How Could I Improve...
This topic is closed.
  • How Could I Improve...
    Im too tired to blow up right now, so Ill state this nice and short:
    Stop.
    STEALING.
    +1>OUR.
    +2>VAPOURBOTS.
      lol the secret mssage thing is funny. LOL
        Or is it...
          Nope, doesnt work on grey.
            Hmm...is it possible to embed images directly onto the page?
              Dont think so...
                Lets see...
                No, it seems theyve disabled embedding. :sad:
                So they should take that part of http://www.fightingrobots.co.uk/cgi-...formattingthis
                  How much do linea actuators weigh and how much power do you get out of them?
                    Weight: NFI, but you could probably build a weapon powered by them for less weight than if you used pneumatics or hydraulics.
                    Power: Probably not more than 3 tonnes at most, but Leo will probably correct me on that one.
                      The 1000th post in this thread!
                      Can someone check this robot please?
                      http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=210http://strickenone.proboards99.com/i...teamww&thread= 210
                        I didnt steal it!
                        However, I am working on refining it.
                        Side Swipe
                        Weight: 110kg
                        Shape: Panzer (S3) with a Tornado style wedge on the front
                        Colour: Silver
                        Dimensions: 85cm x 60cm x 0-39cm since there is a wedge on the front.
                        Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
                        Locomotion: 84cm x 10cm x 41cm titanium tank tracks.
                        Armour: 7mm Titanium/Vanadium alloy
                        Speed: 16mph
                        Ground Clearance: 0mm at front due to wedge, at sides due to skirts over the tracks. 5mm at back. 5mm at sides without skirts.
                        Turning Circle: 0m
                        Weapon: A 7kg Terrorhurtz style axehead, for use as a thwackbot weapon.
                        Srimech: Invertible
                        Any ideas for improvement?
                          You wont get any sort of thwackbot effect from tracks unless you use the worlds most insane motors, which would result in your batteries imploding instantly from the current.
                          Also, why does your robot change its height suddenly because of the wedge? Is it a magic wedge?
                          Liam - check your PMs inbox on Kodys forum.
                            Has Mark been reading System Shocks stats? Because its a clone of my robot with an axe on it
                              what does panzer of series 3 look like again?
                                Okay....
                                Side Swipe
                                Weight: 100kg
                                Colour: Silver
                                Dimensions: 85cm x 60cm x 39cm
                                Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
                                Speed: 20mph
                                Ground Clearance: 0mm at front due to wedge, at sides due to skirts over the wheels. 5mm at back. 5mm at sides without skirts.
                                Turning Circle: 0m
                                Srimech: Invertible
