Vapourbot Vengeance Series 1
    W00T!
    Thanks for the incredible response, guys!
    ENTRANTS
    1) Steve
    2) Joey
    3) Alex
    4) Kody
    5) Paul
    6) Martijn
    7) Leo
    Aaron
    9) Martyn
    10) AJ
    11) Me
    Yes, thats right, I will be entering this tournament (its too good to miss! ). However, I will not be writing my own fights, and not selecting my robot: that is up to you guys! I have created a poll on the ZED forum for you to pick which robot will represent Team BriteSpark in this tourn. Please be nice!
    Link: http://strickenone.proboards99.com/index.cgi?action=display&board=teambv&thread=340http://strickenone.proboards99.com/i...teambv&thread= 340
    N.B. I will not be voting in this poll.
      talking about a plot twist!
        Due to someone re-structuring the ZED forum *cough AJ cough* , the link is now:
        http://strickenone.proboards99.com/index.cgi?board=vv1&action=display&thread=341http://strickenone.proboards99.com/i...lay&thread=341
          OK, I think Ill enter Axe-O-Lotl in Melee 2 as Robot 3. Stats...are around. I think youll find the most up-to-date ones on the Vapourbot Help thread or whatever its called.
          (Message edited by Dinowarrior on June 24, 200
            Id like to enter Hot Sauce please. Link to stats:
            http://strickenone.proboards99.com/index.cgi?board=wwvapours&action=display&thread=33 6http://strickenone.proboards99.com/i...n=display&thre ad=336
            Oh and Melee 2
            Robot 4
              Thanks for entering, Chris and Chezza.
              For my sanity, heres Axe-O-Lotls stats, taken from the How To Improve Thread.
              AXE-O-LOTL
              Weight: 100 kilos
              Body Shape: Comengetorix
              Speed: 20mph
              TC: 0
              GC: 6mm
              Wheels: 4 inner
              Armour: 3.25mm Hardox all around.
              Power: Same stuff as Storm 2 and Cyclone Force uses.
              Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
              Weapons: A very nasty pneumatic axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
              Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
              Inspiration: My favourite amphibian, the axolotl.
              Strengths: Powerful weaponary
              Weaknessess: Obviously a limited CO2 supply.
                Ill enter Flank Attack, the stats of which I think can be found in martijns second tournament. Use the stats that are linked to daves website, though, as opposed to the ones that martijn used for his tourny. :P
                Melee 1 Robot 4
                (Message edited by Siphai on June 25, 200
                • #23
                  Again, for my sanity, Flank Attacks stats are here: http://farr.proboards21.com/index.cgi?board=targeted&action=display&thread=481http://farr.proboards21.com/index.cg...lay&thread=481
                  2 more spaces left! Thanks to everyone who has entered so far!
                  • #24
                    Tira IVs teeth wont last long Ko-D 100Kj impact will shear those things right off!
                    • #25
                      Walk Don€™t Run 3
                      Shape: Disc Shaped
                      Weight: 110 kg
                      Armour: 6mm Hardox for the ring, 3.5mm Hardox for the top and bottom
                      Dimensions: 89 X 89 X 20
                      Drive: 4 Shuffling Pads with 6 Legs with vulkalon rubber
                      Batteries: 5 X 24V NiCad BattlePacks
                      TC: Zero
                      Top Speed: 13 mph
                      GC: 3.8mm
                      Weapon: A 32kg Spinning ring with 2 X 2kg Hypnodisc style teeth, but more larger and more curved, Spinning at 2200RPM powered by a 36V LEM-130, has an absolute buttload of shock proofing inside to stop it from self-destructing.
                      Srimech: Its Invertible
                      Strengths: 360 degree Killing zone, EXCEEDINGLY DESTRUCTIVE!!!!!!, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH
                      Weaknesses: Almost invincible, but does not like flippers, although invertible
                      • #26
                        You forgot the numbers, Samuel :wink:
                        • #27
                          Also, Sam, shuffing robots do not have a weight advantage, meaning that Walk Dont Run 3 is 10kg overweight.
                          Maybe a reduction in the armour (4mm Hardox instead of 6mm) will be enough? As soon as alterations are made, I will be glad to accept your entry.
                          One more space left!
                          • #28
                            Yay! Alex M and W is back!
                            • #29
                              Walk Don€™t Run 3
                              Shape: Disc Shaped
                              Weight: 110 kg
                              Armour: 4mm Hardox for the ring, 3.5mm Hardox for the top and bottom
                              TC: Zero
                              Top Speed: 13 mph
                              GC: 3.8mm
                              Melee 2, Robot 2
                              • #30
                                quote:
                                Shape: Disc Shaped
                                Weight: 110 kg
                                TC: Zero
                                Top Speed: 13 mph
                                GC: 3.8mm
                                LEM130 running on 36v powered by 24v battery packs ;-) I think you meant 36v packs. Also, what motors power the drives? 4 shuffling pads and 6 legs? sounds rather odd, is it a walking shuffler, or a shuffling walker
