In the Annihilator, I have the strange feeling that well see the underdogs of Do Or Die and Sithis standing the best chances here, maybe Sithis to win.
In the next round, its possibly between ANATB and Seung Mina to go, as if Kody does what he wants, Martijn is doomed, but if Kody goes over the spikes in the floor, or Chezza goes after him and overturns him, Kody is to go...Bye Kody.
EDIT ONCE AGAIN :P : Oh, I remembered something; Do Or Die and the arena spikes would be hard put to it to flip over a bot with a ring around it. The way I see it, if Do Or Die comes in with the lifter, Mina will just tilt onto the ring, but once the angle goes too far, shell land right on top of Do Or Die, and still be very hard to flip over. Id say something with the calibre of Chaos 2 or something similar could achieve that if they got under the main body, but I dont think Do Or Die could do that. And the arena spikes, if they caught a side, would simply push Mina onto the ring as well.
But still, avoid Do Or Die, as that could delay me some aggression points if it pushes me around the whole fight.
Event 2- All Stars
1- Kody Kunz
a) Wedginator Devilution
2- Joey McConnell
a) Nidhogg
3- Daniel Stickler
a) Supreme Glory Omega
4- Paul Cuomo
a) Nitro-Gene 4.0
5- Alex Holt
a) Achilles
6- Martijn M Benschop
a) Liar 2
7- Danny Bailey
a) Cat with Wheels
8- ???
a) ???
9- ???
a) ???
10- ???
a) ???
11- ???
a) ???
12- ???
a) ???
13- ???
a) ???
14- ???
a) ???
15- ???
a) ???
16- ???
a) ???
Event 2- All Stars
1- Kody Kunz
2- Joey McConnell
a) Nidhogg
3- Daniel Stickler
4- Paul Cuomo
a) Nitro-Gene 4.0
5- Alex Holt
a) Achilles
a) Liar 2
7- Danny Bailey
a) Cat with Wheels
8- Steven McGregor
a) Wedge Devolution
9- AJ
a) SOR X
10- ???
a) ???
11- ???
a) ???
12- ???
a) ???
13- ???
a) ???
14- ???
a) ???
15- ???
a) ???
16- ???
a) ???
ETC08 Extreme: Annihilator round 3
Seung Mina IV v Do or Die v Sithis v Another Night at the Bar
Booth 1: Kody Kunz, Chezza
Booth 2: Danny Bailey, Martijn M Benschop
Bugs Bunny and Roger Rabbit are in the CPZs.
3...
2...
1...
ACTIVATE!
Mina is using her spinner ring in this fight, and although she can€™t self-right with it on its very unlikely she€™ll get flipped, as the ring will probably stop Do or Die or the arena spikes flipping her. And she€™s also the most aggressive at the start of the round, moving in on ANATB and pushing Martijn onto the Killsaws! BZZT! ANATB is bounced away, but no Do or Die comes in behind Mina and lifts her up, then pushing Kody onto the Killsaws! BZZT! Mina is bounced into the air and lands on top of Do or Die, and Chezza now heads for the pit release button, hitting it, but letting Mina slide off the top! And now Mina rams in behind Do or Die, getting underneath and pinning Chezza up against the wall, but now Sithis comes in from behind and slams into Mina!
CRASH!
Danny hits the ring and spins away, and Mina is unaffected, but now she reverses after Sithis, leaving Do or Die to escape and ram Mina again, lifting her once more and pushing her onto the Killsaws again! BZZT! Mina is bounced sideways, and nearly goes over, but the ring stops her and she attacks ANATB, again, pushing Martijn into Sithis!
CRASH!
Sithis is knocked away, but ANATB escapes from Mina and spins up to attack Do or Die, hitting Chezza hard and sending him spinning away across the arena and onto the Killsaws! BZZT! And now Sithis attacks ANATB from the side, spinning Martijn around, but not causing any real damage, only angering Martijn, who spins up and slams into Sithis, which is knocked flying across the arena and into Roger Rabbit, who rams Danny across the arena and into the opposite wall hard, and yet isn€™t finished there as Roger gets underneath again and hands Sithis to Bugs, who clamps Danny in the claw and holds him up high, then starts spinning and releases Sithis at the pinnacle of the spin, and then he watches as Danny sails across the arena and bounces along the floor, finally coming to rest on the Killsaws! BZZT! Sithis is thrown away across the burrow again, this time hitting Do or Die when the ring is spinning at top speed!
Do or Die is thrust away into the rear of Seung Mina IV, and attacks Mina from behind again, lifting her up and pushing Kody around in a wide arc- and now they€™re both facing the pit! Do or Die gets those LEM-200s going and rushes towards the pit, dumping Mina into the chasm and out of the annihilator!
CEASE!
It€™s a massive turn around, and Seung Mina IV leaves the contest!
