How Could I Improve...
Its still very much overweight - as is the previous version, now I look at it, sorry.
Four LEMs
Hardox armour
Nitrogen flipper
One of these does not belong in a 100kg robot.
Incidentally, Paul, what you described - mounting everything to the chassis - is not what I would refer to as a monocoque, it is what I would refer to as building a robot
. A monocoque would be if you welded the entire bodyshell and support brackets together, installed an access panel, and then mounted everything inside that with no frame.
(Message edited by joeychevron on June 12, 200
Four LEMs
Hardox armour
Nitrogen flipper
