox, and the hammerhead is shaped like the Judge's hammer. Powered by a couple of CO2 tanks @ 500PSI, and is able to immolate aluminum, terrorize titanium, penetrate weak hardox. But who knows, it might even knock something loose inside of the victim.
        Srimech: Hammer, duh.
        Strengths: The Hammer, Pushing Power is really good, too.
        Weaknesses: So-So Turning.
        Lancelot
        Weight: 400kg
        Shape: Invertible Box ala Tornado (Series 4)
        Colour: Metallic Silver
        Dimensions: 130 X 100 X 47
        Power: 2 X LEM-130's @ 36v, powered by a couple of NiCad's, shock mounted
        Tracks: Stainless Steel Tracks, with polyurethane rubber on it.
        GC: 5mm Everywhere
        Armour: 6mm Hardox Everywhere except for underbelly which is 15mm Titanium
        Top Speed: 20mph
        Weapon: A set of Horizontal Claws powered by a Vivoil pump running off a S28-400, and tungsten-coated to induce some severe damage. On the rear, it has a chromium coated spike powered by 4 X 2.5kg Nitrogen tanks. It will probably have 45 jabs to it, and it can make lots of holes in titanium and dent hardox without any problems at all.
        Srimech: None, but Invertible; side cones stop it from getting beached
        Strengths: Very powerful Weapon. Pushing power is also good
        Weaknesses: So-so turning?
        Gorgon
        Weight: 500kg
        Shape: Rollover Shape with low front wedge and fangs, and with a Medusa's head painted on each side.
        Colour: Camouflage tone of Chartreuse, Khaki, and Lime Green. It's so damn disgusting, you could almost puke...
        Dimensions: 120 X 10 X 27
        Power: 2 X LEM-130's @ 48v, powered by many NiCad's, shock-mounted
        Wheels: 4 X Vulkalon Coated Aluminium Tyres
        GC: 6mm Everywhere except the front, which is 0mm
        Armour: 5mm Hardox
        Top Speed: 15 mph
        Weapon: Crushing fangs made of hardox, and powered by an M-Mac M40 Actuator. The front wedge also has some barbs to trap other robots.
        Srimech: It rolls over onto its wheels every time it gets flipped over.
        Strengths: Extremely good weapon, can chew through almost anything (except for thick hardox)
        Weaknesses: ???
        King Arthur
        Weight: 750kg
        Shape: Box with a front Growler-like jaw, and a crown on top.
        Colour: Gold for the top and bottom, Silver for the front and back and Bronze for the sides
        Dimensions: 130 X 100 X 44
        Power: 2 X LEM-130's @ 36v, powered by several NiCads.
        Tracks: Vulkalon Coated Titanium Tracks
        GC: 0mm on the front, 5mm anywhere else
        Armour: 7mm Hardox Monocoque
        Top Speed: 10 mph
        Weapon: On the back, there is a huge vertical flywheel that is powered by a LEM-200, and spinning at 6000RPM. On the front, there is a set of vertical jaws (Think Growler, but much more powerful), powered by a Vivoil Pump running off a S28-400. It has 12 tungsten-tipped teeth inside the jaws to cause maximum damage.
        Srimech: None!
        Strengths: Good all-rounder.
        Weaknesses: No Srimech! :O
          Personally I don't like extremely over the top house robots. With at least four of yours I can see their weapons - if they work as well as you have described - will almost completely disable any robot that comes into contact with them due to the energy levels or power involved. This means if I am in one of your tournaments, all I have to do is push my opponent into one of those things and that's the fight over, no demonstration of weaponry or anything other than pushing power, and it basically turns the fights into glorified sumo. This may be what you're aiming for - I don't know - but personally I prefer writing with house robots that look good and are good to write the actions of, but that don't really change the outcome of the battle they're in much. (This was basically the role of the RW house robots at first, Ivanhoe vs. Killdozer aside)
          That is just my opinion though, they're your machines.
          As for technical things:
          Head Smash:
          - 'immolate' refers to burning things as far as I'm aware, how you're going to set fire to things with a hammer is beyond me.
          - How is the hammer powered? It's all very well saying you have some CO2 tanks, but what do they do...there are several ways you can use a pneumatic ram to make a hammer move, you can have it connected directly (Hell's Angel, although that uses rotary rams), through a linkage (Shunt, Dominator 2, Obsidian before Leo & Mario got hold of it, Splinter), through a chain or similar drive onto the weapon (Killerhurtz, Wedgehog), through the ram just hitting the axe (Iron Awe 1, SJ, and I believe Major Damage may have this as well), or through rack and pinion (Terrorhurtz, The Judge, Obsidian post-Mario & Leo). Since you don't even state a ram, there's nothing to stop me assuming that you're not just venting the CO2 in the general direction of the axe and hoping it falls down.
          Lancelot:
          - Pneumatic spikes are not effective dealers of damage. Aaron (I think) said before that unless you're doing something extremely strange to make the spike go REALLY fast (and I mean faster than what you'll get out of an ordinary pneumatic ram) you have no hope of penetrating the armour used on most of the top robots nowadays. Aluminium, maybe, titanium not unless you're dealing with very thin sheets, and Hardox...nah. So I'd revise your expectations as to what the spike will do :P
          King Arthur:
          - how much does the flywheel weigh? Teeth? You're normally good at providing these things...
            Can i just add something please......
            Lems on anything over 300kg is a no no. They are powerful motors yes but wouldnt last long in house robots. What you need is the good old Etek on 48v minimum. 750kg robot with 2 lems on 36v will be usless so your housy housy robot wont be doing much damage at all only to itself.
            I might be wrong but i dont think i am.
              S28 400 on 200kg robot is not good either
                I agree with Swanny. You will need either more motors distributing the load, or much better suitable motors.
                  Here is the revised version.
                  Mangled Metal
                  Weight: 200kg.
                  Colour: Green.
                  Power: 2 X LEM-130's @ 36v powered by several NiCad's, shock mounted.
                  GC: 6mm Everywhere.
                  Top Speed: 10 mph.
                  Weapon: 59kg Ring Spinner powered by a LEM-200, with 3 X 3kg Pussycat style blades and spinning at 1300RPM. Shock-Mounted to protect itself from its own blows.
                  Mind-Bender
                  Weight: 250kg.
                  Power: 2 X LEM-130's @ 36v, powered by several NiCad Batteries, Shock-Mounted.
                  GC: 5mm Everywhere.
                  Weapon: Get this. A 59kg Whyachi style Spinning Cage powered by a LEM-200. This spins at 1500RPM, and has 3 X 1kg hardox claws to wreak havoc. Heavily Shock-Mounted, as well. Can you say, OUCH?!
                  Head Smash!
                  Weight: 300kg.
                  Power: 2 X E-Tek's @ 48v, powered by several NiCad Batteries.
                  Top Speed: 19 mph.
                  Weapon: A mega-powerful rack and pinion hammer. The entire hammer is made of hardox, and the hammerhead is shaped like the Judge's hammer. Powered by a couple of CO2 tanks @ 500PSI, and is able to obliterate aluminum, terrorize titanium, penetrate weak hardox. But who knows, it might even knock something loose inside of the victim.
                  Lancelot
                  Weight: 400kg
                  Dimensions: 130 X 100 X 27
                  Power: 2 X E-Tek's @ 48v, powered by a couple of NiCad's, shock mounted
                  GC: 5mm Everywhere
                  Top Speed: 20 mph
                  Gorgon
                  Weight: 500kg
                  Dimensions: 120 X 100 X 27
                  Power: 2 X E-Tek's @ 48v, powered by many NiCad's, shock-mounted
                  Armour: 5mm Hardox
                  Top Speed: 15 mph
                  Weaknesses: ...
                  King Arthur
                  Weight: 750kg
                  Dimensions: 130 X 100 X 45
                  Power: 2 X LEM-200's @ 60v, powered by several NiCads.
                  Top Speed: 10 mph
                  Weapon: On the back, there is a huge 32kg vertical flywheel that is powered by a LEM-200, and spinning at 6000RPM. On the front, there is a set of vertical jaws (Think Growler, but much more powerful), powered by a Vivoil Pump running off a S28-400. It has 12 tungsten-tipped teeth inside the jaws to cause maximum damage.
                  Srimech: None!
                  Strengths: Indestructible.
                    Okay. Time to get started on my revised robots.
                    Roveress Evo
                    Weight: 100kg
                    Shape: Biohazard, with Growler's head at the front.
                    Colour: Brown, with black and white splotches in some places.
                    Dimensions: 95cm x 65cm x 30cm
                    Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
                    Locomotion: 4 foam filled wheels.
                    Armour: 6.5mm Titanium/Vanadium alloy.
                    Speed: 21mph
                    Ground Clearance: 0mm at front due to wedge, and at sides and back due to skirts. 5mm at sides and back without skirts.
                    Turning Circle: 0m
                    Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge with Mute-style barbs on it. Once a robot is stuck on the wedge, the top Jaw, powered by a 2.2kg 1000psi Nitrogen tank, comes down with over 2 tonnes of force.
                    Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
                    Strengths: Fast and maneuverable.
                    Weaknesses: The Srimech doesn't always work.
                    Side Swipe 2
                    Weight: 100kg
                    Shape: Panic Attack (S2) with a Tornado style wedge on the front
                    Colour: Silver
                    Dimensions: 90cm x 65cm x 35cm
                    Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
                    Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
                    Armour: 7mm Titanium/Vanadium alloy
                    Speed: 20mph
                    Ground Clearance: 0mm at front due to wedge, at back and sides due to skirts. 5mm at back and sides without skirts.
                    Turning Circle: 0m
                    Weapon: A titanium 5kg 70cm-in-length spinning bar that spins at 2000rpm, powered by an S28-400 Magmotor. The robot has shock proofing to absorb the punishment dealt out by this weapon.
                    Srimech: Invertible
                    Strengths: Powerful weapon and good ground clearance.
                    Weaknesses: Not the most reliable bot.
                    El Camino
                    Weight: 100kg
                    Shape: Invertible Cylinder
                    Colour: Red. The teeth are painted gold.
                    Dimensions: 80cm x 80cm x 25cm
                    Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
                    Locomotion: 2 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
                    Armour: 5.2mm Hardox
                    Speed: 18mph
                    Ground Clearance: 5mm all around.
                    Turning Circle: 0m
                    Weapon: The body spins around at 2000rpm, powered by an E-Tek, and has 4 Hardox teeth approximatly 6cm above the ground.
                    Srimech: Invertible
                    Strengths: Deadly weapon!
                    Weaknesses: Quite unstable.
                    Bubble Blaster
                    Weight: 100kg
                    Shape: Dreadnaut XP-1 (S4)
                    Colour: Blue. The Crusher is Silver.
                    Dimensions: 90cm x 60cm x 50cm
                    Drive: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
                    Locomotion: 4 Vulkanized rubber wheels.
                    Speed: 20mph
                    Ground Clearance: 0mm all around due to skirts. 5mm without skirts.
                    Turning Circle: 0m
                    Weapon: A very big 3000psi Titanium/Vanadium alloy crusher. Powered by a Vivoli pump motor, it can come down with over 6 tonnes of force.
                    Srimech: The domed shape will help it self-right. If that fails there is always the S28-400 Magmotor powered self-righting arm built into the back of the robot.
                    Strengths: Tough Armor and speed for a robot of its shape.
                    Weaknesses: Not very maneuverable.
                    Minesweeper
                    Weight: 100kg
                    Shape: Tornado (S6)
                    Colour: Silver, with MINESWEEPER written on the sides in red.
                    Dimensions: 90cm x 85cm x 25cm
                    Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
                    Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
                    Armour: 6mm Hardox
                    Speed: 20mph
                    Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
                    Turning Circle: 0m
                    Weapon: 2 Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at front and back.
                    Srimech: Invertible
                    Strengths: Super-reliable and fast.
                    Weaknesses: Not too much of an offensive weapon.
                    Cyrilium Mach 3
                    Weight: 100kg
                    Shape: Mortis (S4)
                    Colour: Gold
                    Dimensions: 100cm x 70cm x 30cm
                    Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
                    Armour: 5.5mm Hardox
                    Speed: 20mph
                    Ground Clearance: 0mm at front, and 5mm everywhere else.
                    Turning Circle: 0m
                    Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
                    Weapon 2: A flipping arm, powered by a 1.5kg C02 tank at 750psi. It can lift up to 250kg.
                    Srimech: The flipping arm.
                    Strengths: Twin weapons.
                    Weaknesses: Unreliable.
                    Trojan/Virus/Worm (TVW for short)
                    Shape: Biohazard
                    Dimensions: 95cm x 65cm x 25cm
                    Weight: 100kg
                    Speed: 20mph
                    Ground Clearance: 0mm all around due to skirts, and 5mm without.
                    Colour: Black
                    Turning Circle: 0m
                    Locomotion: 4 solid rubber wheels mounted internally.
                    Power: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
                    Armour: The skirts are 4mm titanium, while the body armour is 6mm titanium.
                    Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
                    Srimech: Due to the power of the axe, the robot can easily self-right.
                    Notes: Has lots of shockproofing to prevent shock damage.
                    Strengths: Fast axe to do a lot of damage in a short amount of time.
                    Weaknesses: Not tough enough to withstand a beating from a major spinner.
                    Interstate
                    Weight: 100kg
                    Shape: El Diablo (Battlebots Series 2.0)
                    Colour: Blue, with I-35 written on the top.
                    Dimensions: 90cm x 65cm x 30cm
                    Drive: 4x LEM-130 motors, powered by 6x NiCad Battlepacks.
                    Locomotion: 4 fully Vulkanized rubber wheels
                    Armour: 8mm Titanium/Vanadium alloy
                    Speed: 19mph
                    Ground Clearance: 0mm at sides and back due to skirts, 5mm without skirts, usually 5mm at front.
                    Turning Circle: 0m
                    Setup 1: A 10kg solid Hardox wedge at the front, 0mm ground clearance, designed to kill spinners where they stand.
                    Setup 2: a 5kg drum, with 10 tiny Hardox teeth, powered by an LEM-200 at 2000rpm, at the front.
                    Srimech: invertible
                    Strengths: I have a choice of weapons.
                    Weaknesses: Too maneuverable, can sometimes get out of control.
                    Ninjoid Evo
                    Weight: 100kg
                    Shape: Tornado Mer with a skirt around the bottom.
                    Colour: Black, with red on top.
                    Dimensions: 95cm x 95cm x 25cm
                    Drive: 4x S28-400 Magmotors powered by 5x NiCad Battlepacks.
                    Speed: 20mph
                    Ground Clearance: 0mm with skirts, and 5mm without skirts.
                    Turning Circle: 0m
                    Weapon: A 1.25m 140kj 4000rpm titanium blade, powered by a Combatparts 6-mag gearbox with 6 S28-400 Magmotors. The robot has lots of shockproofing to counteract the force of the blade.
                    Srimech: The force of the blade can cause it to right itself after a flip. Sort of like Mauler, except it cannot be stranded on its back.
                    Strengths: Very dangerous.
                    Weaknesses: Can flip. The inertia is not always strong enough to flip it back over.
                    Corsair
                    Weight: 100kg
                    Shape: All Torque (Series 2) with a wedge at the front.
                    Colour: Gold, with a black stripe down the middle, and CORSAIR written on the sides.
                    Dimensions: 95cm x 70cm x 25cm
                    Locomotion: 4 internally mounted fully Vulkanized rubber wheels.
                    Speed: 17mph
                    Ground Clearance: 0mm at front due to wedge, 5mm at sides and back.
                    Turning Circle: 0m
                    Weapon: a 12mm titanium wedge, mounted on the front.
                    Srimech: an pneumatic flipping arm, built into the back of the robot, powered by a 1.5kg C02 tank at 750psi.
                    Strengths: At least half-tough.
                    Weaknesses: Quite slow for a vapour.
                    Armory
                    Weight: 99kg
                    Shape: Big rectangular prism with a wedge at the front.
                    Colour: Yellow, with blue on the top and bottom.
                    Dimensions: 90cm x 50cm x 25cm
                    Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
                    Speed: 20mph
                    Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
                    Turning Circle: 0m
                    Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
                    Srimech: Invertible
                    Strengths: Tough, with a dangerous weapon.
                    Weaknesses: Turns too fast.
                    Tenderizer
                    Weight: 100kg
                    Shape: Imagine Hell's Teeth, with a wedge on the front, and with Thor's Hammer.
                    Colour: Black
                    Dimensions: 100cm x 50cm x 25cm
                    Locomotion: 2 Vulkanized rubber wheels at the front, and a caster at the back.
                    Speed: 19mph
                    Turning Circle: 0m
                    Weapon: A Thor style rack and pinion hammer, with a 2kg meat tenderizer for a hammer head,
                    powered by a 2kg C02 tank at 200psi, It can come down with about 1000kg of force, and easily pierce 5mm titanium.
                    Srimech: The axe can easily self-right the robot.
                    Strengths: Crushing Weapon and tough armour.
                    Weaknesses: None that i can think of, yet.
                    Any idea on how to improve these bots?
                      Thats alot of bots Mark and Im not gonna look at all of them at once, if you tell me your 2 or 3 favourites I'm gonna have a better look at them ok?
                        Minesweeper, Side Swipe 2, and Cyrilium Mach 3.
                        EDIT: And surprisingly, the original Side Swipe was a ripoff of your Sheer Heart Attack 2.
                          Minesweeper: Ditch the Bosches...despite their frequent use in real world bots they're not really viable for vapours due to their weight and relatively low power. (damn us being so overkill in fanfic that 11hp isn't enough ) I did a table here that shows the weight and size of some motors, and for a rammer I'd go for four S28-400s at 24v or two LEMs of some kind at 36v, giving you more power for quite a bit less weight than the Bosch 750s.
                          Side Swipe: ...where's the bar? :P Also you haven't stated what voltage the motors run at, I assume it's 24v but we don't know.
                          Cyrilium Mach 3: Looks overweight to me...you have four Mags on four wheel drive, quite thick Hardox, one full pressure weapon, and one low pressure weapon...one of those does not belong, possibly two of them.
                          Also the weapons could do with a bit more description - most stats for axes state what sort of mechanism the axe works on, and I've mentioned before that estimates for precise thicknesses of armour are a bit useless really.
                          I haven't looked at the others in detail yet but the one with the ten Magmotors in is definitely overweight XD
                            Revised it according to Joey.
                            Side Swipe 2
                            Weight: 100kg
                            Colour: Silver
                            Drive: 2x 24v S28-400 Magmotors, powered by 5x NiCad Battlepacks.
                            Speed: 20mph
                            Turning Circle: 0m
                            Weapon: A titanium 5kg 70cm-in-length spinning bar on top of the robot, that spins at 2000rpm, powered by a 24v S28-400 Magmotor. The robot has shock proofing to absorb the punishment dealt out by this weapon.
                            Srimech: Invertible
                            Minesweeper
                            Weight: 100kg
                            Shape: Tornado (S6)
                            Drive: 2x LEM-130 motors, powered by 6x 36v NiCad Battlepacks. The wheels power the 2 middle wheels.
                            Locomotion: 6 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
                            Armour: 6mm Hardox
                            Speed: 20mph
                            Turning Circle: 0m
                            Srimech: Invertible
                            Strengths: Super-reliable and fast. Now more maneuverable.
                            Cyrilium Mach 3
                            Weight: 100kg
                            Shape: Mortis (S4)
                            Colour: Gold
                            Drive: 2x LEM-130 motors, powered by 6x 36V NiCad Battlepacks.
                            Armour: 5mm Titanium
                            Speed: 20mph
                            Turning Circle: 0m
                            Weapon 1: A diamond tipped pneumatic axe, powered by a 200psi 1.75kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
                            Weapon 2: A flipping arm, powered by a 1.75kg C02 tank at 750psi. It can lift up to 250kg.
                              That creates another problem though, if the bar's on the top how is the robot invertible? :P
                              Also you haven't addressed the issue of axe mechanisms in Cyrilium, the armour's fine but knowing how the axe works would be useful.
                                Fixed it.
                                Side Swipe 2
                                Weight: 100kg
                                Colour: Silver
                                Speed: 20mph
                                Turning Circle: 0m
                                Weapon: A titanium 5kg 70cm-in-length spinning bar at the front of the robot, that spins at 2000rpm, powered by a 24v S28-400 Magmotor. The robot has shock proofing to absorb the punishment dealt out by this weapon.
                                Srimech: Invertible
                                Cyrilium Mach 3
                                Weight: 100kg
                                Shape: Mortis (S4)
                                Colour: Gold
                                Speed: 20mph
                                Turning Circle: 0m
                                Weapon 1: A diamond tipped pneumatic axe, powered by a 200psi 1.75kg C02 tank, driven by a 70mm bore, 150mm stroke ram. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
