How Could I Improve...
This topic is closed.
  • How Could I Improve...
    Hows Collateral Damages latest incarnation?
    http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=210&p age=1http://strickenone.proboards99.com/i...teamww&thread= 210&page=1
      Smells faintly overweight to me, particuarly the pneumatic spike option.
        *sticks chopstick up Joeys nose*
          *removes chopstick from nose* Well...I reckon you can have the four LEMs and the hydraulic lifter with the rest of the accessories, but not both. Dont quote me on that though.
          (Message edited by joeychevron on June 02, 200
            Could I just drill holes or something to get the weight down?
              Possibly, but youre looking at a lot of holes there...incidentally, you said the arm was hydraulic but then said it ran off 2 linear actuators. If the arm did run on electric actuators alone, you could concievably fit it all in weight with a few holes, but the spike would still be out.
              Does anyone remember me posting here a while back asking for advice on improving a robot, or am I dreaming again?
                Can you do an electric spike?
                  You could do one with a motor retracting the spike onto a spring, the other option would be to drive it from a flywheel but you wouldnt fit that on the end of an arm.
                    Could you explain the spring thing, so then I could use that?
                      Its like Aggrobots weapon in S3 - you just have a spring inside the arm and a catch to release the spike, and then some mechanism to wind it back in (an overvolted drill motor would do it)
                        Thanks
                          As some of you may know, the Zlaying Every Day forums recently got itself a new and unknown member who listens to the name of Destroyer25. Kody and I spoke this person yesterday over msn, and we discovered he wishes to make vapourbots himself. He is fairly new to forum business but claims to be experienced in robotering. He now has his own board at the ZED boards to store his vapours, but hasnt fully found his way to this forum yet, therefor I decided to introduce this new blood to the grand audience .
                          Lets hear it for Destroyer25!
                          http://strickenone.proboards99.com/index.cgi?board=terv&action=display&thread=282http://strickenone.proboards99.com/i...play&thread=28 2
                          Heres his board. Below is his first and so far only vapourbot.
                          Name: The Undertaker 3
                          Shape: Son of Whyahci
                          Armour: 10 Titanium
                          Speed: 15MPH
                          Drive Motors: 4 S28-400 Magmotors driving 6 TW W238H-150-44H Wheel at 36volts
                          Weapon 1: 3 armed rotors with spiked sledgehammers spinning at 8,300RPM powered by a Briggs & Stratton engine at 12v
                          Ground Clearance: 0mm all over due to the 2.25 tires and 1mm on rotors making it impossible for lifters wedges and flipper to get under and flip or lift The Undertaker 3
                          Strength: powerful weapon good armor and speed
                          Weakness: none
                          Here you have it, some rough and basic stats. Anyone has some good advice for this new kid on the block?
                            Firstly, welcome...secondly, 10 what titanium? 10 metres, 10 fish, 10 green bottles on a wall?
                            Also, 8300rpm is a tad unrealistic, Im not sure if most large motors go above 4000rpm. Having 0 ground clearance all over is also a problem as it means you wont be able to move
                            One final thing; if someone stops the weapon, they will be able to flip you - and dont say it wont happen, there are some evil spinner killers out there (of which I have designed a couple) so you cant expect to just be continuously spinning.
                            Hope that helps. (has he registered over here yet?)
                              I believe you can get over 8000 RPM if you use several motors. 0 CG is a problem.
                              Just out of curiosity, what happened to Undertakers 1 and 2?
                                Hi guys wats up umm heres my new stats
                                Name: The Undertaker 2
                                Armour: 10mm Titanium
                                Speed: 15MPH
                                Weapon 1: 3 armed rotors with spiked sledgehammers spinning at 3700RPM powered by a Etek-R Motor
                                Ground Clearance: 1 all over the machine including rotors Strength: powerful weapon good armor and speed
                                Weakness: none
