Hold everything Martijn...isnt that conflicting with what AJ said about Chaos 2, Tornado and Storm 2?
no it is not, ALL 3 turn on the spot, only Chaos 2 does so with less friction and therefor more smoothly, and quicker if all 3 would have the same motors and gearing
EDIT: as a matter of fact, both AJ AND me are completely right in their posts, all variants can turn on the spot, 2WD does so with more agility/quicker, 6WD does so more slowly and with lotsa friction
Provided the motors and gearing can conquer the friction of the wheels you can. What most 6wd robots do is make the middle pair of wheels a few mm larger so it eases the turning.
Shape: A Box with a flipper at the front
Colour: Red with a picture of a platypus on top facing the rear, the tail covers the flipper
Speed: 15MPH
Weight: 100KG
Armour: 4MM Titanium
Drive: 2 C40-300 Magmotors @ 36V
Power: 6 NiCad Battlepacks @ 36V
Locomotion: 4 Wheels that just poke through the top and bottom of the robot
Ground Clearance: 3MM, 0 at the front of the flipper
Turning Circle: 0
Weaponry: A rear-hinged flipper powered by a 80X100 ram at 750 PSI, powered by a 2.5KG Co2 tank, the flipper also has a built-in front-hinged flipper powered by an identical ram and runs off an identical Co2 tank , the first flipper is 40X30X1 and the other is 20X15X1 and is exactly in the middle of the other flipper
Srimech: Invertable and the flipper can right it
Strengths: Powerful flippers, Fast, Invertable, Unique weapon
Weaknesses: May be hard to control
Speed: 15MPH
Weight: 100KG
Turning Circle: 0
Seeing as Robo-Platypus was such a success here€™s....
Robo-Aardvark
Shape: A box with sloped sides (that does not include the front and back)
Colour: Light blue with the picture of an aardvark on the top
Speed: 10MPH
Weight: 100KG
Motors: 2 Team Wyachi TWM3s @ 36V
Power: 7 NiCad Battlepacks @ 36V
Locomotion: 4 wheels with a vulkalon coating
Ground Clearance: 4MM
Turning Circle: 0
Weaponry: 1) A Rear hinged flipper powered by 2 80X140 pneumatic rams running of a 3KG tank
2) A 20KG vertical fly wheel running at 2500RPM inside the flipper
powered by a perm 132, it has 16 2CM teeth
Srimech: the flipper
Strengths: Powerful weapons, Weapons synergy, Both weapons able to perform OOTA€™S
Weaknesses: Thin armour, Quite slow
Paul, I didnt want to say this in Kodys tournament but Nitrogen is not filled on weight but on pressure. So 2x 1,5kg Nitrogen makes no sense. Under FRA rules (and I hope you guys use those pneumatic rules because the RFL rules are lethal, Im amazed no one died there yet) the main bottles are only allowed a maximum of 1000psi.
CO2 is liquid inside the bottles, and therefore those are weighed since pressure is too variable.
