How could I Improve pt 2
This is a sticky topic.
  • How could I Improve pt 2
    quote:
    I just need to release my creativity
    Ok, if you have 1001 ideas in your head and want to realize all of them, I wont stop you. If the most important part of this game is to do just that, than be my guest and go ahead. I must add this is really comon for people your age
    quote:
    I just want to say That was my idea
    You can still say that even if youd take my advice. Only with my advice they will be realized in a better, more thought out way. Like I said, if you wish to realize ALL your ideas, please continue the way youre going now. Just remember most of this ideas will never shine outside the stats database.
    quote:
    Or thats my robot, the one that has just won E.O.T.R or Mechanical Noise or C&B3
    Ah, heres the one thing where you totally miss the point. You see, if youd concentrate on making GOOD robots rather than LOTSA robots, odds youll ever win a tournament like that will rise drastically. That was what my advice was all about.
      My robots are good!
        Yes, of course you say theyre good. Thing is, Ben, you enter these bots into tournaments where other people decide which bot is better and in which situation. They have very different opinions than yours, and are very experienced in their decisions. To put it straight, I doubt most tournament writers would think that much of the bots you claim to be good.
        Please, Ben, youre not going in a good direction. Do us a favour, and listen to more advice.
          easy boy, I never said they were bad, geez
          what I have been trying to say in a completely polite way all night is the following, read along
          1) Out of the 20+ robots youll soon have, over 50% may never see the arena.
          2) Perhaps you have now spend 16 hours to make 17 robots (that time-frame is completely random) IF you would have spend that same amount of time to make 8 robots, you could:
          a) Actually USE all of your robots
          b) Spend more time on each robot, perfecting them along the way.
          What I see now in your squad is that you kinda know what youre doing but still need some direction, things like paintball guns, 3 mm titanium armour, claiming a spike, 2 saws and a paintball gun offer good weaponsynergy (all 3 weapons are nearly useless), using hardened steel blades or I forget, will post later, forgetting a spinners rpm are just some things that show you have some things to learn, which is perfectly normal for someone as new as you are.
          For one thing you are BETTER than most people who are as new as you. Now dont go all defensive and just think of the advantages of what I just said.
            Ben, read our entire posts. Were trying to HELP you not put you down, as Martijn explained.
              Right. Throwing this out here now, some very rough stats here:
              Troubloon 6 (previously Aftershock)
              Shape: Box wedge with inverted wedge at rear.
              Weight: 100kg
              Armour: 7.5mm Titanium Vanadium alloy with a 4mm polycarbonate laminate. The side skirts are made of 5mm Grade 5 titanium.
              Drive: 2 D-Pack motors @ 24v
              Power: 8 A123 Li-Ion packs, should get in the realm of 24v
              Motivation: 2WD, the usual urethane rubber-pressed titanium wheels.
              Ground Clearance: 0mm at front wedge under the front disc, the discs clearance is 10mm. The sides have 15mm ground clearance without skirts but 0 mm when skirted. The rear is 25mm.
              Rough dimensions in CM = 85 x 65 x 15
              Weaponry: Two horizontal 15kg titanium spinning discs run by a separate D-Pack motor each @ 24v. They spin at 2000rpm and dish out around 55kJ each. Will calculate properly later. The thing is that the front disc is as close to the ground as possible while the rear one is as high up as can be so when Troubloon is flipped, the rear one gets close to the ground.
              Srimech: Invertible.
              ROUGH WEIGHT CHECK
              Armour/Chassis = ~25kg
              Motors = 7.8kg (I think, I seem to recall the motor weigh 3.9kg each)
              Batteries = 5.6kg
              Wheels, gears, and other drivetrain stuff = ~6.6kg
              Weaponry and power = ~45kg
              Rest = ~10kg
              Pointers and constructive criticism are appreciated. Destructive criticism will earn you a Hardox mace to the head. :P
              (Message edited by kodster on August 06, 200
                Dear Kody,
                Given the data supplied I do not believe that the armour and chassis together weigh 25kg. could you please check your numbers again?
                Is that better Martyn?
                (Message edited by leorcc on August 07, 200
                  Leo, i hate to sound bitchy but, you are someone who has built an actual robot, and you are, our moderator, how about saying something a little more helpful than quote:
                  no way that that armour and chassis weigh 25kg.
                    Eh, I didnt take that as too rude. Mkay, Leo, lets see, I can lessen the armour but that will still be more than 25kg...how about I downgrade the weaponry...
                    MODIFICATIONS
                    Armour: 6mm Ti/V alloy with a 3mm polycarbonate laminate
                    Chassis: 3mm steel ladder
                    Weaponry: Two horizontal 12.5kg titanium spinning discs run by a separate D-Pack motor each @ 24v. They spin at 2000rpm and dish out around 50kJ each. Will calculate properly later. The thing is that the front disc is as close to the ground as possible while the rear one is as high up as can be so when Troubloon is flipped, the rear one gets close to the ground.
                    WEIGHT CHECK MODIFICATION
                    Armour/Chassis = ~30kg?
                    Weaponry and power = ~40kg
                    All right?
                      Able to explain this further?
                      Also, 4 D-Pack motors are going to fry those batteries, they can easily pull 500amps each... A123s are only good for a peak of around 120amps and constant 60amps. To satisfy your hungry motors, youll want at least 20 packs (maybe more) in parallel. Advice, run a single D-pack for the weapons, and replace the drives with S28-400 magmotors.
                        Yes, steel ladder chassis is a type of body-on-frame, on which the body is mounted to a rigid frame which supports the drivetrain. Its used in automobiles and is quite successful.
                        As for the rest, I will take your advice except...quote:
                        run a single D-pack for the weaponsThis tells me you think Im running the discs as one. Theyre separate.
                        Once you clear that up for me, Ill sort the stats out, all righty?
                          I am now going to concentrate on improving my vapours, so if my robots have any flaws please tell me
                            You kinda using the steel ladder chassis in a fashion that its something new or special. In the end, its a chassis, regardless of construction technique. Ladder & Space frames are used in bots quiet a lot, but in the end, they are all coined under the same name, chassis. Storm 2 uses a ladder chassis, Warhead uses space frame, Firestorm uses monocoque.
                            If you have a sectional frame with armor bolted on, its a chassis, if your armor is all welded together to form the body, its a monocoque :P
                            Link for ya http://www.autozine.org/technical_sc...hassis.htmhere
                              Martyn, sorry but I dont agree. Specially Kody should know better than come up with 25kg for armour and chassis with a robot that size and armour that thick. I for one think that Kody doesnt need more help than that, he will do fine by number crunching and changing stats on his own. Its not like he started building vapours 2 weeks ago.
                              @kody, can you make me a drawing of the shape of Troubloon 6? It would give me a better insight in the shape and therefore the weight that goes along with it.
                                Itd be alot more effective if youd pick your best/most precious/most creative/favourite etc vapourbots among your squad. A diverse team of axes/spinners/flippers/rammers/crushers etc would be nice, but dont forget its YOUR team :wink:
                                once you decided the core members of your team, itd be easier for people to help you
