At least hes not using fictional materials anymore...now, if we could encourage the use of designs that arent so obviously ripped off from other people, improve his understanding of weight limits and remind him to include motors to power his weaponry, together with somehow erasing everything he did before and making him less of a jerk, we could be on to something here.
Shape: Low box
Weight: 100kg
Dimensions: 85 x 100 x 20
Motivation: 6 x vulaklon tyres
Power: 4 x LEM-130s at 36v, gives 36HP
Armour: 4mm hardox all over, but 4mm hi-grade aluminium(7075) base, 5mm titanium skirts
Weaponry: 5mm hardox Bio-Hazard style lifting arm with a 1mm titanium scoop that runs for the full width of the body, powered by an S28-400 magmotor at 24v, geared at 300:1. The scoop can be swapped for 2 hardox tungsten tipped forks
Top Speed: 20mph
Ground Clearance: 0 at front due to scoop, 0 at sides due to skirts, 6mm at rear and behind those
Turning Circle: 0
Srimech: The arm
Colour: Platinum with name written vetically in red on arm
Strengths: Fast, good pusher, interchangeable arm-ends
Weaknesses: High GC at rear
