Re: How could I Improve pt 2
its 7mm at the sides and back, and 5mm at the front.
so...
Name: ooh! Im dizzy€¦or O.I.D for short lol
Shape: an equilateral triangle, with what would be the pointed bit as the front.
Weight: 100kgs
ground clearance: 7mm at the sides and rear, and 5mm at the front
Drive: 2x Lem130€™s, powered by 5x NiCad Battlepacks.
Armor: 3.2mm hardox all around, but at the back there is a 5mm hinged hardox wedge.
Locomotion: 2 Vulkalon coated wheels
Weaponry: the best bit! It has a nasty 20kg horizontal spinning disk, sunk slightly inside the robot, made out of 8mm hardox with 6mm teeth, its powered by a LEM-130 Lynch geared down to 2000rpm
Dimensions: 99x90x33
Scrimec: it is invertable
Strenghs: strong, tough, destructive
Weakness: untested in battle
so...
Weight: 100kgs
