How could I Improve pt 2
This is a sticky topic.
  • How could I Improve pt 2
    So the horizontal claws of Hector managed to pierce though the Hardox side armour of Crooked to manage to get a hold of the battery to pull it out of the same side hole in the Hardox armour?
      Do you guys mind if I interrupt the conversation and show you my latest creation....?
      Pesticide
      Weight: 100kg
      Shape: Hexagon
      Colour: Emerald Green
      Dimensions: 100 X 75 X 32
      Power: 2 X LEM-130€™s @ 36v powered by 90 X NiCad Cells
      Tyres: 2 X Tightly Foam Packed, Asmaprene Urethane Rubber Tyres
      Armour: 3.5mm Hardox 600 Everywhere
      Ground Clearence: 5mm Everywhere
      Turning Circle: Zero, with tank style steering
      Weapon: A nasty 27kg Titanium spinning disc, simillar to Matilda€™s, (Only this time, its horizontal) powered by a LEM-130. The teeth are shaped like Hypnodisc (Series 4 version)s tooth, and are made out of hardox. This baby can spin at 3000RPM, and deals out 74 kJs. Plenty of Shock-Proofing, as well.
      Srimech: Invertible
      Strengths: Deadly Disc, INSANE Pushing Power
      Weaknesses: Wheels Exposed, although extremely sturdy.
      Can anyone check this?
        Samuel,
        I need a little more info. how big is the disk, and where does it mount on the hexagonal robot (partly in partly out, or on an A frame outside the robot)?
          Pesticide
          Weight: 100kg
          Shape: Hexagon
          Weapon: A nasty front (partly in) 27kg Titanium spinning disc, simillar to Matilda€™s, (Only this time, its horizontal) powered by a LEM-130. This disc is 38cm in diameter. The teeth are shaped like Hypnodisc (Series 4 version)s tooth, and are made out of hardox. This baby can spin at 3000RPM, and deals out 74 kJs. Plenty of Shock-Proofing, as well.
          Srimech: Invertible
            Ive not checked the KJ count, but apart from that Id say you need to get the weight down.
            Armour 40 kg
            LEMs 9 kg
            Disc 27kg
            Batts 6 kg
            Wheels and gears 10 kg
            For Mounts, electronics etc. 8 kg is not much, and you need twice the amount of cells you have now really.
            Given the dimensions you gave on the disc, it would be 5 cm thick. you could halve that, making the disc somewhere around the 15kg mark (it would still be 1 or 2.5cm thick), and use the remaining kgs for batteries and mounts etc.
            (Message edited by leorcc on August 21, 200
              Add to the fact that a hexagon is a 2D shape...
                Well I calculated it as a hexagon prism with 1 side missing for the disc to poke trough.
                  Fragmentor was cloned AGAIN?
                    Pesticide
                    Weight: 100kg
                    Shape: Hexagonal Prism
                    Power: 2 X S24-800€™s @ 36v powered by 90 X NiCad Cells
                    Srimech: Invertible
                    Strengths: Deadly Dusc
                      quote:
                      S24-800€™sNever heard of them before.
                        Is it me or did you just make it heavier instead of lighter?
                          Only the motors changed, he did squat for the rest...
                            Pesticide
                            Weight: 100kg
                            Power: 2 X S28-400€™s @ 36v powered by 4 X NiCad Packs
                            Armour: 3.25mm Hardox 600 Everywhere
                            Weapon: A nasty front (partly in) 23kg Titanium spinning disc, simillar to Matilda€™s, (Only this time, its horizontal) powered by a LEM-130. This disc is 38cm in diameter. There are two teeth, and they are shaped like Hypnodisc (Series 4 version)s tooth, and are made out of hardox, and each weighs about 1kg. This baby can spin at 3000RPM, and deals out 74 kJs. Plenty of Shock-Proofing, as well.
                            Srimech: Invertible
                            (Message edited by samuel3764 on August 22, 200
                              I would have liked to have seen more batteries in there. Right now you have the bare minimum for the 2 magmotors, but you still have a Lem to feed as well.
                              Apart from that I think you will be ok.
                                the lem will be surprisingly easy to run. it wont use that much power when spun up. might take a bit to get started tho but as long as its spinning it shouldnt use up that much power. envy runs 3 nicad pacs and can run a 3 min fight with ease using mag c40 motors.
