How Could I Improve...
  • How Could I Improve...
    Shape Steel Reign R3 Rochester
    Havent seen it. This is why you need to describe the shape.
      its kinda hard to explain so if its ok kody ill post it here k hold
      http://www.flickr.com/photos/shainemata/416828562/http://www.flickr.com/photos/shainemata/416828562/
        Couple things I also see wrong with this:
        Drive: 2 x S28-400 Magmotors @24v
        Power: 6 NiCad Battle Packs at 36v
        Way too many Battlepacks. Go for 2 Battlepacks at 24 volts. The voltage for the batteries should be the same as the voltage for the drive motors.
        Ground Clearance: 0mm on the front 5mm on both side and 0 on back
        From the pic, It doesnt look like 0mm. Id say 5mm all around.
        Dimensions in CM (Length x Height x Wide) 1.02m x 1.13m 1.13m
        I cant decipher that, sorry.
        Motivation: 4 inner 5.5inch wheels
        Weaponry 2 vertical disk w/tool steel cutter spinning at 4,000RPM powered by 15HP Briggs & Stratton ETEK motor
        Self-Righter: Invertible
        Impossible. Cant be invertible unless the discs are smaller than the wheels or its 2WD, and that would make the discs very weak.
        Implement some changes, please.
        (and it would really if you didnt keep completely changing the entire vapourbot :P)
          pls check
          Name: Psycho Killer 2
          Colour: grey
          Speed: 14MPH
          Weight: 220lb (100kg)
          Armour: 6mm TI
          Chassis: Steel
          Ground Clearance: 5mm all around
          Turning Circle: 0
          Dimensions in CM (Length x Height x Wide) 1.02m x 1.14m 1.14m
          Self-Righter: linear actuator powered bar on top
          Strengths: Powerful spinner, good armour and speed
          Weakness: hates flippers
          Picture: Coming soon
          there sorry for changing the stat
            Name: Texas Chainsaw Massacre 2
            Shape: Sewer Snake
            Colour: Grey
            Speed: 28MPH
            Armour: 6mm TI
            Chassis: Titanium
            Drive: 4 LEM 130s
            Power: 4 12v battlepacks giving 48 volts total
            Motivation: 6 inner Battle Tread Carefree Wheels
            Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
            Turning Circle: Zilch
            Dimensions in CM (LxWxH): 110x75x25
            Weaponry: Modular Lifter powered by 2 560lb Actuator the actuator weights about 9.7 lbs
            Self-Righter: Invertable
            Strengths: Powerful Lifter good armour, speed
            Weakness: exposed wheels
            kody can u pls do a cad
              can someone help me with dimensions pls coz im getting confused Length width and height umm ok so length is the body front to back width is the sides and height is tall right?????????
                ...yes.
                  New version of Texas Chainsaw Massacre 3
                  Name: Texas Chainsaw Massacre 3
                  Shape: Panzer MK 2
                  Colour: Black
                  Speed: 20MPH
                  Armour: 6mm Titanium
                  Chassis: Hardox
                  Drive: 4 LEM 130s
                  Power: 4 x 30cell 36v 3Ah Sanyo NiCad Packs
                  Motivation: 6 Nightmare style wheels
                  Turning Circle: 0
                  Dimensions in CM (LxWxH): 1.24m x 0.76m x 0.46m
                  Weaponry: Panzer MK 2 style lifter powered by 2 560lb Actuator the actuator weights about 9.7 lbs
                  Self-Righter: Lifter
                  Kody can u pls do a cad for Texas Chainsaw Massacre 3
                    What does Panzer Mk 2 look like again?
                    When you base your shape on another real robot, it helps if you could provide an link to an image of said robot.
                      It looks like a large marshamallow, that has been sculpted into the shape of Panzer Mk 2.
                      (a non-invertible 6wd box :P)
                        quote:
                        Kody my friend is going to join Zlaying Forum but he will be using my Screen name at Zlaying and (team extreme robotics)
                        Yyes, a trick used quite often by forum offenders... this friend doesnt exists, does he?
                        Now for something else Ruark, an open question, did you design a vapourbot, and search for someone elses picture to go with it, or did you find a picture FIRST and THEN do the stats?
                        I ask this because when looking at that axe-bot, Zombie, the stats PERFECTLY describe the picture, someone elses picture mind you. Even though the picture is deleted from the side, the text that goes with it should still be considered theft in my eyes and therefor should be edited.
                        quote:
                        ok bro my mistake umm i just like those cads umm anyways is it ok if i keep them on ur site and also if its ok with u kody to make me a cad but i do have a friend that does CADs to and i have them but dont have a scanner oh i ask Martijn= to do a cad but he didnt do it ive ask him lastweek and still he didnt get it so i search for CADs and borrowed them etc but i wanna keep Stay alive and my Revenge of the Zombies CAD on ur site
                        Ok, what I told you over msn is that once you have a robot with stats good enough to be approved by the How could I improve... thread, and also good enough for me to tell what the robot looks like, then Ill be more than happy to do a CAD. Talk to me over msn sometime soon so we can see if one of your robots fits that description :wink:.
                          yes he is bro he is real why should tell a lie he is a pro at making CADs like cody he wants to join FRA and its very soon he is a roboteer like some of guys he builds heavyweight and superheavyweights and he enter them in a tournament
                            well... you lied when you send Kody and me those CADs you stole...
                            for the record Ruark, Im still more than happy to do you a CAD but for that I first need you to get your stats straight, mkay?
                              Is it possible to power a robots drive with the kinetic energy from a disc?
                                Aaron does it on Infusion...I wouldnt use it as the primary drive power though, youd have to stop all the time to let it spin up again. Perhaps as a power boost?
