How Could I Improve...
This topic is closed.
  • How Could I Improve...
    I have a sense of humour, but I keep it segregated from most of society...already had enough trouble with it.
      Question about Side Swipe.
      How can it be Barberous 2 shaped, which if I remember correctly is a drum with tracks?
      Also with a spinning drum, where are you supposed to put the axe?
        Dave, technically, it is divided into 2 drums, but both are powered by the S28-400 Magmotor.
        For simpler people, the middle of the drum has a slot, which allows the hammer to stay in place, and not spin like the drum, but also divides the drum into 2 drums.
          ...then why didnt you say that in the stats?
          And not just Laretes has been stolen from, it looks very similar to SHA2 if you ask me
            Mark, the instance you start stealing from MY designs, I join with Kody, Liam and everyone else. You have TWO options...mature, or leave.
              I am serious, it is entirely from my design.
              I can borrow things from some bots, so I just combined Laertes body, SHA2s wedge, and a thwackbot axe. It is a new robot.
                You never actually answered my question from before...
                Why are you still here?
                  ...and WHERE on your vapourbot are the wedges? :P
                    @ Liam: Because I want to be, and the mods (thankfully) havent banned me. Perhaps it is because I am improving a bit.
                    @ Kody: The front part of the tracks.
                      Cyrilium Jr.
                      Weight: 50kg
                      Shape: Hydra (S7), but with a full front wedge.
                      Colour: Silver
                      Dimensions: 65cm x 30cm x 20cm
                      Drive: 4x Bosch drill motors, powered by 4x 24V NiCad battlepacks.
                      Locomotion: 4 fully Vulkanized rubber wheels
                      Armour: 7mm Titanium/Vanadium alloy
                      Speed: 18mph
                      Ground Clearance: 0mm at front due to wedge, and 5mm at sides and back.
                      Turning Circle: 0m, duh.
                      Weapon 1: a pneumatic axe at 180psi, with a 35mm diameter 300mm stroke ram, that gives me about 250kgs in force. With the Hydra-shaped axehead, it can do some damage.
                      Weapon 2: an electric lifting arm, powered by a Bosch drill motor, it is usually used for self righting, and can only lift 60kg or less.
                      Srimech: the lifting arm.
                      I wish to know weather or not Cyrilium Jr. and Side Swipe have any problems.
                        You wont fit a pneumatic axe, a lifting arm, four motors and titanium armour that thick in 50kgs.
                          What would you recomend?
                            Why do you want to be? And your not to improving at all, your getting worse
                              Yes, WHY do you want to be here when clearly everyone hates you? :P
                                To be fair, he has improved quite a bit. Its just his ability at annoying people seems to have increased exponentially...
