Too fast to be really controllable, and from what Craig tells us Eteks really arent worthwhile for drive motors. Stick to Lem-130s, theyre also a lot lighter so you can use that extra weight to maybe bulk up the armour a little.
ok so here is my new stat
here is Ultimate killing machine
Class: Heavyweight
Weight: 100kg
Top Speed: 28MPH
Batterie 4 12v, 16Ah hawkers
Motors: Six Dustins, all set to 34v
Drive: Chain, 6 wheel drive
Steering: Tank
Weapon: Invertible lifting tusk powered by 2 motion actuator
Lift: 8€™@2 sec
Chassis: Titanium
Shape: Sewer Snake
here it is again ps check
Jeez Ive only been away for a couple of hours and there is already a list a mile long.
Well lets look at your stats:
6 dustins to move a heavy is possible, but i doubt you will achieve 28mph on them. They will probably burn out way before then. On 36V you would get about 20mph on the 26cm wheels (I happen to use the same wheels as Sewer Snake in RCC2) And I wouldnt recommend going any higher.
34V is a really weird number to run motors on. 36V or 24V is pretty normal sometimes 48V (but thats not going to happen with Dustins),it usually goes in multiples of 6.
I dont see any mention of armour, so i would need that.
