The Crash & Burn Tournament: Extreme!
  • #91
    Fights will be back up a little later on this week.
    Richard if you have tactics for Ringwraith, Id like them please.
    • #92
      Well, I promised.
      Mayhem
      Metal Sonic Spin Dash vs. Ringwraith vs. Biohazard
      Representing Steven McGregor and Team Braveheart: Metal Sonic Spin Dash! A low profile vapourbot with a Pussycat-style sawblade mounted in front, and a spatula, plus some barbed hooks to hook onto you and drag you where it wants, MSSD can pass you by before you even blink!
      Representing Richard Southworth and Team Velociraptor: Ringwraith! A full-bodied horizontal spinner, its got a nasty spinning drum that can cut into 5mm titanium, and 15mm Lexiguard armour inside. The exposed wheels are also difficult to attack because of this.
      Representing Carlo Bertocchini and Team Biohazard: Biohazard! An even lower profile bot with heavy titanium armour, side and rear skirts, and a cold, dead lifting arm that was helped him win several Battlebots titles.
      Roboteers, stand by...
      Booth 1: Biohazard, Metal Sonic Spin Dash
      Booth 2: Ringwraith
      House Robots: Obelix Bulguous, Taki-san
      3...
      2...
      1...
      ACTIVATE!
      Two spinners and a lifter are here to duke it out, and already Biohazard has gotten to the sides of MSSD and breached the skirts! FLIP! MSSD is already toppled, but Ringwraith is gladly accepted the distraction, and now advances on Biohazard with the fully spun-up drum! Biohazard lowers the arm and shoves MSSD away towards the arena side wall, only for the srimech to pop up and right MSSD, but right back on top of Biohazard, and MSSD is tilted and slammed against the wall! Ringwraith closes in!
      CRASH!!!
      Sparkfest! Biohazard is shunted quite a bit, the rear skirt mangled, pieces flown off, but manages to lift up the arm and send MSSD sliding along the wall, and the srimech pops out, but throws MSSD off the wall and onto its back due to the angle! And its not good at all! The open srimech is wedged against the floor, tilting MSSD slightly, and it cant move! Ringwraith has the drum up to speed again, and goes after Biohazard, but Biohazard goes after the pit release button, nailing it dead center! Pit level from main floor to basement. The Watcher goes over to MSSD and checks things out. Apparently he doesnt like the look of things, and gives MSSD a nudge. Nothing happens...and theres an attack on Biohazards rear again!
      CRASH!!!
      Oh dear! The skirt is gone now, not to mention pieces of the chassis that have flown off as well! Biohazard has also been thrown up against the wall, and is stuck...no, the arm pops out...and leaves Biohazard in the same situation as MSSD! MSSD, meanwhile is now being counted out by The Watcher!
      1...2...3...4...5...
      CRASH!!!
      OHH!!! MSSD has been smashed by Ringwraith, the side taking the most of it by far, badly dented, not to mention losing the skirt! Unfortunately, it didnt right MSSD, and The Watcher has now lost count and has to start the count out all over again, but Ringwraith is not to keen on letting that happen just yet. The drum spins up, as Biohazard, near the pit, throws the arm up, and RIGHTS HIMSELF! Without the rear skirt to thwart him, the 3-time Battlebots champion is back on his feet and coming after Ringwraith! Ringwraith isnt paying attention, but focuses completely on MSSD and smashes into it again.
      CRASH!!!
      The dented side is now gashed up, the 3.75mm hardox unable to stand that 2nd hit...but its righted MSSD this time! Biohazard takes the chance and slams into Ringwraith, sticking the arm in. MSSD rejoices in his reinvertibility and helps Biohazard by charging straight at Ringwraiths front. Unfortunately it does them more harm than good as Ringwraith is pushed on top of Biohazard, and drives off easily, immediately getting the drum going again. MSSD moves around Biohazard and, blade spinning wildly, tackles the full-body drummer just as it turns around.
      CRASH!!!
      Both spinning weapons meet, and the worse one off here is definitely MSSD, as the blade is gone! Oh dear, there it lands, right near one of the arena saw slots. Anyway Biohazard tackles Ringwraith, and raises the arm but that does nothing, only lifting the drumbot slightly into the air and Ringwraith lands perfectly balanced on its two wheels, and spins the drum up again. MSSD charges again valiantly, but Ringwraith rolls one wheel over the undamaged left side and spins around: hes got an open hit on MSSDs side! Steve tries to move MSSD away, but not in time, Im afraid.
      CRASH!!!
      Ringwraith catches the edge of MSSD as he backs off, and throws the hedgehogbot onto its back. Biohazard decides to be mean, and starts pushing MSSD towards the pit! Ringwraith chases down Biohazard and puts a small hit on him with the half-spun-up drum, shunting him away from MSSD, whose srimech pops up and rights him. Biohazard turns and rams Ringwraith, only for MSSD to come at the fully exposed rear and push it away towards the floor flipper. Ringwraith spins around and runs over Biohazard with its wheel, and MSSD shoves it all the way across the arena, right into the wall! WHAM! Biohazards snout is imprinted into the wall. MSSD turns to find a fully spun up drum in his face. Uh oh.
      CRASH!!!
      Once again, MSSD is tossed, and lands heavily onto his back, but manages to self-right. That front is looking pretty beat up though...Biohazard wheels away from the wall, moving a bit slower than usual, and goes to ram Ringwraith, but Ringwraith knows how to dodge Biohazard by now, and simply runs over the skirted bot with one of his wheels, and spins around to face the side with the spinning drum...Biohazard is able to turn in time to also find the drum in his face.
      CRASH!!!
      Biohazard is flung onto its back, the snout on the arm shocked, and...apparently, unable to move at all! MSSD is again tackling the Ringwraith, and succeeds, pushing it all the way across the arena, and WHAM! into the wall! Ringwraiths wheels are jolted off the floor...and The Watcher is counting Biohazard out for good!
      Biohazard is out, and Carlo turns away from the arena and commiserates with his team members, as Taki-san leaves her CPZ and immediately rams the inverted box down the pit. BOOM! One down. And...there is no movement from either of the other two robots as well. The Watcher moves over and shunts MSSD again, pushing it off the wall and tilting Ringwraith off the wedge. Aha! Ringwraith moves away and spins up the drum. MSSD, however, is the broken one here, and Ringwraith abandoning all pretence lays the hurt on him with the drum, this time in the rear.
      CRASH!!!
      MSSD is knocked skyward once more, the backside totaled, and lands heavily onto its back. This time, its srimech does not come to its rescue as it is incapacitated as well. The Watcher is convinced now that MSSD is a dead duck, er, hedgehog and the timer comes on again!
      Out goes MSSD, and Obelix tackles him towards the pit as well, and misses. Ringwraith spins down the drum, his job done, as Obelix gets his bearings back, and hammers MSSD once just for good measure, before dumping it down the hole.
      CEASE!
      Winner: Ringwraith
      Next event: ForcePower 5.0 takes on Asterix Heroicus in the dreaded Sumo Basho!
      • #93
        Sumo Basho
        ForcePower 5.0 vs. Asterix Heroicus
        You all know who Asterix Heroicus is, if youve been in any Crash and Burn Tournament, so I wont go into detail about the house robot.
        The challenger...is ForcePower 5.0! This vapourbot is represented by Andrew Jackson and Team ???. Mr. Tornado-on-acid himself , its powered by two LEM200s and has a hinged wedge in front to get under and ram to death. It only goes at 15mph, though, but it has enormous control and manoeuvrability because of that. 6mm hardox monocoque and invertibility tell the rest of the tale.
        3...
        2...
        1...
        ACTIVATE!
        ForcePower flies out Asterix, who comes to meet him...and neither can get under each other! The wheels grind...and Asterix is slowly being pushed backwards! Oh dear, Asterix doesnt have his own LEM200s run at 60v, does he? Nope, only 48v , and ForcePower is taking advantage of is! Asterix tries to turn away, but its vain, and as they reach the edge Asterix topples onto the tires, off the tires, and onto his back, out of the ring. He spins around in anger.
        CEASE!
        ForcePower 5.0 - 7.34 seconds
        Next event - Vengeance: Tengu VII and Mass Disctruction Revolution have a score to settle!
        • #94
          And now, the moment youve all been waiting for in this heat: Its Vengeance time!
          Vengeance
          Tengu VII vs. Mass Disctruction Revolution
          Representing Alex Holt and Team DoomForAll: Tengu VII! A ferocious full-body spinner with two 7.5kg blades on the spinner and an-anti spinner ring to deal with other spinners. It has good armour, and can even right itself, but its quite tricky to control.
          Representing Aaron Knight and Team Disctructive Technologies: Mass Disctruction Revolution! Its also a full-body spinner, but with 9 hardox teeth on its 25.69kg titanium spinning shell. Its invertible as well, but its top armour is 5mm aluminium which could be damaged...hopefully not here though.
          Tengu had lost to a Mass Disctruction vapourbot before, and wants to tear out MDRs guts! But whose will be spilled? Lets find out!
          Booth 1: Tengu VII
          Booth 2: Mass Disctruction Revolution
          House Robots: Taki-san, Tira-san
          3...
          2...
          1...
          ACTIVATE!!!
          Its MDR that gets up to speed first, and heads in Tengus direction, who has now also achieved its full potential and comes out to greet MDR. Two deadly full body spinners, fully sped, coming right right at each other...oh, shenanigans cant be too far away...
          CRASH!!!
          WHOA!!! What a HUGE hit!!! Both bots go flying backwards straight into the walls opposite! A load of sparks has been created, and as fast as it appeared, it vanishes. What a hit. Ouch. Tengu is still mobile, and actually seems to be okay! The blades are spinning right back up and are pretty much at full speed now! MDR...looks about the same, none of the teeth gone, the rim still shiny and intact...and here they come flying at each other again! I call mayhem!
          CRASH!!!
          ANOTHER HUGE HIT!!! Both bots are sent flying astray again! Only this time, there is definitely some damage! MDRs titanium rim is dented to the EXTREME, caving into the FBSs chassis! Tengu, it seems has gotten one of its blades bent right backwards, but is spinning up all the same. Aaron is very concerned at this point, trying to spin up the shell but cannot do so at all! Tengu is spinning faster and faster, and wobbling! Its clear that Tengu is out of control and flailing around, pulling a Mauler and flying across the arena, to land onto its back near the floor flipper. Up pops the arm and Tengu is righted, but MDR tackles suddenly and pushes it, sliding off quickly. Tengu begins to spin up again, but Alex strikes early to avoid Tengu going haywire again, and puts a hit on MDR with the blades half-spun-up.
          CRASH!
          MDR is smashed away, no damage being done that time, and Tengu goes after him, and spins up a little. MDR spins on the spot rapidly to act like hes supposed to be, an FBS, and Tengu collides with him, blades actually 3/4ths up to speed.
          CRASH!!!
          Its a powerful hit nonetheless, as MDR is blown backwards, Tengus longer teeth gaining the blow as another dent appears in the shell of MDR! And...oh dear, it looks like that blow was to the death, as MDR appears incapacitated, and theres quite a bit of smoke coming out. The Watcher comes in count out Aarons FBS, as Aaron himself pounds against the railing of his control booth in anger.
          Alex is satisfied as he sees the big 10 appear, and having acquired his revenge spins down Tengus blades and waits for the call. Taki-san takes the MDR corpse to the wall and lifts it up against the wall. Another lift...and there we go, over the fence. Unusual though, as house robots should dump their victims in the pit.
          CEASE!
          Winner - Tengu VII!
          Heat B
          More Mayhem is on the way as Axe-O-Lotl, Starstorm 2, and Sauron go for broke!
          Dantomkia starts off our Pinball run!
          Y4 takes on Liar for the Challenge Belt kick-off!
          And then its the All-Stars turn! Firestorm V fights Nightmare in a classic UK vs. US War of Independence! But the next fight is the fight of the night, with Wedge Devolution and Son of Ripper 5.5 duking it out!
          • #95
            Also, just to let you know, Paul Cuomo, I have updated my forum and put your stats there first because you were the first to enter. Tell me if there is anything I missed.
            http://strickenone.proboards99.com/index.cgi?action=display&board=crashburnxtreme&thr ead=1200888495&page=1http://strickenone.proboards99.com/i...crashburnxtrem e&thread=1200888495&page=1
            Your stats were cluttered all over the forum, and I had to find them all and post them, so please, in the (near) future, post all your stats (old and current) in one thread so I dont have to go looking for them.
            I was also nice enough to retype them for you without Caps Lock hurting peoples eyes, so please dont go crazy with the Caps Lock anymore in your stats, its really annoying. Just some advice Paul.
            As I am going to bed now, I will update the rest tomorrow.
            • #96
              yeah, hes boxy, so I guess I have a good chance getting underneath from anywhere, including my twack-around tactic... this should en in an OOTA for sure
              • #97
                No real tactics for Starstorm, just go after whoevers nearest. If I find myself under attack, Ill put the relevent skirt flat to the ground. Being grounded is better than being shoved around. My shape and armour should protect from Ax-o-lotls axe.
                • #98
                  Heat B
                  Mayhem: Axe-O-Lotl vs. Starstorm 2 vs. Sauron: This seems to be quite one-sided. Due to shape and armour, as well as weaponry, Ill go for Frank and Starstorm 2.
                  Pinball: Dantomkia: I dont think Dantomkia will do quite well here.
                  Challenge Belt: Y4 vs. Liar: Im coming after these two, and I believe Ill be fighting Y4, as hell win over Liar via OOTA.
                  All-Stars: Firestorm V vs. Nightmare: Because of FireStorms speed and shape, I think hell bring down Nightmare quite quickly.
                  All-Stars: Wedge Devolution vs. Son of Ripper 5.5: This is deffinate All-Stars! Tough battle, but Ill go for the faster, lower, more powerful Wedge to score an OOTA!
                  Brilliant competition so far.
                  • #99
                    Okay, with the exception of Mattys vapourbots, and Aarons final entrant, I have completely updated C&BX on Me&Martijns forum. Please check it out, and tell me if I have missed anything at all. I dont want to make errors. :sad:
                    Mayhem will be up later. Time for bed.
                    • The Crash & Burn Tournament: Extreme!
                      AXE-O-LOTLS TACTICS
                      Just pummel anything. Im not sure what I can really do against Starstorm, personally.
                      Y4S TACTICS
                      Liar, being based on Wheely Big Cheese, has a lot of body. That means Ill be able to get under him fairly easily and then flip.
                        We€™re at another Heat! Let€™s go!
                        Heat B
                        Mayhem
                        Representing Christopher Mason and Team Dinowarrior: Axe-O-Lotl! Recent heat finalist of C&B2 makes it way into our second mayhem. Powerful axe, powerful drive, and a Comengetorix-style shape give it a good stance, but it has very questionable armour.
                        Representing Frank Goacher and Team Bored: Starstorm 2 Our first full-body flipper run on 500psi and can launch robots off its 4mm hardox dome shape, complete with holes to reduce weight. Its linear actuated skirts are tough too, but it can be outpushed.
                        Representing Aaron Knight and Team Disctructive Technologies: Sauron! It€™s a 2WD translational spinner with 4 hardox teeth on the edges of the spinner (see render). It€™s not quite fast to drive, but its tip speed is 80mph. Add 5mm hardox armour to that and you€™ve got a pretty mean spinner.
                        Booth 1: Sauron, Starstorm 2
                        Booth 2: Axe-O-Lotl
                        House Robots: Our newest housie to the ranks, Ivy-X, pairing up with Exa-Gore-Ic: AI.
                        3...
                        2...
                        1...
                        ACTIVATE!
                        Axe-O-Lotl screams out of his spot and collides with Sauron immediately, stopping the spinner, and then bringing the axe down...on nothing! Miss! Starstorm joins in and attacks the rear of Axe-O-Lotl, and FLIP! Over goes the dinobot on top of Sauron. Starstorm however doesn€™t stop there: it plows into Sauron as well, lowering the skirts just in time to slide underneath Sauron€™s 10mm clearance, as Axe-O-Lotl rights itself off the back of Aaron€™s spinner. FLIP! Over goes Sauron as well, but Starstorm has left him alone, and has headed for Axe-O-Lotl, immediately attacking the rear and sliding underneath! FLIP! Axe-O-Lotl soars, achieving more air than before, and is upended once more! Sauron begins to spin up again, this time unhindered, and soon reaches maximum velocity! Starstorm sees its chance, and as Axe-O-Lotl rights itself again, Starstorm flies directly underneath and pops Axe-O-Lotl€™s underbelly with the dome, sending it flying over onto its back once more, and right in the direction of Sauron! The spinner wastes no time and tears a path of desdtruction towards its target. Axe-O-Lotl waits...and waits...and Starstorm starts shoving it directly at Sauron! Axe-O-Lotl fires the axe and rights itself directly on top of Sauron, stopping its spinning speed, but the edges inside the translational cylinder (wait, not cylinder, er...torus? ) catch the wheels and bank Axe-O-Lotl off of Sauron and away. Starstorm tackles Sauron again and slides underneath with the lnear skirts. FLIP! Sauron goes over again, righted, but Starstorm has already turned back towards Axe-O-Lotl, who€™s coming right after him! He stops just short of the dome and gives it a good WHACK with the axe, however it catches one of the holes and so no damage is really done to the armour of Starstorm, but Axe-O-Lotl backs off before Starstorm can retaliate. Sauron heads over towards one of the CPZ to try and cut Axe-O-Lotl off but Chris, seeing this, reverses, just away from an incoming Starstorm and gives Frank€™s bot another good WHACK with the axe, this time directly hitting the top and giving it a miniscule dent. Starstorm flies underneath Axe-O-Lotl before the latter can get out of danger and FLIP! Axe-O-Lotl flies up, and the rear of the underside bangs into Starstorm€™s uplifted dome, thus falling onto its rear end, but a little push from Starstorm sends it over. Axe-O-Lotl tries to right itself without further interference but Starstorm is persistant and pushes it into an empty CPZ. Ooh, Exa-Gore-Ic flies out of his CPZ but is blocked by Sauron! And there€™s our €˜newcomer€™ house robot, Ivy-X, with those lovely spinning chains. Axe-O-Lotl fires the axe but Starstorm is at him immediately. FLIP! Axe-O-Lotl is pushed up against the arena wall, but falls back down onto Starstorm€™s lid. Sauron decides to get out of the way, and does so as Exa-Gore-Ic trundles past. FLIP! Axe-O-Lotl is popped up again, and the top is pushed up against an angle grinder, but leaning against it throws the axe out, balancing itself off the wall and back onto its wheels, but unfortunately Ivy is right there with the chains!
                        CRASH!
                        Not necessarily a huge hit, but it does send Axe-O-Lotl back towards Starstorm, who again slides €˜neath the front and FLIP! Again we have an inverted Axe-O-Lotl. Sauron heads across the pit and right for Starstorm, but Starstorm really seems to be ignoring him for now and is concentrating its attack completely on poor Axe-O-Lotl. WHOA! Axe-O-Lotl has buried its wedge into Ivy and is slamming her into the wall! WHACK! Whoa, what got into him?! No damage from the axe, though, but Axe-O-Lotl has got the house bot now and heads straight for Sauron. Aaron continues to chase down Starstorm but Starstorm loses the 8mph bot quite easily, allowing Axe-O-Lotl to shove Ivy into Sauron€™s face!
                        CRASH!!!
                        WHOA! Ivy€™s just been sent flying by that huge blow, right off the wedge, no damage though, but Sauron is still spinning! Axe-O-Lotl charges quickly, noticing that Sauron is not quite rotating as well as before.
                        CRASH!
                        Axe-O-Lotl takes the hit and is spun around, the wedge now horribly torn, allowing Starstorm to charge in and dump Axe-O-Lotl into Sauron. Sauron stops spinning immediately and is pushed back into the CPZ. Exa-Gore-Ic receives the translational spinner gratefully and squeezes in, the massive jaws closing around Sauron ominously! FLIP! Axe-O-Lotl is sent almost terminally skyward, but falls down to earth onto his back. Ivy is quite peeved and blasts in again with the flails, striking Starstorm.
                        CRASH!
                        Ineffective blow against that dome, and Starstorm€™s attention is received, but Ivy slams into him harshly. FLIP! Ivy...is also sent over, but fully invertible anyway. Starstorm turns backs to the CPZ.
                        10...9...8...7...
                        Time almost over already? Wow. Exa-Gore-Ic drags Sauron over to the flame pit and leaves him to broil.
                        6...5...4...
                        FLIP! Axe-O-Lotl is righted but Starstorm keeps at it. Axe-O-Lotl gives him another WHACK with the axe, giving the dome another small dent.
                        3...2...1...
                        Ivy smacks Starstorm again with the flails and butts in, as Axe-O-Lotl buries the wedge in as well. Sauron meanwhile burns on the flames...
                        CEASE!
                        A three-way judges€™ decision! This should be interesting...
                        Axe-O-Lotl - Starstorm 2 - Sauron
                        Style = 1/5 - 2/5 - 2/5
                        Control = 1/5 - 3/5 - 1/5
                        Damage = 1/5 - 2/5 - 2/5
                        Aggression = 2/5 - 2/5 - 1/5
                        Strategy = 2/5 - 2/5 - 1/5
                        Total = 7/25 - 11/25 - 7/25
                        Winner: Starstorm 2
                        Next event: Pinball Dantomkia kicks things off!
                          And since this was a generic entry...
                          (sorry, made a mistake; its the Pinball from Series 3, not 2 :sad
                          Pinball
                          Dantomkia
                          Our pinball bout tonight features Mike Lamberts Dantomkia! Its a double wedge with a flipper in the inner wedge. Its done quite well in fights, but its never been in a pinball challenge before...or has it?
                          House Robots: Taki-san guards a 50-point target, Double Whamlet guards another opposite, and Obelix Bulguous guards the big 75 point target. Asterix Heroicus roams the arena at will. So thats...4 house bots.
                          3...
                          2...
                          1...
                          ACTIVATE!
                          Dantomkia speeds away, right after the barrels, toppling many down at once...and one rolls straight into the pit. Dantomkia spins around, knocking some barrels away (and another down the pit ) and heads for the ramp! Oh, hes over it, well done, another 20 points added, and AHH! Hes flipped Obelix Bulguous and toppled him away! Hits the 75 point button, he does! Very good run so far, but now Asterix is after him, hell have to be careful here, and he backs...all the way into the multiball release, good, another 10 points for that. Oh! Now hes taking on Taki-san and a 50 point marker! Nope, drives straight onto the wedge aaaaaand...flipped over. Asterix shoves him into the wall, and pins him there to stop him self-righting, whilst Taki inserts the cutting blade in.
                          CRASH!
                          The rear end of Dantomkia does not take well to that blow, a nice gash cut right through, and Asterix releases Dantomkia. Dantomkia...ah, there we go, righted. Taki shoves him away, but Dantomkia is quite determined to get at that 50 point button and tries to get at the side. Its denied, as Asterix again shoves him away, and right back into a few more barrels, ah, thats all the barrels on that side gone then. But unfortunately for Dantomkia time is up.
                          CEASE!
                          Points scored
                          Barrels - 5 x 9 = 45
                          Ramp = 20
                          75 Point Target = 75
                          Multiball Release = 10
                          Balls fallen into the pit - 2 x 5 = 10
                          TOTAL = 160
                          Dantomkia - 160
                          Next event - Challenge Belt: Its Y4 vs. Liar in this battle for glory!
                            Awesome fight for Starstorm, just a shame I accidentally scrolled too far and spoiled the result before I read it
                              Challenge Belt
                              Y4 vs. Liar
                              Representing Christopher Mason and Team Dinowarrior: Y4! A wilder version of T-Minus, it€™s got 5mm titanium armour, which isn€™t too bad, and is invertible, though with slightly exposed wheels. Its main feature is the flipping arm which can send 300kg bots onto their backs no problem, and can right Y4 in a stylish way. However, with its batteries and motors set at 12v, it€™s not going to be very pushy.
                              Representing Martijn Benschop and Team Varying Every Day: Liar! No, not the new one. 8mm titanium armour give it more protection than its opponent, and like its opponent it has a hugely powerful flipper (1000psi) capable of tossing robots its size many meters in the air! It may not have much pushing power but at 24v, its S28s will be pushy enough. The side wedges on the flipper help to aid in getting under opponents when spinning around, but they won€™t damage the opponent.
                              Booth 1: Y4
                              Booth 2: Liar
                              House Robots: Ancalagon the Black, Double Whamlet
                              3...
                              2...
                              1...
                              ACTIVATE!!!
                              The Challenge Belt kick-off is underway! Liar approaches first and speeds into Y4, who greets him with the flipper blade. WHAM! Both cancel out, and it looks like Liar is the slightly more powerful here, as he€™s currently pushing Y4 away towards the arena wall! Y4 backs off, but Liar persists, and both clearance confront each other again...and it€™s Y4 winning the duel! FLIP! Liar is flicked, and tipped over. FLIP! Liar rights himself, but right back onto Y4€™s arm! Y4 heads to the arena wall! FLIP! It€™s Liar who activates his flipper first, and throws himself backwards, but that only sends him directly onto the flipper blade of Y4 and...NO! Y4 tosses him along the wall! Martijn breathes a deep sigh of relief and directs Liar back over to Y4 and they meet again! Liar prevails! FLIP! Y4 is tossed over. This only means he can€™t use the flipper, and Y4 gets away before Liar can catch him...not long, however, before Liar is able to catch him! Liar smacks him with the wedge, but Y4 is away again before Liar can flip...can Liar use the flipper? Y4 activates the flipper and a beautiful 540 is performed, just as Liar gets to his spot - FLIP! Oh! So he can use the flipper, he was just waiting for his moment! Martijn grins as Y4 goes soaring into the arena wall, back onto his back. Y4 rights himself in the blink of an eye however, popping straight back over this time, and is able to get away before Liar can get in for another devastating toss. Chris is quite determined, showing in his face as he works the controlls for Y4, who charges into Liar once more! Liar veers of course slightly and goes for a wedge thwack to Y4. Bad idea! Y4 slides under the front of the right side wedge and FLIP! Liar is over again...FLIP! And righted again! Y4 is right there however, and before Liar can recover, he€™s over again! (FLIP!) Y4 charges into Liar again and carries him to the arena wall, but Liar pops up again (FLIP!) righting himself and Y4 nearly smacks his snout into the arena wall! Liar turns and flicks into Y4€™s side! FLIP! Y4 now has his turn of being inverted! Liar charges in and gets another flip in, tossing Y4 in a perfect 360! Y4 blows this scene and runs away, activating the flipper as he does so, thus righting himself, but Liar crashes into him and FLIP! WHOA! Y4 goes sailing...OVER THE WALL!!!
                              CEASE!
                              Winner: Liar
                              Next event - All-Stars: Firestorm, Nightmare, Wedge Devolution, and Son of Ripper fight for their right to party, AND advance to the next round!
                                Whatever, these two bots are filler entries anyway.
                                All-Stars
                                Representing Graham Bone and Team Firestorm: Firestorm V! Hes scorched opponents with that awesome front-hinged flipper and appeared in the Grand Final three times. Very low to the ground, and very capable of sliding underneath opposing skirts with that wedge blade. He also has pretty decent armour, but with only 2WD he wont be much of a shover.
                                Representing Jim Smentowski and Team Nightmare: Nightmare! Thats his name, and knocking the hell out of other robots is his game! The disc travels at 1600rpm and is SERIOUSLY powerful. In reality, though, hes got NO armour, only a (very sturdy) chassis, and he doesnt look that balanced despite being flipped only once.
                                Very experienced, these two, excellent drivers, but who will get their stuffing beaten in this War of Independence?
                                Booth 1: Firestorm V
                                Booth 2: Nightmare
                                House Robots: Double Big Mac, Asterix Heroicus
                                3...
                                2...
                                1...
                                ACTIVATE!
                                Lets go! Firestorm is off the mark and crashing into Nightmare, who turns to give Firestorm a taste of his wheel. Firestorm crashes into the wheel and is struggling to get under the side of it. This gives Nightmare plenty of time to get that lovely disc going, but Firestorm turns and has a go at Nightmares rear. Nightmare tries to spin around but his tail wedge is pushed around by Firestorm and he cant seem to get around and attack. Likewise, Firestorm is unable to slide under that rear wedge, even from the side of it...oh, no wait, hes under it, but not all the way, only the wedge blade, and NOT the wedge itself, is under it. Nightmares tail suddenly scrapes the arena wall as it passes, and Firestorm is jolted into the tail, and completely under it! Nightmare drives off, however, before he goes off-balance, and spins around to face Firestorm. Firestorm is already driving at it, right at one of the wheels, but Jim backs his robot off, and Nightmare keeps facing Firestorm with the disc. The pressure is on, and Firestorm doesnt want to put itself at a disadvantage, so he twists here and there, trying to position himself, when Nightmare jumps the gun and comes right at him! As he nears, Firestorm pulls a U-turn, backs past Nightmare, and goes for the wheels again, from the rear. Nightmare is pushed up onto the wedge by his left wheel! Firestorm doesnt want to go too far, however, knowing that the disc is still spinning and very dangerous, and slowly pushes Nightmare, but he can only spin Nightmare clockwise. Nightmare tries to turn around...AND DOES!
                                CRASH!!!
                                The disc slams into Firestorms flipper and gashes it severely, also knocking Nightmare back quite a bit! Firestorm...is okay, and still coming straight for Nightmare, and slides right under the dormant disc, and up comes the flipper! Damaged as it is, it still works, and its got Nightmare, and Firestorm is pushing him towards the wall! NO! No flip! Nightmare manages to keep balance! Firestorm still has him, though, and decides to give him to Double Big Mac, who is nearby. This cant end well...
                                CRASH!!!
                                Nightmare is spun right around, the tail getting smashed across the side, with Firestorm still neath the disc! Asterix flies out and hammers the side of Firestorm, tilting both bots...AND NIGHTMARE IS OUT OF THE ARENA!!! What a tactic! What a hoist! Firestorm has just flipped Nightmare over the fence! A SUPERB flip, right into the middle of the tilted Nightmare, and sent it disc-first, right over the edge, and out! Asterix backs away, which is a bad idea because now its Firestorms turn to attack the house robots, as DBM is gotten under and flipped immediately! Asterix barges in, only to find itself on Firestorms flipper and brought to the wall opposite, slammed against it with the flipper and stacked. How very pathetic.
                                CEASE!
                                Winner: Firestorm V
                                Next All-Star: Wedge Devolution vs. Son of Ripper 5.5 - a classic of the classics!
