How Could I Improve...
No Batteries in there Paul, it cannot drive, or spin up :P
Seriously think its just over the limit, Id drop one of those LEM130s off the weapon, 27KG is light enough for a LEM130, two of them is a waste of weight. Switch the drives to S28-400 magmotors, and it should put you into the clear.
WRT the KE calculation, if they are all on the same shaft, the KE is combined together. So Pauls figure is correct.
