Eye Of The Robot - Series 3 (My first real tornument!
i don;t have time to do stats for BBAP5 so is it okay if i replace it with call out hook
NAME- Call out hook (thanks to Matty. H for help with the weapon description)
SHAPE- low box wedge (like storm 2 but not invertible)
COLOUR- white
WEIGHT- 100kg
SPEED- 23mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
ARMOUR- 4mm hardox
WHEELS- 6 inner Vulcalon wheels
POWER- 2 x S28-400€™s Magmotors on 24v.
WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
SRIMECH- the lifting arm which can self right from any position due to the turret
STRENGTHS- good weapons, good pushing power
WEAKNESSES- if the arm is spinning round slowly it may topple
as it makes my life 10 times easier
COLOUR- white
WEIGHT- 100kg
SPEED- 23mph
TURNING CIRCLE- 0mm
ARMOUR- 4mm hardox
