Use the Arena to your Advantage 1 - Bloody Low Walls
Me! Me!
NAME: Cat With Wheels
SHAPE: Wedge with sloped sides.
COLOUR: Like a Tabby Cats coat
WEIGHT: Around 100Kg
DIMENSIONS: L:100cm W:70cm H:50
cm
SPEED: 18mph.
TURNING CIRCLE: Omm
ARMOUR: 7mm Titanium
GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts with 4 NiCad battlepacks
WEAPONS: Front hinged C02 flipper, powered by two rams, running at 750psi. It can probably flip around 300kg
SCRIMECH: flipper.
All Okay?
Me! Me!
cm
SPEED: 18mph.
TURNING CIRCLE: Omm
SCRIMECH: flipper.
All Okay?
Kinetic Intent needs a good test
