How could I Improve pt 2
This is a sticky topic.
  • How could I Improve pt 2
    Asmaprene Urethane rubber: more stronger type of urethane rubber, they provide excellent grip on all arena surfaces and are especially designed to be resistant to oil spills and other debris on the arena floor.
      And where did you find this info? Link or Im not keen on believing it.
        Fatality
        Weight: 100 kg
        Body Shape: Cone.
        Colour: Flourescent Blue Body with Turquoise and Green Teeth.
        Dimensions: 96 X 96 X 42 cm.
        Drive: 2 X S28-400€™s @ 24v powered by 4 X NiCad Batteries.
        Top Speed: 15 mph.
        Tyres: 2 X Vulkanized Tyres.
        Ground Clearence: 7mm all around. It has to be.
        Armour: 6mm Hardox FBS shell, 6mm Polypropylene Base.
        Turning Circle: Zero! Need I say more?
        Weapon: A very nasty 36kg, 1500RPM FBS shell with 2 X 2kg Hardox Teeth and small Tungsten Carbide-tipped teeth all around, powered by an LEM-130 @ 36v. This can reach top speed in 2 seconds, and brings out about 80kJ. The teeth are curved, jagged, and barbed. Has a buttload of shock proofing inside to stop it from self-destruction. Holes drilled into it to reduce weight.
        Srimech: An extremely blunt spike that comes out at the top, powered by 1 X 2kg CO2 Tank.
        Strengths: Deadly Weapon, Fast Srimech.
        Weaknesses: Weak Base Armour, able to shoot only 15 times with the srimech.
        Axetra
        Weight: 100kg
        Body Shape: Box with sloped sides and wedge, skirts all around.
        Colour: Steel Blue.
        Dimensions: 97 X 84 X 36.
        Drive: 2 X LEM-130€™s @ 36v powered by 5 X NiCad Batteries.
        Top Speed: 19 mph.
        Tyres: 4 X Vulkanized Tyres.
        Ground Clearence: Completely 0mm on the front due to wedge, 0mm with skirts, 5mm anywhere without skirts.
        Armour: 3.62mm Hardox 500.
        Turning Circle: (Seriously, does it need to be here?) Zero
        Weapon: A great big 9kg axe made of 3.25mm hardox. The gas is stored in 2 X 2kg tanks. It can easily penetrate titanium and also dent hardox. It brings out 200PSI, and 1000 Joules of force. When the axe fails to work, it can use its immense pushing power to ram other robots.
        Srimech: The axe can easily self-right the robot, and it can self-right even after the axe has been fired. It should also have enough power to pull the robot back over from its sides.
        Strengths: Lethal Axe, Awesome Pushing Power, Tough Armour, Nice and Fast.
        Weaknesses: Limited CO2.
        Mad Dash
        Weight: 100kg.
        Body Shape: Box with a front scoop.
        Color: Chartreuse Body, Pure Black Scoop.
        Dimensions: 100 X 90 X 36
        Drive: 2 X LEM-130€™s @ 36v powered by 4 X NiCad Batteries.
        Top Speed: 20 mph.
        Armour: 5mm Hardox for the scoop and 5mm Titanium for the rest.
        Ground Clearence: Completely 0mm on the front and 6mm anywhere else. (including sides)
        Turning Circle: Zero, what does it look like?
        Weapon 1: Static Scoop to deflect other spinners.
        Weapon 2: In the middle of the scoop, there is a Tornado-esque drum thingy powered by S28-150, spinning at 3220RPM.
        Srimech: Invertible, Side spikes prevent it from getting beached on its side.
        Strengths: Can run both ways up, EXTREME Pushing Power, Deadly Drum, Can get under anything, Shock-Proofed.
        Weaknesses: So-So Turning.
        Blade of Doom
        Weight: 110 kg.
        Body Shape: Box with Rear Wedge.
        Colour: Dark Blue with Turquoise Tinges.
        Dimensions: 99 X 88 X 33.
        Drive: 2 X LEM-130€™s @ 24v powered by 5 X NiCad Batteries.
        Top Speed: 15 mph average, 20 mph max.
        Tracks: Titanium Tracks with urethane rubber for superb grip, extremely hard to break.
        Armour: 3.3mm Hardox 600.
        Ground Clearence: Completely 0mm at the back and 5mm for the rest.
        Turning Circle: It€™s completely zero, and you should know that by now.
        Weapon: At the front there is a nasty 20kg Fluffy-Style Spinner (Horizontal) powered by a LEM-130 Lynch spinning at 4000RPM. The blade tips are sharpened, barbed and curved to cause max damage. The wedge at the back can also serve as defense for those nasty spinners, and if the blade fails to work, it can push robots around the ring.
        Srimech: Invertible, Side spikes prevent it from getting beached.
        Strengths: Very Destructive, Heavily Shock-Proofed, Good Control, Immense Pushing Power, Extremely Durable, Tracks Protected from all sides.
        Weaknesses: Tracks exposed from the top, even though they€™re EXTREMELY strong.
        Ramminator
        Weight: 100kg.
        Body Shape: Box with front concave scoop, and skirts all around.
        Colour: Prussian Blue.
        Dimensions: 100 X 77 X 27
        Drive: 2 X LEM-130€™s @ 36v, powered by 4 X NiCad Batteries.
        Top Speed: 22 mph.
        Wheels: 4 Inner, Tightly Foam-Packed Wheels, with Asmaprene Urethane on it.
        Armour: 5mm Hardox.
        Ground Clearence: 0mm at the front, 0mm anywhere with skirts, and 5mm anywhere without skirts.
        Weapon: This mainly relies on pushing power, but there is a diamond-tipped sawblade on the scoop powered by an S28-400, and spinning at 4000RPM.
        Srimech: Invertible. Side spikes keep it from getting beached.
        Strengths: Very Hard to get under, Immense Pushing Power.
        Weaknesses: Let€™s just say the wheels are a bit exposed.
        Bubonic Plague (was previously Black Death)
        Weight: 100kg.
        Body Shape: Wedge with Firestorm style wedge extention on the front and sloped rear.
        Colour: The main body and flipper is Black with Dark Purple Polka Dots, the disc is gray with blood red teeth.
        Dimensions: 100 X 70 X 35.
        Top Speed: 15 mph.
        Armour: 3.2mm Hardox 500.
        Ground Clearence: Completely 0mm on the front, rising to 6mm on the back.
        Turning Circle: *Sigh of Frustration*€¦ Zero.
        Weapon: At the front there is a Rear-Hinged Flipper powered by 2 X 80mm High Pressure Rams. It€™s capable of 32~38 flips or so before it starts weakening. At the back, there is an X-Terminator style vertical disc that weighs 13kg, powered by an S28-400. This has 3 curved and serrated teeth to rip, flip and toss and spins at 4000RPM.
        Srimech: Flipper, and side spikes prevent it from getting beached.
        Strengths: Deadly Disc, Powerful Flipper, Near Impossible to get under from the front, Immense Pushing Power.
        Walk Don€™t Run 3€˜n a half
        Weight: 110kg.
        Body Shape: Disc.
        Colour: Emerald Green Weapon, Snow White for top and bottom.
        Dimensions: 95 X 95 X 27.
        Drive: 2 X LEM-130€™s @ 36v powered by 3 X NiCad Batteries.
        Top Speed: 13 mph.
        Feet: 4 X Shuffling Pads with Asmaprene urethane rubber, and this prevents WDR from self-destruction.
        Armour: 6mm Hardox for the ring spinner, and 4mm Grade 5 Titanium for top and bottom.
        Ground Clearence: 5mm all around.
        Weapon: 30kg Ring spinner spinning at about 1300RPM, powered by a LEM-130, and has 6 X 1kg Hypno-Disc style teeth, curved, barbed and jagged to rip armour. This brings out about 125kJ, and if the spinner fails, it can use its INSANE pushing power to ram other robots to death. Its also heavily shock-proofed as well.
        Strengfths: Deadly Weapon.
        Weaknesses: Hates Flippers.
        Paralyzation 2
        Weight: 100kg.
        Body Shape: Low Box ala Tetanus Booster.
        Colour: Gold.
        Dimensions: 100 X 78 X 20.
        Top Speed: 15 mph.
        Wheels: 4 inner, Tightly Foam-Packed Wheels with Asmaprene Urethane on them.
        Armour: 3.4mm Hardox 500.
        Ground Clearence: 3.5mm all around.
        Weapon: 19 kg Drum powered by a LEM-130 Lynch, spinning at 5000 RPM. There are 8 teeth, which are all curved upwards and jagged to rip and flip opponents.
        Srimech: Invertible. Side spikes prevent it from getting beached.
        Strengths: Deadly Weapon, and a Great Pusher.
        Weaknesses: Exposed Tyres although very strong.
        If you see anything wrong with THAT, please let me know.
          I saw it on AJs forum.
            So? You can at least provide an accurate link to the page where you saw it. :P
              http://teamcode14.proboards24.com/index.cgi?board=Stats&action=display&thread=15http://teamcode14.proboards24.com/in...play&thread=15
                Right, then perhaps AJ can explain what this wonderful Asmaprene upgrade to urethane is, unless Leo would like to clarify?
                  And you didnt change Bubonic Plague at all? The weaponry kind of makes it overweight, and theres still no side ground clearance...well?
                    Weight: 100kg.
                    Top Speed: 15 mph.
                    Ground Clearence: Completely 0mm on the front, rising to 6mm on the back, and 3mm on sides.
                    Weapon: At the front there is a Rear-Hinged Flipper powered by 2 X 80mm High Pressure Rams. It€™s capable of 32~38 flips or so before it starts weakening. At the back, there is a SMIDSY-style disc (only this time, its vertical) that weighs 10kg, powered by an S28-400. This has 3 curved and serrated teeth to rip, flip and toss and spins at 5000RPM.
                      Right...
                      Rough weight check on Bubonic Plague:
                      Armour/chassis (plus extension, minus flipper) = ~40kg
                      Motors = 6.2kg
                      Batteries = 7.2kg
                      Wheels and gears and stuff = ~10kg
                      Flipper (including power and mechanics) = ~12.5kg
                      Disc (including power and mechanics) = ~20kg
                      Everything else = ~10kg
                      By my (very bad) calculations, you are overweight by about 6.2kgs.
                      If anyone wants to step in and clarify/correct me...?
                        quote:
                        Right, then perhaps AJ can explain what this wonderful Asmaprene upgrade to urethane is, unless Leo would like to clarify?http://www.asma.at/index.php?l1=11&l2=55http://www.asma.at/index.php?l1=11&l2=55
                        Google is your friend.
                        Basically it is a derivative of Polyurethane.
                          quote:
                          Right...
                          Motors = 6.2kg
                          Batteries = 7.2kg
                          With all the ~s youre using in this weight check its hardly fair to boldly state the robot will about 6 kgs off in your conclusion. If for every ~ you used your guess is about 1 kg off the robot suddenly is underweight
                            Paul, I had a look at Inferno on ZED earlier and couldn€™t help but notice some things I wanted to point out. First of all, is all the shock proofing really that necessary? 4cm of rubber seems to be a little bit over the top, even if you are trying to survive 140kJ of impact. 6mm Weldox might be pushing it slightly, but as nobody else has commented on that, you€™re probably fine. My next problem is that you are claiming due to the curving of the panels, the armour cannot be torn. Remember that nothing is impossible... :wink: Next up is the 30mm wheels - I am presuming this is a typo? I€™m pretty sure there are antweights with bigger wheels than that. Onto the disc€¦ why is it so thick? Also, €œteeth non-attached teeth€ doesn€™t make a lot of sense to me. Did you run the spinner through the Kinetic Energy Calculator to get these figures? As always though, you€™ve come up with a nice idea.
                            Asmaprene€¦ I€™ve been using it on Exertion for several months now with no complaints. As you can see, it does exist and it is just a variant of rubber, which I decided to introduce as an alternative to Vulkolan. It seems that Samuel noticed and decided he wants to use it too. As you can see on the website, it has €œhigh resistance to grease, oil and hydrolysis and mechanical impact€ and €œexcellent adhesion to metal€. Basically, Asmaprene and Vulkolan are quite similar. I believe Mechaniac once used Asmaprene, so it has been tested in robot combat before.
                            Ben, your robo-zoo is wonderful. That is all.
                              Im assuming that non-attached teeth are like the teeth on The 6isc, where the teeth are simply part of the discs shape rather than welded on.
                                Thanks about the concept. Its actually an evolution (in my eyes) of Tornado Mer - a low robot, with a spinning bar on top. The bar was powerful, but discs always seemed to be better than bar spinners, so I put a disc on top and called it Inferno
                                A number of things I need to get right, so Im going to set them right here for everyone.
                                When I said, the armour is curved to avoid panels being torn, I didnt mean torn as in cut, I meant torn as in torn off - Its an idea being used by Frank on Masamune as the armour is a large sheet of 6mm Hardox curved over the whole body, so the armour cant just be removed panel by panel. I meant that the 6mm Weldox circumference is 1 panel, so it cant be torn off.
                                About the padding, I said 1 Inch of PU foam, 1cm of Vulkanised Rubber, and it has 0.5cm of PU foam between each motor, so the motors arent shock-killed.
                                About the teeth, I meant that the teeth were part of the disc (which is 8mm thick Hardox for durability) so the teeth cant be torn off. Frank is using it on The 6isc, but the main reason I did that is that is weve all heard of the Mauler dance and I didnt want to risk Inferno loosing a tooth and doing that mad dance.
                                The wheels are now increased in size to 60mm in diameter - the robot is very small, at 100mm in height, so I cant a wheels equal in size to even Terrorhurtz - he has 130mm wheels, but is 80cm tall, thats why the wheels look so small - but hopefully, Ive gone through all the original faults and corrected them for you all
