Use the Arena to your Advantage 1 - Bloody Low Walls
    Me! Me!
    NAME: Cat With Wheels
    SHAPE: Wedge with sloped sides.
    COLOUR: Like a Tabby Cats coat
    WEIGHT: Around 100Kg
    DIMENSIONS: L:100cm W:70cm H:50
    cm
    SPEED: 18mph.
    TURNING CIRCLE: Omm
    ARMOUR: 7mm Titanium
    GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
    MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts with 4 NiCad battlepacks
    WEAPONS: Front hinged C02 flipper, powered by two rams, running at 750psi. It can probably flip around 300kg
    SCRIMECH: flipper.
    All Okay?
      Seems like a good oppertunity to test out the new achilles, so:
      Achilles
      Weight: 100kg
      Shape: box, slightly thicker than tornado, not double sided, sides skirted like Panic Attack, back curved for more efficient srimech (like the original hydra), front is sloped at 45 degrees and tapered inwards so that any hits to the front will go to the reinforced flipper plate€¦ See the image.
      Wheels: Four internal cast aluminium wheels (similar to tornados Go Cart wheels in design but only half the width) and using treaded go-kart style tyres of appropriate diameters.
      Motors: 4x S28-400 Magmotors at 24v
      Speed: 18mph,
      Turning circle: 0m
      Armour: 5mm titanium and on top 10mm of polyurethane rubber to stop axes and crushers The flipper itself is a hardox frame and front plate (4mm) and the spatula being titanium. The internal rams are mounted onto a hardox crossbar but otherwise the top of the flipper it is now armoured with 10mm polycarbonate and the aforementioned rubber.
      Ground clearance: At the front, the flipper spatula essentially gives it a 0 ground clearance, at the sides it would be 5mm but is protected by a 3mm stainless steel skirt
      Weapons:
      The weapon is a rear pivoted lifting arm, this has two set-ups, plus a small extra mounted weapon for either. To get under the opponent it has a Bigger Brother style lifting plate that runs parallel to the ground resting upon it that gives the machine a really low ground clearance enabling it to get under most things, the front edge of the plate has been filed to a sharp edge.
      Set-up 1: Hydraulics
      Uses a single hydraulic lifting arm to life opponents of up to 150 kg into the air and tip over up to 400kg. Uses a 120mm bore ram with 40mm stroke and powered using a Vivoil pump
      On top of the lifter is a hook mechanism that looks like a tiny claw but performs the same gripping effect as the top mounted behemoth axe. It is not particularly sharp, as it is not designed to cause damage, just to grip the opponent it is powered by a small linear actuator.
      Set-up 2: Pneumatics
      The second set up is a high-powered pneumatics set-up with a single canister of C02 running at 1000psi providing the power. The addition to this set-up is a small T-shaped bar powered by an actuator which pivots towards the back, enabling Achilles to self right without using up any gas.
      Strengths: Very durable, no particular weaknesses for opponent to exploit.
      Weaknesses: No damaging weapons.
      However, as there is no interchangeable option, Ill only use the pnuenatic setup.
        Damn... Missed out Kinetic Intent needs a good test
          lol... might as well go for 16 entrants
          claim a spot if you like Aaron
            This is, of course, the updated Cosmic Thunder without the lexan. Grats =)
            http://farr.proboards21.com/index.cgi?board=targeted&action=display&thread=112 5588424http://farr.proboards21.com/index.cg...y&thread=11255 88424
            Im gonna have to actually put in some specifications for the flipper mechanism at one point though, lol
              Right, I should post some stats then, or at least a link to them.
              http://strickenone.proboards99.com/i...play&thread=18
                Bloody hell, 13 entrants in well under 3 hours
                1. Paul Cuomo - NITRO-GENE 4.0
                2. Joey McConnell - The Quaestor
                3. Andre Ydolly - Sir Spinalot
                4. David Sheppard - The Hoof
                5. Andrew Jackson - GeForce 4.0
                6. Cristopher Mason - Die-Ceratops Re-Invertus
                7. Frank Goacher - Starstorm 2
                8. Kody Kunz - The Zenith
                9. Alex MacWilliam - Cosmic Thunder
                10. Chezza - Namies Style
                11. Danny Bailey - Cat With Wheels
                12. Alex Holt - Achilles
                13. Aaron Knight - Kinetic Intent (I think?)
                pull in 3 more people and we have a 16-bot straight knockout tournament, w00t
                • #23
                  If the arena floor is steel, Ill go with http://vapourbots.crystalnode.net/fo...t=63Attraction
                  • #24
                    By the way Martijn, Nitro-Gene 4.0 isnt spelt with capitals.
                    By the way, can I ask if Nitro-Gene 4.0 is actually inside the weight limit and not OVERweight?
                    (Message edited by paulc on March 04, 200
                    • #25
                      Think of it as him getting revenge on you for not calling Another Night at the Bar by its correct name in Eye of the Robot 4, after he repeatedly told you not to call it A Night at the Bar 2. :wink:
                      • #26
                        Nitro-Jean
                        *** Insert Xmen characters on nitrous oxide ***
                        • #27
                          I could wear them
                          • #28
                            quote:
                            This is a flippers paradise, so why will anyone enter anything other than a flipper?
                            So please welcome my entry, the robot wish uses the moon as a crash-site for his opponents...
                            NITRO-GENE 4.0
                            € WEIGHT: 100kg
                            € ARMOUR: 6mm Hardox for the body. 7mm Hardox flipper.
                            € SHAPE: Low invertible box with pointed sides and rear. At the front is a Storm 2 style wedge to aid in getting underneath other robots.
                            € MOTORS: 4 x LEM 130€™s at 36V = 36HP
                            € LOCOMOTION: 4 Vulkanised Wheels.
                            € DIMENSIONS: (L) 80CM (H) 15CM (W) 60CM
                            € COLOUR: Black all over with the flipper coloured red.
                            € WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a ratio 2.8:1, the flipper produces 1800kg of force at the tips, allowing me to launch anyone away! This version has 3 x 3kg Nitrogen bottles, giving me 30 flips!
                            € SPEED: 22mph
                            € GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the sides/rear, its 2cm. The orginal weakness of Nitro-Gene (its high ground clearance) has been seen to by the skirts on the sides/rear. They are 4mm Hardox skirts and are joined together like BioHazard - at the corners. To avoid them breaking off, they are held in place by Hardox hinges.
                            € STRENGTH: Pushing power and weaponry.
                            € WEAKNESS: High speed may mean difficult driving
                            Well, this is what you entered Paul, all clues pointed into the direction that Nitro-Gene 4.0 is spelled with caps, Ill sort it out when I do the draw though
                            I dont want any side-effects like axes/skirts stuck in arena-floors, so everything is Hardox Aaron
                            • #29
                              Attraction it is then. Magnetic goodness, now who can work out which vapourbot Ive revived with this one
                              • #30
                                From the name alone, Im guessing Electro. Sheesh, why not call it Magneto?
