The Fowler Fic War Series 5
  • The Fowler Fic War Series 5
    Welcome to the second first round battle of Heat 3 of the Fowler Fic War Series 5.
    First in and seeded number 21, Salamander 3!
    Essentially an axlebot in principle, with all the electronics housed in the wheels, Alex has created an invertible horizontal spinner with great power. The drive will never be the best, and the 3mm Hardox could be vulnerable to more dangerous weapons, but the weapon and manouvreability should make up for it.
    FFW History
    In FFW3 - Used the disc to great effect to destroy Double Killa in round 1, however was easily beaten in round 2 by SOR 4.0
    In FFW4 - Got one round further this time, knocking out A Large Red Bus Drove My Love Away in round 1, before removing Cacodemon via K.O. in round 2. Lost to eventual quarter finalists Wedginator 5.0 in the heat final, after being flipped out of the arena.
    FFW Points
    FFW3 - 2/2 = 1
    FFW4 - 3
    Total - 4
    Next in is one of Frank€™s new machines, Dead Horse Beater!
    With a weapon which is shaped like a baseball bat with a nail sticking out of it, you can tell that Dead Horse Beater is out for all out brutality. The low box wedge has good armour, reasonable pushing power, and with the powerful weapon as well could be a dangerous adversary. However the axe will be hard to aim and if it€™s flipped over the underbelly is vulnerable.
    FFW History
    In FFW3 - Did Not Enter
    In FFW4 - Did Not Enter
    FFW Points
    FFW3 - 0
    FFW4 - 0
    Total - 0
    And finally, Yet Another Cut Above The Rest.
    One of the oddest shaped robots in the whole competition, this robot has 2 truncated pyramids housing 2 wheels, with a bar section through the middle which houses a mighty horizontal disc. The armour is 3.25mm Hardox with 4mm titanium skirts, while the weapon should be able to seriously arm more than its own armour.
    FFW History
    In FFW3 - Lost in Round 1 to Drilla Killa Renaissance who caught him on the drills and pushed him down the pit.
    FFW Points
    FFW3 - ½ = 0.5
    FFW4 - 0
    Total - 0.5
    3€¦
    2€¦
    1€¦
    Activate!
    2 horizontal spinners versus 1 insane axe, this could prove to be a very interesting battle indeed. Both spinners move away to try and get up to speed but Dead Horse Beater goes straight on the pursuit of Salamander and slams the axe down on the disc. It bounces back upwards doing no damage, but has stopped the disc. Frank slides his robot underneath and slams him into the fence bringing the axe down again, this time denting the Hardox armour on the Salamander.
    By this point Yet Another cut Above The Rest is spun up, and comes flying into the back end of Dead Horse Beater. The disc slams into the armour on Dead Horse Beater but does nothing but scratch the tough outer shell. Frank turns around to pay his attentions towards YACATR, bringing the axe down on the Hardox bars across the disc. He slams down on it 3 times in quick succession, and it looks obviously bent, but as of yet not enough to impact on the movement of the weapon.
    Salamander 3 has used this opportunity to spin up his weapon though and comes in at the side of YACATR. There€™s a loud whirr and he slams into the side skirts, tearing one off completely, the 4mm titanium and its hinges not enough to stand up to the power. AJ turns his machine and brings it into the wheel of Salamander 2, scratching the hubs, and taking small chunks out of the rubber wheels.
    Dead Horse Beater has moved away at this point to allow the other 2 to get on with their battle but allows himself to run up to the top of the arena and nudge the pit release button.
    Salamander 3 and Yet Another Cut Above The Rest are still embraced in a tenacious waltz, and the 2 of them are still trying to score scratches and scrapes off of one another, but Dead Horse Beater comes back across to try and end it, slamming the axe down on top of YACATR and getting the nail stuck in between the wheel and it€™s casing. He tries to move it back out but the axe appears to be lodged. Salamander 3 sees this as a chance to cause some mayhem, spinning up the disc and striking in between where the 2 robots are stuck, there€™s a loud noise, as another skirt comes off of YACATR, and Frank€™s axe is pulled out of the wheel, albeit without the nail. It also seems to have stopped working as Frank, moving frantically at the controls, can€™t get it out of it€™s fired position on the ground.
    Dead Horse Beater tries to prod the other 2 with his baseball bat but it€™s no good and the 2 just go back to fighting each other, Salamander 3 aiming for the exposed side where the skirt was torn from but managing very little other than scratches. YACATR tries to make his own response and slams into the wheel of Salamander 3 again. Instantly the wheel stops moving. As it happens the force of that attack has broken the magnet in the motor of the drive in one side and Salamander 3 is left a sitting duck. Frank decides to get the fight over with before he can receive any more damage and nudges Alex€™s machine with his back end, across the arena and down into the pit he€™d opened earlier.
    CEASE
    Salamander 3 could do newt about that. Dead Horse Beater goes through along with an impressive looking Yet Another Cut Above The Rest
    Round 2 draw
    Whirligig 4.0 (5) v Dead Horse Beater
    Sengazanken v Yet Another Cut Above The Rest
    Thoughts, Tactics, Predictions, Comments?
      Predictions
      I dont think that axe can do much to the shuffling pads of Whirly...Steve through by a KO.
      Surprising that Sengazanken went through to be honest...so actually, I will have to pass as again either could go through.
      Tactics
      Read, enjoy, rinse and repeat.
        Hah, I knew Id be seeing ol Whirly if I got through round 1.
        Itd be too easy to just give up and say Im screwed, so Im not going to because I honestly dont think I am
        My plan is to let Whirly spin up to full power, then hit the top with the axe. Even a slight tilt should cause Whirly to go gyroscopic, hit the floor and bounce itself halfway across the arena. I think Ive said it before, Whirly is too powerful for its own good and I intend to exploit that.
        If he catches me a few times before I can axe him, the armour should protect me. If his weapon breaks and the robot itself is still working, Ill push him around and try to pit him or something. He might have a good drive, but his shape really isnt efficient for pushing.
        Great battles so far and good luck Steve.
          HEAT C
          ROUND 2
          Dead Horse Beater VS WHIRLIGIG 4.0 (5)
          Spin. Shuffle to sides. Kill.
          You expect anything more from Whirligig?
            I think I might post my predictions, as well as bring this thread back into attention - as I dont want this piece of brilliat work to go under:
            Whirligig 4.0 (5) v Dead Horse Beater: Im going to go for the 5th seed to kill the drive motors.
            Sengazanken v Yet Another Cut Above The Rest: Sengazanken is made of Titanium, at 8mm thick - AJs going to rip that up!
              Should have internet access again soon
                Ah, so thats the reason for your absence. Well I cant say I blame you. My internet has been bannedty for God knows how long.
                  This isnt a bump, but its to ask if this is going to turn out to be a hypothetical? Because I dont want it to, but if it has to, I understand. But please Matty - DONT LEAVE THIS THREAD TO DIE! :sad:
                    it wont be.
                      And so finally, after a long break, Will is finally ready to start writing again, and with this comes the first second round battle of Heat 3, which involves Whirligig 4.0 and Dead Horse Beater.
                      3€¦
                      2€¦
                      1€¦
                      Activate!
                      Straight from the off, Whirligig 4.0 attempts to move as far away as possible from Dead Horse Beater to get it€™s ring spinning up, but Dead Horse Beater catches it with little difficulty and hammers the axe down on top, getting into the shuffling plates. Steve tries to manoeuvre Whirly away but Dead Horse Beater begins dragging him around, with a bit of a struggle. Unfortunately for Frank, in the time he€™s spent holding onto him, Steve has been able to get the spin of Whirligig 4.0 up to its maximum power. Frank continues to try and drag him around and eventually manages to get him over to the Pit Release Button which he duly presses; sending the sirens off and the pit immediately begins to descend.
                      Before he has a chance to try and manoeuvre his prey towards a smoky descent however, he is warned by the officials to release him from the pin as he has been captive for over 30 seconds. He lets go and immediately tries to slam straight into him with the front wedge but the impact sends him flying away, albeit with no damage other than a couple of sheared nuts and bolts. Whirligig 4.0 barely slows down at all however, and comes straight into him again with another attack on the wedge. The same thing happens again with Dead Horse Beater bearing the brunt of the attack seemingly very well.
                      Frank tries to regain control over his spinning machine but just ends up careering into the wall, leaving him a sitting duck for another attack for an increasingly menacing looking Whirligig 4.0. Frank attempts to get into forward motion, but before he can manage it another attack on the wedge leaves the main panel flying across the arena, having had most of the nuts and bolts sheared off.
                      Missing both a panel, and also beginning to limp slightly Frank tries to pull a plan out of the bag, and decides he will continually go in with the front of the now badly damaged wedge. After all, what more damage is he going to do? He comes in again, and brings down the axe once more, hoping to be in a position again to drag him into the pit or some other such hazardous obstacles, but as he brings it down, Whirligig backs off, before coming straight back in. The noise from the impact is tremendous, as gas fills the arena and the axe appears, hanging limply in its downward position, the sheer force sent through it apparently being enough to rip part of it away from its mechanisms.
                      Dead Horse Beater is in an absolute state and is barely able to move around the arena. Steve appears to take pity on this and slows down the outer shell to a less destructive speed. He nudges him once, sending him away with a few sparks, and nudges him again, and it appears he€™s trying to manoeuvre him towards the pit. A couple more nudges, and with Dead Horse Beater sitting limp on the edge of the pit, he turns the shell right down, and with one last nudge, sends him plummeting into the drop to meet his maker.
                      CEASE
                      Dead Horse Beater couldn€™t beat anything more than that. Whirligig 4.0 is through to the Heat Final.
                        good to see ya back Matt
                          Hooray! Matty has returned!
                            Welcome to the 2nd round 2 battle in Heat 3 of the Fowler Fic War Series 5 and today we see Yet Another cut Above The Rest going up against Sengazanken.
                            3€¦
                            2€¦
                            1€¦
                            Activate!
                            Both robots move straight towards each other from the start, both obviously having the idea of preventing their opponent spinning up, whilst both losing aggression levels. It€™s Sengazanken who gains more from this though, as with the superior shape and power for pushing, he slams YACATR into the wall and into the angle grinders, causing sparks to fly off one of YACATR€™s truncated pyramid-shaped wheel pods.
                            AJ doesn€™t respond too well to this onslaught, traversing his way out of a tight situation and spinning up the dual-contact area disc to a reasonable speed, Tony turns Sengazanken to face him with the hinged wedge and comes straight at him with it. The result is points for both parties, as on impact a small gash is left in the wedge of Tony€™s machine, however the wedge pulls him up regardless of the impact and Tony ends up underneath the side of YACATR, possibly doing damage to the underbelly but invisible to the rest of us.
                            He drives across the arena and slams him into the wall once more, where YACATR flops onto his side, but the shape merely allows him to fall back right way up once more. Sengazanken wastes no time in preventing AJ from doing what he did before however, and gets underneath the discs slamming the discs into it, causing sparks to fly once more, before slamming him into the pit release button.
                            The siren sounds and the pit as ever descends, though with slightly less grace than usual. However in trying to reverse , he drops YACATR off the hinged wedge, and AJ moves away to get the disc up to speed. Tony chases after him to try and stop it spinning up too fast, but as he charges in, AJ moves his machine, just slightly and the attack hits the side of the hinged wedge, bending the hinge itself slightly and the slight movement, sends the wedge into the disc, preventing either of Tony€™s front discs from working.
                            The impact has slown the disc down enough though that Tony can come in with the wedge again though, and he attempts to charge straight underneath YACATR once more. Sengazanken appears to have been slightly unbalanced and veers, ever so slightly to the right, this is still enough to get under the wheel pod of YACATR however, and begins once again moving him towards the pit. The bottom corner of the wedge is still digging into the arena floor and cause Sengazanken to move away from its intended destination, which soon leads to problems when he drops AJ€™s machine once again not far from the pit. This gives AJ a chance to spin up his disc ready for Tony to try and come in again.
                            Tony decides to reverse this time as he feels that it may be easier to drive, which it soon proves to be, reversing straight back into him, only to be immediately met by the disc. The impact is huge, a massive gash being put in the side of Sengazanken, who flies off. But AJ loses control of his machine from the impact, and ends up spinning right over the edge of the pit. One wheel is stuck on the very edge. He tries to gain purchase but only ends up pulling himself further over the edge. Swaying he tries to get himself into a position to escape, but a massively slowed down Sengazanken, steers his way back into the frame. A little nudge, another little nudge, each one pushing YACATR closer to oblivion.
                            Finally, AJ gains some purchase, and begins to pull his way out but the limping Sengazanken once again nudges him back over the perimeter€¦ this can€™t go on for much longer, and thankfully it doesn€™t as with one last slightly more powerful nudge, Sengazanken drops YACATR into the pit.
                            CEASE
                            Well, YACATR was teetering, tottering and eventually out, but he put up a better than good fight at points of that match. However, with a lot of repairs to be made, it€™s Sengazanken that go through to the Heat Final!
                            And so to that heat final where it€™s
                            Whirligig 4.0. (5) v Sengazanken
                            Thoughts, Tactics, Predictions, Condoms?
                              ...its alive! Break out the champagne and dust off the...thingy...
                              Sengazanken will only win this if Whirly loses it.
                                Never mind, great battle as always!
                                I think Whirligig should win this one.
