The Fowler Fic War Series 5
Then I shall try to grapple and pit Back to Rock, simple as that. :wink:
Great stuff thus far, Matty!
He goes through to the series semi-finals.
He has 6mm Hardox monocoque armour, shiteloads of power and a very controlled drive. For this fight, I am going to try and dash away from ForcePowers advances with the Magmotor power, and immediately smack the flat sides repeatedly, hoping to take an entire side panel off after much bashing, seeing as it cant be shredded, and then eat into the internals. Hopefully it should happen as my spinning ring has tons of power from its Etek weapon motor, but I wont underestimate ForcePowers endurance. If its an actual true monocoque, which thanks to Joey it should be, then my tactics of going for the sides wont work, and Ill have to take a very risky approach; smack into the side of his wedge to try and take it off, and then if the front gets exposed, keep slamming that. After Ive lost, which seems bloody obvious due to the match-up
, congratulate AJ on a job well done and buy him a can of Magners.
