How could I Improve pt 2
This is a sticky topic.
  • How could I Improve pt 2
    they come to a line much like Terrorhurtz. they do less damage but still make a nice clamper
    Ive aslo considered yet another possibility, will CAD that and post it too
      Just an idea:
      Shape: A 3-D Semi-Circle
      Colour: Shiny Black
      Speed: 12 MPH
      Weight: 110KG
      Armour: 4MM Titanium
      Drive: 2 C40-300 Magmotors @ 36V geared for torque
      Power: 6 NiCad Battlepacks @ 36V
      Locomotion: A pair of small titanium tracks with an Asmaprene/Vulkalon/Urethane coating and imbedded screws
      Ground Clearance: 2MM
      Turning Circle: 0
      Weaponry: 2 pairs of beetle-like crushing claws, one at the top one at the bottom, they only generate 3 tons at the tip but they can each turn 180 degrees and rip robots in two
      Srimech: Invertible, but can use the arms
      Strengths: Poweful weapons, Good Pusher
      Weaknesses: Slow, Thin Armour
        Things wrong with it:
        1. You dont need the screws, thats what will kill the grip given by the rubber coating.
        2. Why do you need 2 pairs? One pair would certainly be sufficient.
        Otherwise, good.
          I am guessing, correct me if I am wrong Ben, that he wants to clamp down with the top and bottom claws, and then have 1 pair moving in one direction and the second pair in the opposite direction in an attempt to rip the robot apart.
          Its a nice idea, but it wont work that way. you would have to generate so much force to achieve that goal that your claws would bend and snap sooner than the opponents armour would buckle under the strain.
            Also the 2 mm GC is too low. The coating only has to be worn away by 2 mm to completely ground your machine, plus when youre too low any shrapnel in the arena makes things difficult for you. I consider a 5 mm GC to be the absolute lowest you should go without skirts. Spinners need more because they generate a lot of shrapnel, or at least they should if theyre designed well
              Also do you intend for the 2 pairs of claws move away from each other in horizontal or vertical motion? AKA one pair moves to the left and another koves to the right OR one pair moves up and the other... down?
              Im guessing the latter since you say the claws help selfrighting, I fail to see how your bot is invertible then though, I guess with 3d semi-circle you mean a sphere cut in halve?
                I think something like this.
                http://www.insaneclown.nl/images/robobeetle.jpghttp://www.insaneclown.nl/images/robobeetle.jpg
                  in that picture the claws wouldnt be able to turn 180 degrees like the stats say leo
                    Once they are closed he could.
                    The other option would be
                    http://www.insaneclown.nl/images/robobeetle2.jpghttp://www.insaneclown.nl/images/robobeetle2.jpg
                    But then you would lose a lot of space inside and it would not be invertable.
                      I think the first option is right and remain wondering why it can use the claws as a srimech.
                      Actually Ben Ive been playing around with ideas like this but the thruth is youd tear your weapon apart rather than your opponent, I most likely. Ive never been able to find a way around this.
                      Random note; Im busy on Robo-Hedgehog but still dont really understand the curved teeth. Are they like Mutes and placed on top of the robot? If so then your robot would not be invertible (without the axe) like you stated.
                        Mobile Failure
                        Shape - Box wedge
                        Colour - Pale purple
                        Weight - 100kg
                        Motors - Those LEM130s running on 36 volts
                        Wheels - 4 go-kart style wheels
                        Speed - 16mph
                        Clearance - the wedge has no clearance, and the sides have 3mm titanium skirts so its 0 there too. Without skirts theres 5mm of clearance
                        Armour - 6mm titanium and for the bottom its 6mm polycarbonate
                        Dimensions - 105cm x 75cm x 20cm
                        Weapons - A titanium axe, using a rack-and-pinion mechanism, powered by 2 2kg CO2 tanks and fed off a 110mm x 20mm pneumatic ram...whew!
                        Srimech - The axe!
                        Good? Bad?
                          Hi Tracy,
                          Two things.
                          20cm high is very low. specially if you want to put pnuematics in there. make it a little higher please, like 30cm or so.
                          Either your ram is very wide and very short (4 wide, 0.7 short), or very narrow and still a bit short (0.7 wide and 4 short). Either way not very suitable for an axe. Also at what pressure will you be operating the axe?
                          As a reference, this is my axe:
                          120mm bore (wide), 200mm stroke (long), running on CO2 at 16 bar. That gives me 1800kg of force on the ram when it pushes, and 1700kg on the return. That is because there is the rack that slides in and out the ram that takes up space where on the other side there is gas. So one end of the ram is less powerful than the other. On the other hand it fills more quickly since it needs less gas.
                          Hope this helps.
                            Thanks Leo. It did indeed help.
                            Mobile Failure
                            Shape - Box wedge
                            Weight - 100kg
                            Motors - 2 LEM130s running on 36 volts
                            Speed - 16mph
                            Dimensions - 105cm x 75cm x 30cm
                            Weapons - A titanium axe, using a rack-and-pinion mechanism, powered by 2 2kg CO2 tanks and fed off a 210mm x 125mm pneumatic ram. Running at 250psi.
                            Srimech - The axe!
                            Are the edits acceptable?
                              Not bad at all, Tracy.
                                You might want to run the axe at a higher pressure, 1000 PSI would qaudruple the damage
