How Could I Improve...
  • How Could I Improve...
    ok, thats 50 kg worth of motors, can you break down what the rest of your machine will weigh?
    wheels+armour+batteries+electronics+weapon+rest=50 kg?
      Ok, Ill make the blade 1000mm. 2 LEM200 for the weapons and 2 LEM130 For the pushing power
        Forget that.
          The whole robot is 97 KG and Blade is 1050mm.
            quote:
            Yes I have a rought feeling about the weight of everything.
            Andre, could you give us a set of stats of what Sir Spinalot looks right now, and roughly say for every component what it will weigh?
            To get you on your way here Im thinking of making a CAD (computer aided... drawing (yayaya, Computer Aided Design)) of Sir Spinalot to see what flaws there are. Youre getting closer and closer to getting yourself your first real vapourbot .
              Ph my robot looks a tuna can with the shape of Revolutionist. The bottom of the body its is wheels, the middle is its weapons and the top is the self righting bar. The color is Light blue with the USA fight on the top of sir-spinalot.
                Very interesting description of Sir Spinalot...
                Can anyone give me advice on my new crusher - Square?
                SQUARE
                € WEIGHT: 100kg
                € ARMOUR: The top armour is 4mm Titanium. The sides (all - front back AND sides) are 5mm Hardox. At the front, between the claws, is 5cm of Vulkanised Rubber to put off spinner blows.
                € SHAPE: Low invertible box with slightly curved sides to prevent balancing on the sides.
                € MOTORS: 4 x LEM 130€™s at 36V = 36HP
                € LOCOMOTION: 4 Vulkanised Wheels.
                € DIMENSIONS: (L) 70CM (H) 25CM (W) 70CM
                € COLOUR: Unpainted.
                € WEAPONRY: The weaponry is a apir of Kan-Opener style pincers, made of Titanium with Hardox spikes on the end. Running on a Razer style system, but in reverse, the claws produce 9 tons at the tips!
                € SPEED: 15mph
                € GROUND CLEARANCE: 0-5MM. On all sides are fixed skirts, made of 4mm Titanium.
                € STRENGTH: Pushing Power.
                € WEAKNESS: Weak top armour
                  weight: 97 kg
                  Armor: 6mm titanium
                  shape: circle
                  Motors: for the weapon 3 lem200 motors, 2 lem170 for the driving
                  Locomotion: 4 foam-filled wheels
                  Ground Clearance: 10 mm
                  Dimmension: 1000mm x 1000mm x 200mm
                  speed: 20 mm
                  weaponry: 1150mm 8x8x8 titanium spinning bar with 4 3x3x4 with a 7 distance titanium teeth that spins 1000 rpm
                  Sri-mech: Yes a spinning bar at the the top of Sir spinalot while the weapon is in the middle.
                  Sir Spinalot is a circle shaped spinner just like revolutionist. Its color is light blue and paint with USA flag on top of sir spinalot.
                    Strength: powerful weapon
                    weakness: lack of traction
                      I thought another weakness would be that it moved at 20mm Im sure you mean 20mph, so Im just noting it down for the future.
                        Yes Sir Spinalot Speed is 20mph
                          Yes Sir Spinalot speed is 20mph! So is is approved. Please say yes.
                            what powers the srimech-bar?
                              Its have the same power of a flipper.
                                hope?
