Robot SMASH!!
Ill enter for team Insanity...
Nitro-Gene 4.0 (Also competing in Annihilator and Tag Team)
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox for the body. 6mm Hardox flipper.
€ SHAPE: Low invertible box with pointed sides and rear. At the front is a 42* wedge to aid in getting underneath other robots. All the lines have been curved over to make it harder for a spinner to grab onto a panel and rip.
€ MOTORS: 4 x LEM 130€™s at 36V = 36HP
€ LOCOMOTION: 4 Vulkanised Wheels.
€ DIMENSIONS: (L) 90CM (H) 17CM (W) 70CM
€ COLOUR: Black all over with the flipper coloured red.
€ WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a ratio 2.2:1, the flipper produces 1600kg of force at the tips, allowing me to launch anyone away! This version has 2 x 3kg Nitrogen bottles, giving me 25 flips!
€ SPEED: 22mph
€ GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the sides/rear, its 2cm. The orginal weakness of Nitro-Gene (its high ground clearance) has been seen to by the skirts on the sides/rear. They are 5mm Titanium skirts and are joined together like BioHazard - at the corners. To avoid them breaking off, they are held in place by Hardox hinges.
€ STRENGTH: Pushing power and weaponry.
€ WEAKNESS: High speed may mean difficult driving
D.V.D (Death Via Drum) (Also competing in Challenge Belt and Tag Team)
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox.
€ SHAPE: An invertible box shape with triangular sides and rear.
€ MOTORS: 2 x LEM130€™s at 36V = 18HP
€ LOCOMOTION: 4 Vulkanised Wheels on top and bottom ala Big Nipper.
€ DIMENSIONS: (L) 70CM (H) 23CM (W) 70CM
€ COLOUR: Black for the drum, white for the body.
€ WEAPONRY: At the front is a 15kg drum, made of Titanium with 3 sharpened tool steel teeth. The drum is powered by 2 x LEM130€™s on a ratio of 1.5:1, giving a spinning speed of 6500rpm! 65kj of energy per hit, and if flipped, the drum can be reversed to help it spin the right way - upwards. Behind the drum, there are massive amounts of shock-proofing to avoid self-destruction.
€ SPEED: 13mph
€ GROUND CLEARANCE: The ground clearance is the same all the way around, due to no skirts or wedge - its 6mm all around.
€ STRENGTH: Good all-rounder.
€ WEAKNESS: Low speeds.
WORCK
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox for the body and flipper. 6mm Hardox for the scoop. There are hindged wedges on the sides and rear of Worck made of 3.25mm Hardox. The internals are protected by 5cm of Vulkanised rubber mounted on all sides.
€ SHAPE: A low wedge shape.
€ MOTORS: 2 x S28-400 MagMotors at 36V = 12HP
€ DIMENSIONS: (L) 70CM (H) 15CM (W) 70CM
€ COLOUR: Black for the flipper and barbs, white for the body.
€ WEAPONRY: A forward hindged flipper, running on a single 750psi ram running on CO2. The gas is contained in 2 x 2.5kg bottle, giving me 20 flips per fight, and the gearing on the ram 3:1 means we have 1300kg of flipping force! That should mean on a forward hindged flipper that I can flip almost everything OOTA.
€ SPEED: 13mph
€ GROUND CLEARANCE: The wedges, which join up at the corners of the robot, make the ground clearance effectively zero, but underneath the wedges is 5mm of clearance. The wedges are held on by Titanium hindges
€ STRENGTH: Near impossible to get under.
Coinst
€ WEIGHT: 100kg with the heaviest set-up. 95kg with the lightest.
€ ARMOUR: 4mm Hardox.
€ SHAPE Low invertible box
€ LOCOMOTION: 4 Vulkalon treaded wheels.
€ DIMENSIONS: (L) 70CM (H) 22 CM (W) 70CM
€ COLOUR: Black all over with, a green arrow pointing the way forward.
€ WEAPONRY: Interchangable weapons:
1: An invertible front wedge made of 8mm Hardox, weighing 15kg to make it super low. It is hidged so if flipped, it€™ll become invertible.
2: A 7kg Titanium drum, powered by a Lem130 at 46V. It should reach speeds of 1500rpm, and give off 25kj per hit!
3: A set of invertible lifting forks modelled on Panic Attack. They are made of Titanium, and are diamond-tipped to make them super low. Powered by 2 x Lem130€™s at 36V, they can lift 1000kg at the tips.
€ SPEED: 20mph
€ GROUND CLEARANCE: 0-10MM. On all sides are fixed skirts, made of 5mm Hardox. They are hindged in the middle so if flipped, it can still remained skirted.
€ STRENGTH: Interchangable weapons.
€ WEAKNESS: None.
Bar-Red
€ WEIGHT: 100kg
€ ARMOUR: 5mm Titanium around the sides and on the top is 9mm Titanium.
€ SHAPE: A low cylinder shape.
€ DIMENSIONS: (L) 70CM (H) 10CM (W) 70CM
€ COLOUR: Black for the body, and the bar is red.
€ WEAPONRY: The weapon is a bar weighing 20kg, made out of 10mm Titanium, with 2 x 1kg Hardox blocks. The bar is 90cm long and powered by 2 x S28-400 MagMotors at 36V - allowing a spinning speed of 3000rpm. Incase I€™m flipped over, I have an actuator on the bar, electrically powered by a 750 24V Bosch motor.
€ SPEED: 13mph
€ GROUND CLEARANCE: The ground clearance all around is 5mm.
€ STRENGTH: Very dangerous weaponry.
€ WEAKNESS: Unknown.
MeCannibal 2.0
€ WEIGHT: 110kg (Shuffler)
€ ARMOUR: 3.25mm Titanium on top and bottom.
€ SHAPE: Invertible low cylinder
€ LOCOMOTION: 2 x Shuffling pads
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 20CM
€ COLOUR: Black with scary human face with over sized teeth coloured red.
€ WEAPONRY: Ring spinner, made of 10mm Hardox, weighing 30kg, powered by 2 x LEM130€™s at 36V to give it spinning speed of 3000rpm and producing 195KJ per blow with a spin-up time of 3 seconds, but is lethal in 1 second. It 2 big teeth made of Hardox that curve out. The teeth are inserted into the body and have rows of Tool Steel spikes on the teeth to dig in. These teeth 5kg each and are designed to send all the spinning energy into one spot rather than small amount into multiple spots. It also has 5 Inches worth of Titanium shock-proof Foam to stop it self-destructing.
€ SPEED: 15MPH
€ GROUND CLEARANCE: 0MM-8MM. It has a full-bodied 5mm Titanium skirt running completely along the ground that rises when the shell is spinning, but drops when the shell isn€™t spinning. This is powered by a simple 750w Bosch 36V motor and runs at the same time as the spinner.
€ STRENGTH: Scary name and weapon
€ WEAKNESS: Hard to control
Storm 2 (Realie)
Terrorhurtz (Realie)
Hope this satifies.
€ WEIGHT: 100kg
€ SPEED: 22mph
€ WEIGHT: 100kg
€ SPEED: 13mph
WORCK
€ WEIGHT: 100kg
€ SPEED: 13mph
Coinst
€ SPEED: 20mph
€ WEAKNESS: None.
Bar-Red
€ WEIGHT: 100kg
€ SPEED: 13mph
MeCannibal 2.0
€ SPEED: 15MPH
Storm 2 (Realie)
Hope this satifies.
Feel sorry for Steven!Hes hardly gotten into any of them!
