Eye Of The Robot - Series 3 (My first real tornument!
    Eye Of The Robot - Series 3 (My first real tornument!&#4
    You might want to divide that by at least 100
      And another thing Timmy, youve done the wrong dimensions as well.
      Youve done them like this:
      Dimensions:40X99X80 (meaning its 40cm long, 99cm high and 80cm wide)
      Ive put the name down, but if you havent sorted it by the time this competition begins, it wont do so well.
        350 tonnes worth of force equals 350 elephants standing on your bot man :P
          No, no, Paul, hes not supposed to know it wont do so well until it loses. Let him be confident and think itll do well and then kill him off. Thats the point.
          (Message edited by kodster on January 07, 200
            40 long, 99 wide and 80 high actually, and ACTUALLY, without dimensions, were supposed to believe its MMs hes talking about since thats standard in egineering
              So thats actually 4cm x 9.9cm x 8cm.
              There are antweights bigger than that. :P
                Hmm, might as well see if I can actually win one of these on my own.
                1) Wedge Devolution
                SHAPE- low wedge with sloped rear and Biohazard-style side and rear skirts
                COLOUR- sleek and shiny silver
                WEIGHT- about 100kg
                DIMENSIONS- 90cm X 78cm X 40cm
                SPEED- 16mph
                TURNING CIRCLE- 0
                GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot (without skirts), 0mm at all sides (with skirts)
                ARMOUR- 4mm Hardox
                WHEELS- inside robot, 4-wheel drive
                POWER- 12 x 12v 3amp NiCad packs, giving 36v @ 12amp; 2 x LEM-COs at 36v for drive
                WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. According to Dannys flipper calculator (making the flipper 6kg and the amout of gas aboard 2kg), Mr Devo should use about 34 flips per fight and throw approximately 816kg in total.
                Also, the front blade can be exchanged for a Nose-style plate, approximately 15cm in length. This is used primarily for full-body spinners, but hardly ever used.
                SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
                NOTES- flashing red light on top of robot, flies Scotland flag
                STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
                WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers)
                2) Killotine: EVO
                SHAPE- compact box shape with a front Storm 2-style wedge and spatula for getting under other bots
                COLOUR- red
                WEIGHT- about 100kg
                DIMENSIONS- 100cm X 70cm X 35cm
                SPEED- about 16mph
                TURNING CIRCLE- 0m
                GROUND CLEARANCE- virtually 0mm at the front, 10mm at sides and back without skirts, 0mm at sides and back with skirts
                ARMOUR- 15mm polycarbonate top and bottom, 3.25mm Hardox armour at sides, front and back
                WHEELS- inside robot, 4WD
                POWER- 2 X LEM-130s
                WEAPONS- The main weapon is the large 180 degree pneumatic axe, very similar to that of Killerhurtz. It operates at 160psi with a rack-and-pinion system like Terrorhurtz. The axe is composed of 3.5mm Hardox, but if anything should happen to it, the robot can use its great pushing power to resort to a Tornado-style tactic - ram to death!
                SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. The machine also has a rounded back and a red semi-sphere on either side of robot to stop it landing on its side.
                NOTES- flies the Scotland flag
                STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
                WEAKNESSES- so-so turning
                3) Metal Sonic Spin Dash
                SHAPE- low skirted box, with fixed front wedge & sloped sides
                COLOUR- blue bodywork, with red-and-white striped skirting
                WEIGHT- about 100kg
                DIMENSIONS- 102cm X 75cm X 20cm
                SPEED- 16mph
                TURNING CIRCLE- 0m
                GROUND CLEARANCE- virtually 0mm at front with spatula, 0mm elsewhere with skirts, 12mm elsewhere without skirts
                ARMOUR- 3.75mm Hardox
                WHEELS- inside robot, 6WD
                POWER- 2 x LEM-130 MagMotors. These will run at 36v and produce approximately 18hp.
                WEAPONS- The main weapon here is really the excellent traction, but like all its other incarnations, Spin Dash still maintains its Pussycat-style vertical saw blade, running at 3000rpm. This time, however, the four-clawed spinner sticks halfway out of the front wedge, so that when the wedge/spatula combo bashes underneath an opponent, both the wheels and the underbelly are at the mercy of the saw.
                Also features several Mute-style barbs on top to hook onto other robots and let me drag them around the ring
                SRIMECH- a rear-hinged arm on top with a basic low-pressure CO2 set-up. Can be used to about 30-40 times and is ONLY used for self-righting in order not to waste the gas supply
                NOTES- flies the Scotland flag (though, forgot to add to pic. Shockaroonie!), has F*** Shadow! written on the underbelly in red
                STRENGTHS- excellent traction, fast, manoueverable, tough armour, well-skirted, great at getting under everyone else
                WEAKNESSES- so-so turning ability, teething troubles?
                PICTURE- http://img77.imageshack.us/img77/3603/fifthspindashde6.pnghttp://img77.imageshack.us/img77/360...pindashde6.png
                4) Whirligig 4.0
                SHAPE- flat disc
                COLOUR- deep yellow with Mauler-style scary face on top
                WEIGHT- about 100kg (see bottom)
                DIMENSIONS- 101.6cm diameter X 12.7cm
                SPEED- 15mph
                TURNING CIRCLE- 0
                GROUND CLEARANCE- 4mm
                ARMOUR- 1.905 cm thick Grade 5 titanium
                FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
                POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
                WEAPONS- the main weapon on Whirly 4.0 is a much improved spinning shell. Weighing in at 33.72kg overall, its heavier than before and now boasts 9 Pussycat-style blades - 3 on the top, 3 in the middle and 3 on the bottom, so it can get some scars in nearly all opponents. The shell is now powered by 2 X LEM-130s running at 36v (these lie on their side, so they will fit comfortabely inside Whirly). These produce 2000rpm...and 183 kilojoules. This should be enough to completely obliterate another machine. Or worse.
                As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
                SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
                NOTES- Mauler-style scary face on top and bottom which show direction of robot, flies Scotland flag, my first properly calculated machine
                STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
                WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
                WEIGHT CHECK:
                armour = 33.72kg (inc blades)
                chassis, mounts, bracing etc = about 30kg
                drive and weapon motors = 12kg overall
                NiCads = about 15kg
                feet = about 10kg overall
                TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule.
                5) Clawdius Decimus Murderous
                SHAPE- wedge with small box section and high rear wedge
                COLOUR- deep green with shield emblazoned on the wedge
                WEIGHT- about 100kg
                DIMENSIONS- 95cm X 73cm X 70cm (including claw - 35cm without)
                SPEED- 13mph
                TURNING CIRCLE- 0m
                GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
                ARMOUR- 5mm Hardox
                POWER- 2 X S28-300 MagMotors (thanks to Scott here)
                WEAPONS- The main weapon is the Razer-style crushing claw, operating at 3000psi (5000 if permitted in certain tournaments), with a nice little diamond-coated tip. Also at the front is a Firestorm-style blade and 2 small €œspears€ to aid in getting under the opposition. Combined with the crusher and the reasonably powerful 4WD, CDM can become an effective pusher/clamper
                SRIMECH- Like before, CDM uses a rear-hinged pneumatic arm on either side to self-right. The high-wedged rear also prevents the robot getting perched there
                NOTES- flies the Scotland flag, concept of name came from €œGladiator€ (€œMy name is Maximus Decimus Meridius - father to a murdered son, husband to a murdered wife...but that€™s when I phoned Claims Direct!€)
                STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fast srimech
                WEAKNESSES- so-so manoeuvrability, slow weapon
                6) Turbo Tails
                SHAPE- short box with front wedge, sloped sides & rounded rear
                COLOUR- yellow with the foxs face looking particularly evil on the front slope
                WEIGHT- approx 100kg
                DIMENSIONS- 90cm X 75cm X 25cm
                SPEED- 16mph
                TURNING CIRCLE- 0m
                GROUND CLEARANCE- approx 0mm at front (titanium blade), 8mm everywhere else
                ARMOUR- 3.5mm monocoque Hardox, with 2mm yellow fur over that.
                MOVEMENT- 4 inner wheels
                POWER- 2 x C40-500 MagMotors. These will run at 36v and produce approximately 12hp.
                WEAPONS- Tails chief weapon is the horizontal spinning blade. Now mounted on top, its a bit heavier than before and has Fluffy-style heads instead of the old hammers. Its powered by 2 x LEM-130s running at 36v and has top speeds of around 2500rpm, so its definately just as deadly as before - if not, more so!
                SRIMECH- A front forward-hinged arm, powered by a single, low-pressure CO2 ram. Capable of operating just over 30 times per fight. Not used for the offensive unless desperate. Sloped sides and rounded rear also prevent it getting beached.
                STRENGTHS- orrible weapon, touger armour, fast, fairly compact, greater pushing power
                WEAKNESSES- not quite as manouverable as before, flammability, wholl take it seriously?
                PICCY HERE- http://img63.imageshack.us/img63/8014/turbotailsnu8.pnghttp://img63.imageshack.us/img63/8014/turbotailsnu8.png
                7) Chaos 2 (RW Ex 2)
                Pussycat (RW7)
                • #23
                  OK its 80CM X 99CM X 40CM. Ok it can do double the amount of tonnes than TAN.
                  • #24
                    Not when its powered by an LEM130 @ 48v... If you want to state the power of the crusher Tim you have to actually work it out, not guess a random number. A motorised crusher isnt gonna come close to 1 tonne never mind 350. I will be entering this competition by the way, if anything Im waiting to see who else enters to determine whether I would get any more seeded robots. For now, any chance I can reserve Megabyte and Razer as my real robots?
                    • #25
                      Go ahead AJ, I need as many entrants as I can get.
                      • #26
                        Save me a space, i will post stats when i get back on my computer at uni which will be saturday at the earlyist.
                        Real robots will be
                        1. Fluffy
                        2. Dantomkia
                        undecided on my vapours at the moment, might try something new
                        • #27
                          *sigh* Timmy Timmy Timmy, you need to do some huge research, my friend.
                          • #28
                            ok Paul, I give you my newest design, With or Without you!
                            http://strickenone.proboards99.com/index.cgi?action=display&board=thvapours&thread=11 99898296http://strickenone.proboards99.com/i...thvapours&thre ad=1199898296
                            yeah, still not entirely sure on my other 5, I might do some upgrading soon.
                            (Message edited by MajinB on January 09, 200
                            • #29
                              OK its now running on 4X9 HP motor brushless DC Motors and it should cause in theory a maximum of 130 Tonnes and a minimum of 80 tonnes.
                              • #30
                                No it shouldnt. It really shouldnt.
